JSF: Совместное использование RI и Томогавк
Здравствуйте. Собственно, можно ли так делать? Например использовать компоненты от Sun и при этом jsCookMenu? ... |
| 31.01.2006, 15:28:44 |
Можно, взято отсюда Requirements and Setup * Put the tomahawk.jar in your WEB-INF/lib directory (or in the classpath of your application server.) Note If you are using the MyFaces implementation you can choose to use the myfaces-all.jar instead. It is basically a single jar file containing the JSF 1.1 API, JSF 1.1 Implementation and the MyFaces custom components. * Install the MyFaces Extensions filter * Add the following to your JSP page in order to use one of the MyFaces custom components: <%@ taglib uri="http://myfaces.apache.org/tomahawk" prefix="t"%> * That's it! You're good to go. Please see additional documentation for specific issues regarding the MyFaces API and implementation packages. ... |
| 01.02.2006, 06:23:01 |
start [/forum/topic.php?desktop=1&fid=59&tid=2150256]: |
51ms |
67ms |
| others: | 364ms |
| total: | 564ms |
