store procedure для JB 8 & Oracle (ref cursor & binary_integer table )
Как заюзать следующие конструкции с ref cursor для просмотра понятно, а с type document_tab is table of document_rec index by binary_integer для udi ( update , delete , insert ) не выходит не понятно как делать, как передать данную конструкцию как параметр в процедуры. type document_rec is record ( DI_ID V$SCHEMA#DOC_ITEM.DI_ID%TYPE, DOC# V$SCHEMA#DOC_ITEM.doc#%TYPE, TYPE# V$SCHEMA#DOC_ITEM.type#%TYPE, DOC_DATE V$SCHEMA#DOC_ITEM.doc_date%TYPE, GOODS# V$SCHEMA#DOC_ITEM.goods#%TYPE, GOODS_NAME VARCHAR2(100), PACKAGING V$SCHEMA#DOC_ITEM.packaging%TYPE, AMOUNT V$SCHEMA#DOC_ITEM.amount%TYPE, PRICE V$SCHEMA#DOC_ITEM.price%TYPE, COST V$SCHEMA#DOC_ITEM.COST%TYPE, COST_NDS V$SCHEMA#DOC_ITEM.COST_NDS%TYPE, COST_NP V$SCHEMA#DOC_ITEM.COST_NP%TYPE, COST_TOTAL V$SCHEMA#DOC_ITEM.COST_TOTAL%TYPE, NP NUMBER, NDS NUMBER, TO_CODE TOVAR.TO_CODE%TYPE, WEIGHT TOVAR.TO_WEIGHT%TYPE ); type document_upr_rec is record ( DOC# V$SCHEMA#DOCUMENT.DOC#%type, TYPE# V$SCHEMA#DOCUMENT.TYPE#%type, PLACE# V$SCHEMA#DOCUMENT.PLACE#%type, DOC_DATE V$SCHEMA#DOCUMENT.DOC_DATE%type, DOC_NUMBER V$SCHEMA#DOCUMENT.DOC_NUMBER%type, D_CONTRACTOR# V$SCHEMA#DOCUMENT.D_CONTRACTOR#%type, C_CONTRACTOR# V$SCHEMA#DOCUMENT.C_CONTRACTOR#%type, D_NAME OTDEL.OT_NAME%type, C_NAME CLIENT.CL_NAME%type, PT# V$SCHEMA#DOCUMENT.PT#%type, PARENT_DOC V$SCHEMA#DOCUMENT.PARENT_DOC#%TYPE -- PARENT_TYPE V$SCHEMA#DOCUMENT.PARENT_TYPE#%TYPE ); type document_cur is ref cursor return document_rec ; type document_upr_cur is ref cursor return document_upr_rec ; ========================================================== type document_tab is table of document_rec index by binary_integer ; type document_upr_tab is table of document_upr_rec index by binary_integer ; ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ----------------------------------------------------------------------------------------------- procedure document_refcur(document_data in out document_cur, VID in V$SCHEMA#DOCUMENT.DOC#%type ); procedure document_upr_record(voz_upr_data in out document_upr_cur , VID in V$SCHEMA#DOCUMENT.DOC#%type ); ----------------------------------------------------------------------------------------------- procedure document_lock (document_data in out document_tab ); procedure document_upr_lock (document_data in out document_upr_tab); ----------------------------------------------------------------------------------------------- procedure document_update (document_data in out document_tab, VID in V$SCHEMA#DOCUMENT.DOC#%type); procedure document_upr_update(document_data in out document_upr_tab); ----------------------------------------------------------------------------------------------- procedure document_delete (document_data in out document_tab ); ----------------------------------------------------------------------------------------------- procedure document_insert (document_data in out document_tab , VID in V$SCHEMA#DOCUMENT.DOC#%type, TYP in V$SCHEMA#DOC_ITEM.type#%TYPE, DOCDT in V$SCHEMA#DOC_ITEM.doc_date%TYPE); procedure document_upr_insert (document_data in out document_upr_tab ); ----------------------------------------------------------------------------------------------- ... |
| 25.06.2003, 13:59:59 |
start [/forum/topic.php?desktop=1&fid=59&tid=2154639]: |
36ms |
28ms |
| others: | 269ms |
| total: | 387ms |
