deprecated NameValuePair
[javac] /home/oracle/.../d-Source/java/com/.../presentation/common/HelpSupportContainerRenderer.java:42: cannot resolve symbol [javac] symbol : method constructLink (oracle.portal.provider.v2.render.PortletRenderRequest,java.lang.String,oracle.portal.utils.NameValue[],boolean,boolean) [javac] location: class oracle.portal.provider.v2.url.UrlUtils [javac] UrlUtils.constructLink( Заменили NameValuePair на NameValue UrlUtils.constructHTMLLink на rlUtils.constructLink , как советуют, получили error, что не ТАК? This class has been replaced with NameValue which is in an unversioned package. The functionality of the replacement is identical. Стало Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. ... |
| 22.11.2005, 14:46:01 |
start [/forum/search_topic.php?author=DKspider&author_mode=last_posts&do_search=1]: |
23ms |
23ms |
38ms |
57ms |
| others: | 683ms |
| total: | 891ms |
