Как прикрутить другой парсер к JAXP?
Устанавливаю свойство для парсера - http://java.sun.com/xml/jaxp/properties/schemaSource, он выкидывает исключение - org.xml.sax.SAXNotRecognizedException, т.е. парсер по умолчанию(Crimson) не поддерживает JAXP1.2 , хочу прикруить к JAXP Xerses 2, только вот не знаю как:( ... |
| 11.01.2005, 12:43:46 |
RTFM public static SAXParserFactory newInstance() throws FactoryConfigurationError Obtain a new instance of a SAXParserFactory. This static method creates a new factory instance This method uses the following ordered lookup procedure to determine the SAXParserFactory implementation class to load: * Use the javax.xml.parsers.SAXParserFactory system property. * Use the properties file "lib/jaxp.properties" in the JRE directory. This configuration file is in standard java.util.Properties format and contains the fully qualified name of the implementation class with the key being the system property defined above. * Use the Services API (as detailed in the JAR specification), if available, to determine the classname. The Services API will look for a classname in the file META-INF/services/javax.xml.parsers.SAXParserFactory in jars available to the runtime. * Platform default SAXParserFactory instance. ... |
| 11.01.2005, 14:44:53 |
big_mammothRTFM public static SAXParserFactory newInstance() throws FactoryConfigurationError Obtain a new instance of a SAXParserFactory. This static method creates a new factory instance This method uses the following ordered lookup procedure to determine the SAXParserFactory implementation class to load: * Use the javax.xml.parsers.SAXParserFactory system property. * Use the properties file "lib/jaxp.properties" in the JRE directory. This configuration file is in standard java.util.Properties format and contains the fully qualified name of the implementation class with the key being the system property defined above. * Use the Services API (as detailed in the JAR specification), if available, to determine the classname. The Services API will look for a classname in the file META-INF/services/javax.xml.parsers.SAXParserFactory in jars available to the runtime. * Platform default SAXParserFactory instance. Да, оно самое, просто с ходу не додумался, что там в файле jaxp.properties прописывать :) ... |
| 12.01.2005, 11:07:41 |
Если в лом праить файл свойств можно и так java.exe.....-Djavax.xml.parsers.SAXParserFactory=org.apache.xerces.jaxp.SAXParserFactoryImpl Естественно в classpath должен быть прописан пути к библиотекам ... |
| 12.01.2005, 11:42:10 |
start [/forum/topic.php?desktop=1&fid=59&tid=2153130]: |
28ms |
61ms |
69ms |
| others: | 357ms |
| total: | 572ms |
