BEA Workshop 3.0 вышел.
http://dev2dev.bea.com/blog/wgroth2/archive/2005/11/the_blended_dev_1.html BEA Workshop 3.0 makes use of our acquisition of M7 to provide tooling support for major open source frameworks like: Struts JavaServer Faces Spring (through the use of Spring IDE via separate download) Hibernate (through BEA Workshop ORM functionality) So What's News? There are are two main things to pay attention to in this release. First, we are adding support for WebLogic Server 9.0. This means we now support the following environments: WebLogic 9.0 & 8.1 JBoss Tomcat Jetty WebSphere Resin The key thing to note is that BEA is supporting the deployment of applications to other application servers. In our view, this offers customers an important option. When a customer's application begins scale up, many times the open source application containers do not offer the reliability, scalability, and manageability that WebLogic Server does. BEA Workshop provides a very clean and simple way to migrate web applications from these containers to an industrial-strength environment provided by WebLogic Server 9.0. The second thing to pay attention to is that by supporting other servers and open source frameworks, BEA intends to provide tools to developers beyond just J2EE developers, and someday perhaps beyond even the Java language. We have also dropped the "WebLogic" from the Workshop name. This is for two reasons: First, we now support other containers. Second, the Eclipse framework will be the basis for our rich client tools across product lines. Blended Development The notion of the Blended Environment is one that is firmly based in Joy's Law, which loosely paraphrased is "Most of the smart people don't work for you." (This is also rendered more elegantly "Innovation happens elsewhere"). For many reasons, there is a huge spike in the innovation in both languages and frameworks. Most of these are open source. Languages include Perl, PHP, Python and Ruby. Frameworks include the ones mentioned above. I believe this is happening mainly because innovation happens in waves. Consider that there was some ground-breaking work on programming languages done in 1967-1973, namely C and Simula. IBM had PL/1 and derivatives at this time. Then things stabilized for a while until the 80s and early 90s, when object-oriented languages like C++, Smalltalk, Objective-C. Then the dust settled from the language wars, the dominant languages were C++ and Java. After several years of working with these languages, it became clear there had to be an easier way to build web applications. It started with CGI scripts written in Perl, which gave rise to PHP. Python, one of the first OO scripting languages was given new life by this new paradigm. There are also new languages on the horizon generating great interest, Ruby. It is safe to say that no one can predict what the next hot framework will be, but our new strategy allows us to be ready for it. скачать ... |
| 09.11.2005, 09:35:56 |
Кто скачивал? "BEA Workshop Studio 3.0", он Eclipse based? ... |
| 09.11.2005, 10:55:37 |
privateКто скачивал? "BEA Workshop Studio 3.0", он Eclipse based?да ... |
| 09.11.2005, 11:00:54 |
тэкс... скачал. размер > 120 мегабайт. это BEA Workshop™ Studio (типа полный набор всего) распаковал. получил два файла: WorkshopInstaller.exe installer.properties стало интересно, а что внутри installer.properties? посмотрел. а вот что: Код: plaintext 1. 2. конечно же я сразу поменял значение prop с "0005-trial" на "0005". запустил инсталлятор. ничо. запустился. немножко стало смешно. Congratulations! Workshop Studio has been successfully installed хорошо. запускаю. опа: Please activate your Workshop license by entering the Order Id and Serial Number you received in the activation email and click Activate. If you did not receive or can not find your activation email, please contact support@m7.com for assistance. а мыло с активацией чето так и не пришло. :) ... |
| 09.11.2005, 12:02:14 |
start [/forum/topic.php?desktop=1&fid=59&tid=2151021]: |
50ms |
62ms |
| others: | 334ms |
| total: | 518ms |
