связка Apache с Tomcat
Привет! Пытаюсь связать Apache c Tomcat. Дистрибутив - Debian. Скачал и установил пакет libapache2-mod-jk2_2.0.4-1_i386.deb. При старте или перезапуске apache валится ошибка: Syntax error on line 10 of /etc/apache2/httpd.conf: Can't locate API module structure 'jk_module' in file /usr/lib/apache2/modules/mod_jk2.so: /usr/lib/libapr-0.so.0: undefined symbol: jk_module. C apache работаю впервые. Просьба сильно не пинать. Заранее спасибо. httpd.conf: # Load mod_jk module # Update this path to match your modules location LoadModule jk_module /usr/lib/apache2/modules/mod_jk2.so # Declare the module for <IfModule directive> (remove this line on Apache 2.x) AddModule mod_jk.c # Where to find workers.properties # Update this path to match your conf directory location (put workers.properties next to httpd.conf) JkWorkersFile /etc/apache2/workers.properties # Where to put jk logs # Update this path to match your logs directory location (put mod_jk.log next to access_log) JkLogFile /var/log/httpd/mod_jk.log # Set the jk log level [debug/error/info] JkLogLevel info # Select the log format JkLogStampFormat "[%a %b %d %H:%M:%S %Y] " # JkOptions indicate to send SSL KEY SIZE, JkOptions +ForwardKeySize +ForwardURICompat -ForwardDirectories # JkRequestLogFormat set the request format JkRequestLogFormat "%w %V %T" # Send everything for context /examples to worker named worker1 (ajp13) JkMount /examples/* worker1 ... |
| 06.09.2005, 12:01:11 |
Был установлен mod_jk2, а настройки для mod_jk надо или настройки поменять, или модуль установить mod_jk Димыч ... |
| 06.09.2005, 12:13:14 |
start [/forum/topic.php?desktop=1&fid=59&tid=2151574]: |
23ms |
42ms |
44ms |
| others: | 313ms |
| total: | 471ms |
