Hibernate 2.1 Get Up And Running Quick [readme.txt]
собираем Hibernate 2.1.7 правим батник и запускаем - java -version java version "1.5.0" Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0-b64) Java HotSpot(TM) Client VM (build 1.5.0-b64, mixed mode, sharing) - получаю красивые ошибки - compile: [javac] Compiling 491 source files to C:\webs\hibernate-2.1\build\classes [javac] C:\webs\hibernate-2.1\src\net\sf\hibernate\Hibernate.java:188: as of release 1.5, 'enum' is a keyword, and may not be used as an identifier [javac] (try -source 1.4 or lower to use 'enum' as an identifier) [javac] public static Type enum(Class enumClass) throws MappingException { [javac] ^ [javac] C:\webs\hibernate-2.1\src\net\sf\hibernate\impl\AbstractQueryImpl.ja va:246: as of release 1.5, 'enum' is a keyword, and may not be used as an identi fier [javac] (try -source 1.4 or lower to use 'enum' as an identifier) [javac] setParameter( position, val, Hibernate.enum( val.getClas s() ) ); [javac] ^ [javac] C:\webs\hibernate-2.1\src\net\sf\hibernate\impl\AbstractQueryImpl.ja va:306: as of release 1.5, 'enum' is a keyword, and may not be used as an identi fier [javac] (try -source 1.4 or lower to use 'enum' as an identifier) [javac] setParameter( name, val, Hibernate.enum( val.getClass() ) ); [javac] ^ [javac] C:\webs\hibernate-2.1\src\net\sf\hibernate\type\TypeFactory.java:169 : as of release 1.5, 'enum' is a keyword, and may not be used as an identifier [javac] (try -source 1.4 or lower to use 'enum' as an identifier) [javac] type = Hibernate.enum(typeClass) ; [javac] ^ [javac] 4 errors BUILD FAILED file:C:/webs/hibernate-2.1/build.xml:158: Compile failed; see the compiler error output for details. - Что посоветуете, господа? Взять версию hibernate посвежее? Либо сменить JDK? Либо оторвать руки и не подпускать к hibernate. -- Заранее благодарен. -- интересно у вас тут ... |
| 15.03.2005, 13:00:31 |
Niemi -- интересно у вас тут ога. тебе же компилятор пишет: "-source 1.4". вот и поставь это параметр при вызове javac ... |
| 15.03.2005, 13:09:49 |
я бы поставил параметр, но видимо не так хорошо знаю где в build.xml это надо прописать. -- интересно у вас тут ... |
| 15.03.2005, 13:19:42 |
там где <javac ...>...</javac> добавить атрибут к этому тэгу: <javac source="1.4" ...>...</javac> ... |
| 15.03.2005, 13:25:57 |
дежавю там где <javac ...>...</javac> добавить атрибут к этому тэгу: <javac source="1.4" ...>...</javac> Благодарю, всё отлично завершилось, попробуем далее :) -- интересно у вас тут ... |
| 15.03.2005, 13:30:40 |
start [/forum/topic.php?desktop=1&fid=59&tid=2152811]: |
28ms |
49ms |
67ms |
| others: | 302ms |
| total: | 501ms |
