JDeveloper теперь можно использовать бесплатно
Подробности тут ... |
| 28.06.2005, 14:19:19 |
а на чем он основан? ... |
| 28.06.2005, 14:40:52 |
в своевремя Оракл купила лтцнзию у Borland это не Эклипс ... |
| 28.06.2005, 14:48:20 |
Ага, бесплатно. Для тех кто заплатил за техподдержку и за лицензию OAS. Если я не ошибаюсь, Oracle JDeveloper = Borland JBuilder + Oracle ADF ... |
| 28.06.2005, 15:13:54 |
теперь за техподдержу платить не надо http://www.theserverside.com/news/thread.tss?thread_id=34781 Does this mean that JDeveloper will be free? As in I a can download it, install it on 10 machines, and use it to develop production applications. All for $0.If so then Great! I like Jdeveloper and as of 9.0.5.2 I think it is a quality IDE. Yep. Totally free. Install it on ten machines, twenty machines... Go wild. And thanks for the compliment! Michael O'Neill Product Director, Oracle Our involvement with Eclipse and MyFaces is actually about advancing the use of JavaServer Faces. We want JSF to succeed, and the best way to guarantee that is to a) help ensure the success of the leading open source JSF implementation, and b) provide JSF tooling for Eclipse. It's really a continuation of our prior involvement with Eclipse for EJB 3.0 tooling. Final note: as someone suggested in an earlier post, JDeveloper is more than just a Java IDE. In addition to the PL/SQL development tools he talked about, JDeveloper includes UML modeling, code analysis, code optimization, BPEL process modeling, and visual editors for JSPs, HTML, Swing, JSF and Struts, plus portlet, web service and XML development. You should take a look. Michael O'Neill Product Director, Oracle >Oracle JDeveloper = Borland JBuilder + Oracle ADF не совсем забавно у него собвстенный java копилятор ojc наз ... |
| 28.06.2005, 15:21:40 |
И все же (поправьте меня если я неправ): бесплатно только до тех пор, пока приложения деплоятся на OAS (который не бесплатен), а если захотите еще куда (к примеру на JBoss) -- платите денежки за ADF runtime. ... |
| 28.06.2005, 15:46:06 |
Mike, is standalone OC4J free for development purposes as well? Answering for Mike from another Mike: OC4J is as you know, embedded in JDeveloper, so within that context is useable according to the licensing of JDeveloper. But you are not licensed for OC4J Stand-alone, you are licensed to use JDeveloper. If you want to use OC4J independent of JDeveloper - i.e. Standalone OC4J - you have two options: 1. For development, prototyping etc, you can download it from OTN subject to the OTN licensing terms ... which essentially is that you have a full use license for development purposes though if you weed through the legalese there are some restrictions. 2. If you deploy it in a production environment, OC4J is a fully supported production product and can be licensed. The way you license it is you buy the Oracle Application Server Java Edition, which grants you a license to deploy OC4J in a production environment. The changes that you are reading here about JDeveloper do not in any way change the licensing of OC4J Stand-Alone. Hope this helps. Mike Lehmann (Product Management for OC4J) ... |
| 28.06.2005, 15:47:53 |
АБИ все же (поправьте меня если я неправ): бесплатно только до тех пор, пока приложения деплоятся на OAS (который не бесплатен), а если захотите еще куда (к примеру на JBoss) -- платите денежки за ADF runtime.Я даже поправлять не буду. Средство разработки JDeveloper Вы можете использовать без приобретения лицензии. Политика относительно других продуктов Oracle (Oracle RDBMS, OracleAS, Oracle EBS итд) остаётся прежней - покупайте лицензии. ... |
| 28.06.2005, 15:49:23 |
как видишь с точки зрения лицензий вопросов много jDeveloper имеет смысл использовать в свзяке с Ораклом есле у вас есть лицензия на Оракл , то я думаю лицензия на bc4j точно будет ;-) ... |
| 28.06.2005, 15:49:55 |
OC4j сам J2EE сервер ... |
| 28.06.2005, 15:55:36 |
manschкак видишь с точки зрения лицензий вопросов много jDeveloper имеет смысл использовать в свзяке с Ораклом есле у вас есть лицензия на Оракл , то я думаю лицензия на bc4j точно будет ;-)Ты различай разработку и эксплуатацию. :-) ... |
| 28.06.2005, 15:56:46 |
выдержу я привел ... |
| 28.06.2005, 15:58:09 |
manschвыдержу я привелмолодец ... |
| 28.06.2005, 16:00:37 |
ты к стати с BC работаешь? ... |
| 28.06.2005, 16:01:31 |
manschты к стати с BC работаешь?Сейчас нет. Курс вроде бы по ним даже читал в Минске. И экзамен сдавал. ... |
| 28.06.2005, 16:07:33 |
просто проблемы как нормально обрабатывать нажатие Cancel у меня page flow сначала создаю записб а потом либо заполяню ее данными либо делаю Cancel а при нажатии на Cancel зарись сохраяеться в РекордСете дерьмо - ее нужно руками чистить ... |
| 28.06.2005, 16:09:07 |
manschпросто проблемы как нормально обрабатывать нажатие Cancelчуть попозже отвечу. сейчас отвлекли ... |
| 28.06.2005, 16:14:22 |
у меня слишкмо сложное решение получилось - я посомтрел как организовано adftoystore и у меня получилось 1 на уровне ApplicationModule Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. Код: plaintext 1. 2. 3. 4. 5. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. а действие очень простое - Cancel ... |
| 28.06.2005, 16:19:51 |
manschуж очень сложно а действие очень простое - CancelБоюсь, что это правильный вариант. В самих BC4J (а ты с ними напрямую и работаешь) поддержки вложенных транзакций нет, а у тебя фактически получается, что ты хочешь в рамках основной транзакции провернуть вложенную, которая состоит из двух действий и должна закончиться либо update-ом либо cancel-ом. ... |
| 28.06.2005, 17:56:05 |
сначала я вообще Rollback делал но он все кеши очищаеи и обнуляет Рекордсет - то есть по нажатию на cancek я вообще черте куда переходил пришло отказаться ... |
| 28.06.2005, 17:58:23 |
не обнуляет , а переходит на 1-ую запись но все равно - я считаю что это ошибка и писал Мюнеху ... |
| 28.06.2005, 18:00:41 |
start [/forum/topic.php?desktop=1&fid=59&tid=2151790]: |
46ms |
90ms |
| others: | 345ms |
| total: | 537ms |
