запуск exe
Помогите написать функцию для запуска exe файлов. Сам с джавой не работал так что не бейте ... |
| 31.01.2005, 15:58:53 |
запуск exe
ну кто то же знает есть у меня класс CREATE OR REPLACE AND COMPILE JAVA SOURCE NAMED "JavaFiles" as import java.io.File; import java.lang.SecurityException; public class JavaFiles { // === Ôóíêöèÿ ïåðåèìåíîâûâàåò/ïåðåíîñèò ëîêàëüíûé ôàéë === // Äëÿ ïåðåçàïèñè ñóùåñòâóþùåãî overwrite=1, èíà÷å overwrite=0. // result = 0, åñëè ïåðåèìåíîâàíèå ïðîøëî óñïåøíî. // result = 1, åñëè ñòàðûé ôàéë íå ñóùåñòâóåò. // result = 2, åñëè íîâûé ôàéë íå óäàëîñü óäàëèòü. // result = 3, åñëè íîâûé ôàéë ñóùåñòâóåò, à overwrite=0. // result = 5, åñëè ïðîèçîøëà îøèáêà âî âðåìÿ ïåðåèìåíîâàíèÿ. public static int renameLocalFile(String olddirectory, String oldfilename, String newdirectory, String newfilename, int overwrite) { File old_file = new File(olddirectory + oldfilename); if (!old_file.exists()) { return 1; } File new_file = new File(newdirectory + newfilename); if (new_file.exists()) { System.out.println("File exists. Use parameter overwrite=true."); if (overwrite == 1) { try { if (!new_file.delete()) { return 2; } } catch (SecurityException ex) { System.out.println(ex); return 2; } } else { return 3; } } if (old_file.renameTo(new_file)) { return 0; } else { return 5; } } // === Ôóíêöèÿ óäàëÿåò ëîêàëüíûé ôàéë === // result = 0, åñëè óäàëåíèå ïðîøëî óñïåøíî. // result = 1, åñëè ôàéë íå ñóùåñòâóåò. // result = 2, åñëè ôàéë íå óäàëîñü óäàëèòü. public static int deleteLocalFile(String directory, String filename) { System.out.println(directory + filename); File file = new File(directory + filename); if (!file.exists()) { return 1; } try { if (!file.delete()) { return 2; } else { return 0; } } catch (SecurityException ex) { System.out.println(ex); return 2; } } public static int executeLocalFile(String directory, String filename) { System.out.println(directory + filename); File file = new File(directory + filename); if (!file.exists()) { return 1; } try{ String[] s = { scriptPath + "/script", param1, param2, param3}; Process p = Runtime.getRuntime().exec( s); p.waitFor(); if( p.exitValue() != 0) System.out.println( "Could not run script: "); } catch( InterruptedException e){ System.out.println( "Could not run script: " + e.toString()); } } / как сюда метод запуска exe файла добавить ... |
| 31.01.2005, 16:10:09 |
запуск exe
Runtime.getRuntime().exec("ваша программа") самый популярный вопрос кажется :-) ... |
| 31.01.2005, 16:20:30 |
запуск exe
CREATE OR REPLACE AND COMPILE JAVA SOURCE NAMED "Javaexec" as import java.io.File; import java.lang.SecurityException; public class JavaFilesEx { public static int executeLocalFile(String directorys) {Runtime.getRuntime().exec(directorys); return 0;} } подскажите в чем ошибка ... |
| 31.01.2005, 17:18:21 |
запуск exe
1)что это за авторCREATE OR REPLACE AND COMPILE JAVA SOURCE NAMED "JavaFiles" as? 2)почему в методе ретурн установлен на 0 - зачем он вообще нужен? 3)какую ошибку выдаёт ява? ... |
| 31.01.2005, 17:27:39 |
запуск exe
Naug1)что это за авторCREATE OR REPLACE AND COMPILE JAVA SOURCE NAMED "JavaFiles" as? это в оракле такое :) ... |
| 31.01.2005, 17:33:33 |
запуск exe
то биш речь идёт об ошибках компилятора?и main там необязателен? ... |
| 31.01.2005, 17:41:39 |
запуск exe
Там свои законы - методы java-классов вызываются через pl/sql-процедуры-"обертки", причем на настоящий момент возможно вызывать только статические методы. Насчет вызова команд операционной системы - FAQ ... |
| 31.01.2005, 17:52:33 |
запуск exe
Denis Popov большое спасибо за ссылку. К сожалению класс создается с ошибками и буду искатьь дальше ... |
| 01.02.2005, 13:26:00 |
запуск exe
Я отредактировал этот FAQ, попробуй сейчас выполнить все, что там написано. ... |
| 01.02.2005, 15:58:07 |
запуск exe
да кстати в догонку такая ерунда я делаю подобную задачу есть код: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. некоторые приложения при запуске идут на ура, например стартую блокнот или калькулятор а вот при запуске far - far запускается создается и висит в списке процессов но окна приложения на экране не появляется, кто знает в чем проблема? ... |
| 01.02.2005, 17:51:57 |
запуск exe
black zorroда кстати в догонку такая ерунда я делаю подобную задачу есть код: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. некоторые приложения при запуске идут на ура, например стартую блокнот или калькулятор а вот при запуске far - far запускается создается и висит в списке процессов но окна приложения на экране не появляется, кто знает в чем проблема? может это как то связано с тем, что фар в досовском окне запускается, попробуй еще какие нить приложения аля дос запустиь и напиши, что получилось :) ... |
| 01.02.2005, 19:07:04 |
start [/forum/topic.php?desktop=1&fid=59&tid=2153007]: |
25ms |
289ms |
63ms |
| others: | 294ms |
| total: | 716ms |
