диалог always on top к родителю
Нужно создать диалог(не модальный), который бы always on top к родителю, т.е. диалог на переднем плане, а в основном окне можно что-нить менять. ... |
| 06.04.2006, 02:00:45 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. ... |
| 06.04.2006, 11:39:53 |
JDK 5.0 API setAlwaysOnTop public final void setAlwaysOnTop(boolean alwaysOnTop) throws SecurityException Changes the always-on-top window state. An always-on-top window is a window that stays above all other windows except maybe other always-on-top windows. If there are several always-on-top windows the order in which they stay relative to each other is not specified and is platform dependent. If some other window already is always-on-top then the relative order between these windows is unspecified (depends on platform). No window can be brought to be over always-on-top window except maybe another always-on-top window. All owned windows of an always-on-top window automatically become always-on-top windows. If a window ceases to be always-on-top its owned windows cease to be always-on-top. When an always-on-top window is sent toBack its always-on-top state is set to false. This method makes the window always-on-top if alwaysOnTop is true. If the window is visible, this includes bringing window toFront, then "sticking" it to the top-most position. If the window is not visible it does nothing other than setting the always-on-top property. If later the window is shown, it will be always-on-top. If the Window is already always-on-top, this call does nothing. If alwaysOnTop is false this method changes the state from always-on-top to normal. The window remains top-most but its z-order can be changed in the normal way as for any other window. Does nothing if this Window is not always-on-top. Has no effect on relative z-order of windows if there are no other always-on-top windows. Note: some platforms might not support always-on-top windows. There is no public API to detect if the platform supports always-on-top at runtime. If a SecurityManager is installed, the calling thread must be granted the AWTPermission "setWindowAlwaysOnTop" in order to set the value of this property. If this permission is not granted, this method will throw a SecurityException, and the current value of the property will be left unchanged. Parameters: alwaysOnTop - new value of always-on-top state of the window Throws: SecurityException - if the calling thread does not have permission to set the value of always-on-top property Since: 1.5 See Also: isAlwaysOnTop(), toFront(), toBack(), AWTPermission ... |
| 06.04.2006, 17:04:30 |
start [/forum/topic.php?desktop=1&fid=59&tid=2149678]: |
40ms |
49ms |
| others: | 299ms |
| total: | 453ms |
