Tomcat 3.2.4, Struts, JSF
Добрый день. Кто-нибудь пытался юзать Struts с ТомКатом 3.2.4? У меня постоянно ошибки вылетают. Если использовать примеры Стратсовые, то 16.12.2005 12:51:37 org.apache.struts.util.MessageResourcesFactory createFactory SEVERE: MessageResourcesFactory.createFactory java.lang.ClassNotFoundException: org.apache.struts.util.PropertyMessageResourcesFactory at java.net.URLClassLoader$1.run(URLClassLoader.java:199) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:187) at java.lang.ClassLoader.loadClass(ClassLoader.java:289) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274) at java.lang.ClassLoader.loadClass(ClassLoader.java:235) at org.apache.struts.util.RequestUtils.applicationClass(RequestUtils.java:119) at org.apache.struts.util.MessageResourcesFactory.createFactory(MessageResourcesFactory.java :150) at org.apache.struts.util.MessageResources.getMessageResources(MessageResources.java:495) at org.apache.struts.action.ActionServlet.initInternal(ActionServlet.java:1013) at org.apache.struts.action.ActionServlet.init(ActionServlet.java:322) at javax.servlet.GenericServlet.init(GenericServlet.java:258) at org.apache.tomcat.core.ServletWrapper.doInit(ServletWrapper.java:317) at org.apache.tomcat.core.Handler.init(Handler.java:215) at org.apache.tomcat.core.ServletWrapper.init(ServletWrapper.java:296) at org.apache.tomcat.context.LoadOnStartupInterceptor.contextInit(LoadOnStartupInterceptor.j ava:130) at org.apache.tomcat.core.ContextManager.initContext(ContextManager.java:491) at org.apache.tomcat.core.ContextManager.init(ContextManager.java:453) at org.apache.tomcat.startup.Tomcat.execute(Tomcat.java:195) at org.apache.tomcat.startup.Tomcat.main(Tomcat.java:240) cannot load servlet name: action: null А если JSF, то XmlMapper: Can't find resource for entity: -//Sun Microsystems, Inc.//DTD Web Application 2.3//EN -- > http://java.sun.com/dtd/web-app_2_3.dtd "null" Хотя под TomCat 5 всё нормально работает. Подскажите, пожалуйста, в чём может быть проблема? ... |
| 16.12.2005, 12:50:10 |
start [/forum/topic.php?desktop=1&fid=59&tid=2150663]: |
60ms |
64ms |
| others: | 389ms |
| total: | 587ms |
