Как в JPanel вывести (нарисовать) имадж?
<subj> спасиба! ... |
| 04.09.2005, 19:46:17 |
на всю Jpanel ? ... |
| 05.09.2005, 11:32:33 |
Самый примитивный способ - это кинуть на нее JLabel, а лейблу назначить иконку. ... |
| 05.09.2005, 11:36:56 |
Cпасиба. А как потом поверх этого имаджа, в той же панели, наложить наверх, другие имаджи? ... |
| 05.09.2005, 11:57:20 |
int width = 100; int height = 100; // Create buffered image that does not support transparency BufferedImage bimage = new BufferedImage(width, height, BufferedImage.TYPE_INT_RGB); // Create a buffered image that supports transparency bimage = new BufferedImage(width, height, BufferedImage.TYPE_INT_ARGB); These examples create buffered images that are compatible with the screen: GraphicsEnvironment ge = GraphicsEnvironment.getLocalGraphicsEnvironment(); GraphicsDevice gs = ge.getDefaultScreenDevice(); GraphicsConfiguration gc = gs.getDefaultConfiguration(); // Create an image that does not support transparency bimage = gc.createCompatibleImage(width, height, Transparency.OPAQUE); // Create an image that supports transparent pixels bimage = gc.createCompatibleImage(width, height, Transparency.BITMASK); // Create an image that supports arbitrary levels of transparency bimage = gc.createCompatibleImage(width, height, Transparency.TRANSLUCENT); A screen compatible buffered image can also be created from a graphics context: public void paint(Graphics g) { Graphics2D g2d = (Graphics2D)g; int width = 100; int height = 100; // Create an image that does not support transparency BufferedImage bimage = g2d.getDeviceConfiguration().createCompatibleImage( width, height, Transparency.OPAQUE); // Create an image that supports transparent pixels bimage = g2d.getDeviceConfiguration().createCompatibleImage( width, height, Transparency.BITMASK); // Create an image that supports arbitrary levels of transparency bimage = g2d.getDeviceConfiguration().createCompatibleImage( width, height, Transparency.TRANSLUCENT); } ... |
| 05.09.2005, 12:11:32 |
start [/forum/topic.php?desktop=1&fid=59&tid=2151585]: |
26ms |
62ms |
70ms |
| others: | 343ms |
| total: | 546ms |
