запись в BLOB на ORACLE
Есть код db_con.setAutoCommit(false); sql = "select content from a where id = " + id + " for update"; rs = st.executeQuery(sql); if (rs.next()) { blob = ((oracle.jdbc.driver.OracleResultSet)rs).getBLOB(1); blob.putBytes(1L, data); } rs.close(); При попытке записать в BLOB поле получаю ошибку [04.10.06 06:50:04] Invocation exception: ORA-22990: LOB locators cannot span transactions (java.sql.SQLException: ORA-22990: LOB locators cannot span transactions ) java.sql.SQLException: ORA-22990: LOB locators cannot span transactions at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java:134) at oracle.jdbc.ttc7.TTIoer.processError(TTIoer.java:289) at oracle.jdbc.ttc7.v8TTILob.receiveReply(v8TTILob.java:991) at oracle.jdbc.ttc7.v8TTILob.write(v8TTILob.java:249) at oracle.jdbc.ttc7.TTC7Protocol.lobWrite(TTC7Protocol.java:2365) at oracle.sql.LobDBAccessImpl.putBytes(LobDBAccessImpl.java:304) at oracle.sql.BLOB.putBytes(BLOB.java:367) at aktif$docmanager$doc1$html.run(aktif$docmanager$doc1$html.java:1490) В чем проблемма? ... |
| 06.10.2004, 20:22:01 |
start [/forum/topic.php?desktop=1&fid=59&tid=2153636]: |
45ms |
58ms |
| others: | 349ms |
| total: | 514ms |
