ActiveX with Java!!!
Привет! Я сам вообще к JAVA отношения не имею. Нашел одну ссылку в интернете, возможно, будет интересна для участников данного форума: jacoZoom jacoZoom jacoZoom is a tool for programmers and not for end users! jacoZoom is a java class library which allows you to use ActiveX Controls and ActiveX Servers (COM/DCOM/Automation) with java. It is based on JNI and thus can be used with any java environment on the MS Windows platform. jacoZoom contains a typelibrary parser, which produces java wrapper classes directly corresponding to the COM-objects and interfaces. ... |
| 02.05.2006, 17:46:55 |
Ну и заодно: jadoZoom jadoZoom jadoZoom is a tool for programmers and not for end users! jadoZoom brings data sources with Ole DB -provider interfaces and those with ODBC-drivers to java programmers in 2 ways: Java classes for ADO JDBC driver The JDBC-Driver works with all databases with an OleDB-Provider or ODBC-Driver. It is optimized for MS Access and MS SQL Server , but can be used with lots of other databases, too. ... |
| 02.05.2006, 17:57:52 |
фи... JNI... ... |
| 02.05.2006, 20:21:47 |
start [/forum/topic.php?desktop=1&fid=59&tid=2149364]: |
41ms |
54ms |
| others: | 333ms |
| total: | 492ms |
