Проблемы соединения с MySQL
Пытаюсь соединиться с MySQL 5.0.16 через Connector/J 3.1.12. #java --version java version "1.4.2" gij (GNU libgcj) version 4.0.0 20050519 (Red Hat 4.0.0-8) Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. Компилирую. При попытке запуска выдаёт следующее: Found: com.mysql.jdbc.Driver@492f8 SQLException: Error during query: Unexpected Exception: java.io.CharConversionException message given: null Nested Stack Trace: ** BEGIN NESTED EXCEPTION ** java.io.CharConversionException STACKTRACE: java.io.CharConversionException at gnu.gcj.convert.Input_iconv.read(char[], int, int) (/usr/lib/libgcj.so.6.0.0) at java.lang.String.init(byte[], int, int, java.lang.String) (/usr/lib/libgcj.so.6.0.0) at java.lang.String.String(byte[], int, int, java.lang.String) (/usr/lib/libgcj.so.6.0.0) at com.mysql.jdbc.SingleByteCharsetConverter.SingleByteCharsetConverter(java.lang.String) (Unknown Source) at com.mysql.jdbc.SingleByteCharsetConverter.initCharset(java.lang.String) (Unknown Source) at com.mysql.jdbc.SingleByteCharsetConverter.getInstance(java.lang.String, com.mysql.jdbc.Connection) (Unknown Source) at com.mysql.jdbc.StringUtils.getBytes(java.lang.String, java.lang.String, java.lang.String, boolean) (Unknown Source) at com.mysql.jdbc.ByteArrayBuffer.writeStringNoNull(java.lang.String, java.lang.String, java.lang.String, boolean) (Unknown Source) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(com.mysql.jdbc.Statement, java.lang.String, java.lang.String, com.mysql.jdbc.Buffer, int, com.mysql.jdbc.Connection, int, int, boolean, java.lang.String, boolean) (Unknown Source) at com.mysql.jdbc.Connection.execSQL(com.mysql.jdbc.Statement, java.lang.String, int, com.mysql.jdbc.Buffer, int, int, boolean, boolean, java.lang.String, boolean, byte, boolean) (Unknown Source) at com.mysql.jdbc.Connection.configureClientCharacterSet() (Unknown Source) at com.mysql.jdbc.Connection.initializePropsFromServer(java.util.Properties) (Unknown Source) at com.mysql.jdbc.Connection.createNewIO(boolean) (Unknown Source) at com.mysql.jdbc.Connection.Connection(java.lang.String, int, java.util.Properties, java.lang.String, java.lang.String, com.mysql.jdbc.NonRegisteringDriver) (Unknown Source) at com.mysql.jdbc.NonRegisteringDriver.connect(java.lang.String, java.util.Properties) (Unknown Source) at java.sql.DriverManager.getConnection(java.lang.String, java.util.Properties) (/usr/lib/libgcj.so.6.0.0) at java.sql.DriverManager.getConnection(java.lang.String) (/usr/lib/libgcj.so.6.0.0) at JT.main(java.lang.String[]) (Unknown Source) at gnu.java.lang.MainThread.call_main() (/usr/lib/libgcj.so.6.0.0) at gnu.java.lang.MainThread.run() (/usr/lib/libgcj.so.6.0.0) ** END NESTED EXCEPTION ** SQLState: S1000 VendorError: 0 Причём если подставить неправильный логин/пароль/база выдаёт "Access denied". То есть соединение всё-таки происходит, но не до конца. Пробовал указывать collationEncoding и charsetEncoding - не помогло. (Пробовал windows-1251(cp1251) и UTF-8) ... |
| 09.01.2006, 14:38:05 |
Проблема не решена, но можно закрыть. Запустил этот же класс под WinXP. Получил кучу ошибок, которые Caused by: java.lang.RuntimeException: Unable to initialize character set mapping tables at com.mysql.jdbc.CharsetMapping.<clinit>(CharsetMapping.java:73) Выяснилось, что мне сюда http://bugs.mysql.com/bug.php?id=14938. Думаю под Linux`ом причина та же. ... |
| 09.01.2006, 17:40:48 |
Код: plaintext 1. если jdbc:mysql://localhost:3306/test все ОК! ... |
| 10.01.2006, 20:27:15 |
start [/forum/topic.php?desktop=1&fid=59&tid=2150514]: |
65ms |
63ms |
| others: | 353ms |
| total: | 559ms |
