Помогите разобраться
Из вопроса, думаю понятно что с явой я плохо или вообще не знаком. Решил значит я подключиться к Ораклу. Добавляю КлассПасс java -classpath "C:\oracle\product\10.1.0\Client_1\jdbc\lib\ojdbc14.jar" Далее пишу код try { System.setProperty("jdbc.drivers","oracle.jdbc.driver.OracleDriver"); l_User = "user"; l_password = "password"; l_url = "jdbc:oracle:thin:ORCL"; Conn = DriverManager.getConnection(l_url, l_User,l_password); } catch (SQLException e) { e.printStackTrace(); } При выполниии у меня ошибка java.sql.SQLException: No suitable driver at java.sql.DriverManager.getConnection(DriverManager.java:545) at java.sql.DriverManager.getConnection(DriverManager.java:171) at DBObject.TOracleConection.<init>(TOracleConection.java:42) at DBMove.TMainForm.btn_OKMouseClicked(TMainForm.java:227) at DBMove.TMainForm.access$000(TMainForm.java:18) at DBMove.TMainForm$1.mouseClicked(TMainForm.java:78) at java.awt.AWTEventMulticaster.mouseClicked(AWTEventMulticaster.java:212) at java.awt.Component.processMouseEvent(Component.java:5491) at javax.swing.JComponent.processMouseEvent(JComponent.java:3126) at java.awt.Component.processEvent(Component.java:5253) at java.awt.Container.processEvent(Container.java:1966) at java.awt.Component.dispatchEventImpl(Component.java:3955) at java.awt.Container.dispatchEventImpl(Container.java:2024) at java.awt.Component.dispatchEvent(Component.java:3803) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4212) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3901) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3822) at java.awt.Container.dispatchEventImpl(Container.java:2010) at java.awt.Window.dispatchEventImpl(Window.java:1774) at java.awt.Component.dispatchEvent(Component.java:3803) at java.awt.EventQueue.dispatchEvent(EventQueue.java:463) at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149) at java.awt.EventDispatchThread.run(EventDispatchThread.java:110) Причем из среды(Есть там возможность выполнять запросы к БД ) Net Beans К ораклу идет коннект. Вопрос что я делаю не так. И Второй Как мне посмотреть содержтмое classpath ... |
| 10.03.2006, 08:39:32 |
добавь перед DriverManager.getConnection следующую строку: Class.forName("oracle.jdbc.driver.OracleDriver") а System.setProperty убери. ... |
| 10.03.2006, 09:09:36 |
Код: plaintext 1. 2. 3. 4. ... |
| 10.03.2006, 09:14:49 |
Пробовал не помогает. Ловит Эксепшен, что класс не найден. Я думаю что то не так с classpath, хотя могу ошибаться ... |
| 10.03.2006, 09:28:17 |
evg_pЯ думаю что то не так с classpath факт. накой ляд там кавычки стаят """???? ... |
| 10.03.2006, 13:31:40 |
expp evg_pЯ думаю что то не так с classpath факт. накой ляд там кавычки стаят """???? Пробовал я и без кавычек :-) ... |
| 10.03.2006, 14:24:23 |
start [/forum/topic.php?desktop=1&fid=59&tid=2149964]: |
56ms |
63ms |
| others: | 335ms |
| total: | 525ms |
