Форумы / Java [игнор отключен] [закрыт для гостей] / Проблемы с RMI: Серверу требуется класс вместо интерфейса
2 сообщений из 2, страница 1 из 1
    #33643621
K1RUHA
Здравствуйте.
Начну с кода:
EquationI:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
 package  kazakevich;
 import  java.rmi.Remote;
 import  java.rmi.RemoteException;
/** Implementing this interface allows you to obtain access to solve an equation.
 * @version 1.0
 * @author Kirill Kazakevich
 public   interface  EquationI  extends  Remote{
     * @param function function that imlements interface FunctionI
     * @param a begin of a segment
     * @param b end of a segment
     * @param eps fault
     * @return root of an equation
     * @throws RemoteException
     double  solve(FunctionI function,  double  a,  double  b,  double  eps)  throws  RemoteException;
EquationServer:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
 package  kazakevich;
 import  java.math.BigDecimal;
 import  java.net.MalformedURLException;
 import  java.rmi.Naming;
 import  java.rmi.RMISecurityManager;
 import  java.rmi.registry.LocateRegistry;
 import  java.rmi.server.UnicastRemoteObject;
 * Server.
 * Server waits for clients to solve an equation and returns a solution.
 * @version 1.0
 public   class  EquationServer  extends  UnicastRemoteObject  implements  EquationI{
     public  EquationServer()  throws  RemoteException{
     public   double  solve(FunctionI function,  double  a,  double  b,  double  eps)  throws  RemoteException{
	 double  m = (a + b) /  2 ;
	 double  fa = function.f(a);
	 double  fm = function.f(m);
	 double  product = fa * fm;
	 if ((b - a) <= eps || product ==  0 ){
	    BigDecimal epss =  new  BigDecimal(eps);
	    System.out.println(epss.scale());
	     return  m;
	 return  product <  0  ? solve(function, a, m, eps) : solve(function, m, b, eps);
     * @param args
     * @throws MalformedURLException
     public   static   void  main(String[] args)  throws  RemoteException, MalformedURLException{
	System.setSecurityManager( new  RMISecurityManager());
	EquationServer server =  new  EquationServer();
	LocateRegistry.createRegistry( 1099 );
	Naming.rebind("EServer", server);
	System.out.println("Server is waiting for clients.");
EquationClient:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
 package  kazakevich;
 import  java.rmi.NotBoundException;
 * Client.
 * Client connects to server to solve an equation.
 * @version 1.0
 public   class  EquationClient{
     * @param args
     * @throws NotBoundException
     public   static   void  main(String[] args)  throws  NotBoundException, MalformedURLException, RemoteException{
	FuncA a =  new  FuncA();
	EquationI server = (EquationI)Naming.lookup("EServer");
	System.out.println("The root of an equation is " + server.solve(a,  1 . 0 ,  1 . 7 ,  0 . 01 ));
FunctionI
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
 package  kazakevich;
 * Implementing this interface allows you to store a formula of f(<i>x</i>)
 * @version 1.0
 public   interface  FunctionI{
    /** Calculate f(<i>x</i>).
     * @param x <i>x</i>
     * @return f(<i>x</i>)
     double  f( double  x);
FuncA
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
 package  kazakevich;
 import  java.io.Serializable;
/** Class stores formula of equation <code>x<sup>4</sup> - 2x - 4</code>.
 * @version 1.0
 public   class  FuncA  implements  FunctionI, Serializable{
     public   double  f( double  x){
	 double  result = Math.pow(x,  4 ) -  2 *x - 4 ;
	 return  result;
Программа вычисляет на сервере в методе solve корень уравнения f(x)=0 методом деления отрезка пополам. В метод solve передается ссылка на интерфейс FunctionI, реализация FuncA которого должна хранится у клиента, но если у сервера нету этого класса, то выдается исключение:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
Exception in thread main
java.rmi.ServerException: RemoteException occurred in server thread; nested exception is:
	java.rmi.UnmarshalException: error unmarshalling arguments; nested exception is:
	java.lang.ClassNotFoundException: kazakevich.FuncA
	at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java: 325 )
	at sun.rmi.transport.Transport$ 1 .run(Transport.java: 154 )
	at java.security.AccessController.doPrivileged( Native  Method)
	at sun.rmi.transport.Transport.serviceCall(Transport.java: 149 )
	at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java: 460 )
	at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java: 701 )
	at java.lang.Thread.run(Thread.java: 595 )
	at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java: 247 )
	at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java: 223 )
	at sun.rmi.server.UnicastRef.invoke(UnicastRef.java: 126 )
	at java.rmi.server.RemoteObjectInvocationHandler.invokeRemoteMethod(RemoteObjectInvocationHandler.java: 179 )
	at java.rmi.server.RemoteObjectInvocationHandler.invoke(RemoteObjectInvocationHandler.java: 132 )
	at $Proxy0.solve(Unknown Source)
	at kazakevich.EquationClient.main(EquationClient.java: 29 )
Caused by: java.rmi.UnmarshalException: error unmarshalling arguments; nested exception is:
	at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java: 285 )
Caused by: java.lang.ClassNotFoundException: kazakevich.FuncA
	at java.net.URLClassLoader$ 1 .run(URLClassLoader.java: 200 )
	at java.net.URLClassLoader.findClass(URLClassLoader.java: 188 )
	at java.lang.ClassLoader.loadClass(ClassLoader.java: 306 )
	at java.lang.ClassLoader.loadClass(ClassLoader.java: 251 )
	at java.lang.ClassLoader.loadClassInternal(ClassLoader.java: 319 )
	at java.lang. Class .forName0( Native  Method)
	at java.lang. Class .forName( Class .java: 242 )
	at sun.rmi.server.LoaderHandler.loadClass(LoaderHandler.java: 430 )
	at sun.rmi.server.LoaderHandler.loadClass(LoaderHandler.java: 165 )
	at java.rmi.server.RMIClassLoader$ 2 .loadClass(RMIClassLoader.java: 620 )
	at java.rmi.server.RMIClassLoader.loadClass(RMIClassLoader.java: 247 )
	at sun.rmi.server.MarshalInputStream.resolveClass(MarshalInputStream.java: 197 )
	at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java: 1538 )
	at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java: 1460 )
	at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java: 1693 )
	at java.io.ObjectInputStream.readObject0(ObjectInputStream.java: 1299 )
	at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 339 )
	at sun.rmi.server.UnicastRef.unmarshalValue(UnicastRef.java: 290 )
	at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java: 279 )
	...  6  more
Перепробовал уже кучу всего :( Может надо в java.policy что-нибудь прописать? Прописано только SocketPermission.
На всякий случай код в архиве.
    #33644278
Nefastus
Код: plaintext
1.
2.
 public   interface  FunctionI  extends  Remote {
     double  f( double  x)  throws  RemoteException;
Код: plaintext
1.
2.
3.
 public   class  FuncA   extends  UnicastRemoteObject  implements  FunctionI {
     public  FuncA()  throws  RemoteException {}
Дополнительно можете поискать на google rmi + callback.
