VisiBroker
Нашел VisiBroker запустил самый простой примерчик с использованием JBuilder все сгенирировал нормально все классы Сервера Клиента но Клиент не хочет работать выдает такую ошибку кто может помогите: org.omg.CORBA.OBJECT_NOT_EXIST: Could not locate the following POA: poa name : /Attendees_poa vmcid: 0x0 minor code: 0 completed: No at com.inprise.vbroker.orb.LocatorBidder.getBid(LocatorBidder.java:32) at com.inprise.vbroker.ProtocolEngine.ManagerImpl.startBidding(ManagerImpl.java:199) at com.inprise.vbroker.ProtocolEngine.ManagerImpl.getConnector(ManagerImpl.java:172) at com.inprise.vbroker.orb.DelegateImpl._bind(DelegateImpl.java:271) at com.inprise.vbroker.orb.DelegateImpl.bind(DelegateImpl.java:229) at com.inprise.vbroker.CORBA.portable.ObjectImpl._bind(ObjectImpl.java:62) at com.inprise.vbroker.orb.ORB.bind(ORB.java:1764) at bicon2000.bicon2000.AttendeesHelper.bind(AttendeesHelper.java:72) at bicon2000.bicon2000.AttendeesHelper.bind(AttendeesHelper.java:61) at bicon2000.AttendeesClientImpl1.init(AttendeesClientImpl1.java:53) at bicon2000.AttendeesClientImpl1.number(AttendeesClientImpl1.java:81) at bicon2000.AttendeesClientImpl1.main(AttendeesClientImpl1.java:27) java.lang.NullPointerException at bicon2000.AttendeesClientImpl1.number(AttendeesClientImpl1.java:82) at bicon2000.AttendeesClientImpl1.main(AttendeesClientImpl1.java:27) Exception in thread "main" ... |
| 13.08.2004, 12:58:09 |
start [/forum/topic.php?desktop=1&fid=59&tid=2153802]: |
36ms |
35ms |
| others: | 294ms |
| total: | 412ms |
