Помогите запустить sun Java Application Server
Установил Sun Java Studion Creator 2 Update 1 все замекчательно только не стартуется sun Java Application Server в лог выдает следующее [#|2006-05-04T01:41:31.821+0300|WARNING|sun-appserver-pe8.2|javax.enterprise.tools.launcher|_ThreadID=10;|LAUNCHER005:Spaces in your PATH have been detected. The PATH must be consistently formated (e.g. C:\Program Files\Java\jdk1.5.0\bin; ) or the Appserver may not be able to start and/or stop. Mixed quoted spaces in your PATH can cause problems, so the launcher will remove all double quotes before invoking the process. The most reliable solution would be to remove all spaces from your path before starting the Appservers components. |#] [#|2006-05-04T01:41:31.861+0300|INFO|sun-appserver-pe8.2|javax.enterprise.tools.launcher|_ThreadID=10;| C:/Sun/Creator2_1/java\bin\java -client -XX:PermSize=32m -XX:MaxPermSize=128m -XX:+CMSPermGenSweepingEnabled -XX:+CMSClassUnloadingEnabled -Xmx512m -XX:NewRatio=2 -Dcom.sun.aas.defaultLogFile=C:/Sun/Creator2_1/SunAppServer8/domains/creator/logs/server.log -Djava.endorsed.dirs=C:/Sun/Creator2_1/SunAppServer8/lib/endorsed -Djava.security.policy=C:/Sun/Creator2_1/SunAppServer8/domains/creator/config/server.policy -Djava.security.auth.login.config=C:/Sun/Creator2_1/SunAppServer8/domains/creator/config/login.conf -Dsun.rmi.dgc.server.gcInterval=3600000 -Dsun.rmi.dgc.client.gcInterval=3600000 -Djavax.net.ssl.keyStore=C:/Sun/Creator2_1/SunAppServer8/domains/creator/config/keystore.jks -Djavax.net.ssl.trustStore=C:/Sun/Creator2_1/SunAppServer8/domains/creator/config/cacerts.jks -Djava.ext.dirs=C:/Sun/Creator2_1/java/jre/lib/ext;C:/Sun/Creator2_1/SunAppServer8/domains/creator/lib/ext;C:/Sun/Creator2_1/SunAppServer8/derby/lib -Djdbc.drivers=org.apache.derby.jdbc.ClientDriver -Djavax.management.builder.initial=com.sun.enterprise.admin.server.core.jmx.AppServerMBeanServerBuilder -Dcom.sun.enterprise.config.config_environment_factory_class=com.sun.enterprise.config.serverbeans.AppserverConfigEnvironmentFactory -Dcom.sun.enterprise.taglibs=appserv-jstl.jar,jsf-impl.jar -Dcom.sun.enterprise.taglisteners=jsf-impl.jar -Djavax.xml.parsers.SAXParserFactory=com.sun.org.apache.xerces.internal.jaxp.SAXParserFactoryImpl -Dcom.sun.aas.configName=server-config -Dorg.xml.sax.parser=org.xml.sax.helpers.XMLReaderAdapter -Ddomain.name=creator -Djmx.invoke.getters=true -Djavax.xml.parsers.DocumentBuilderFactory=com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderFactoryImpl -Dcom.sun.aas.promptForIdentity=true -Dorg.xml.sax.driver=com.sun.org.apache.xerces.internal.parsers.SAXParser -Dcom.sun.aas.instanceRoot=C:/Sun/Creator2_1/SunAppServer8/domains/creator -Djavax.xml.transform.TransformerFactory=com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl -Dcom.sun.aas.domainName=creator -Djava.util.logging.manager=com.sun.enterprise.server.logging.ServerLogManager -Dproduct.name=Sun-Java-System/Application-Server -Dcom.sun.enterprise.overrideablejavaxpackages=javax.faces,javax.servlet.jsp.jstl,javax.xml.bind,javax.help -Dcom.sun.aas.configRoot=C:/Sun/Creator2_1/SunAppServer8/config -Djava.library.path=C:\Sun\Creator2_1\java\jre\bin\client;C:\Sun\Creator2_1\SunAppServer8\lib;C:\Sun\Creator2_1\SunAppServer8\lib;C:\Sun\Creator2_1\java\bin;.;C:\WINDOWS\System32;C:\WINDOWS;C:\Sun\Creator2_1\SunAppServer8\lib;C:\Sun\Creator2_1\SunAppServer8\bin;C:\Sun\Creator2_1\SunAppServer8\lib;C:\Sun\Creator2_1\SunAppServer8\bin;C:\Sun\Creator2_1\SunAppServer8\bin;C:\Sun\Creator2_1\SunAppServer8\bin;C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\Perl\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\JDK1.5.0_04\bin;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;c:\Archivators;C:\PROGRA~1\UACenter;C:\Python24;C:\Documents and Settings\yr\Desktop\pljava-i686-pc-mingw32-pg8.0-1.1.0;C:\Program Files\Common Files\GTK\2.0\bin;;c:\JDK1.5.0_04\bin;C:\Program Files\Sun\jstudio_ent8\AppServ8.1UR2\bin;C:\Program Files\Sun\jstudio_ent8\ide\uml1\modules\DoorsIntegrationFiles\modules\bin -Dcom.sun.aas.instanceName=server -Dcom.sun.aas.processLauncher=SE -cp C:/Sun/Creator2_1/java/lib/tools.jar;C:/Sun/Creator2_1/SunAppServer8/lib/appserv-rt.jar;C:/Sun/Creator2_1/SunAppServer8/lib\activation.jar;C:/Sun/Creator2_1/SunAppServer8/lib\admin-cli.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-admin.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-assemblytool_es.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-assemblytool_fr.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-assemblytool_ja.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-assemblytool_ko.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-assemblytool_zh.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-assemblytool_zh_CN.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp_es.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp_fr.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp_ja.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp_ko.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp_zh.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-cmp_zh_CN.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-env.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-ext.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-jstl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-rt_es.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-rt_fr.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-rt_ja.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-rt_ko.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-rt_zh.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-rt_zh_CN.jar;C:/Sun/Creator2_1/SunAppServer8/lib\appserv-upgrade.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher_es.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher_fr.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher_ja.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher_ko.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher_zh.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-launcher_zh_CN.jar;C:/Sun/Creator2_1/SunAppServer8/lib\commons-logging.jar;C:/Sun/Creator2_1/SunAppServer8/lib\deployhelp_es.jar;C:/Sun/Creator2_1/SunAppServer8/lib\deployhelp_fr.jar;C:/Sun/Creator2_1/SunAppServer8/lib\deployhelp_ja.jar;C:/Sun/Creator2_1/SunAppServer8/lib\deployhelp_ko.jar;C:/Sun/Creator2_1/SunAppServer8/lib\deployhelp_zh.jar;C:/Sun/Creator2_1/SunAppServer8/lib\deployhelp_zh_CN.jar;C:/Sun/Creator2_1/SunAppServer8/lib\dom.jar;C:/Sun/Creator2_1/SunAppServer8/lib\driveradapter.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee-svc.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee_es.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee_fr.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee_ja.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee_ko.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee_zh.jar;C:/Sun/Creator2_1/SunAppServer8/lib\j2ee_zh_CN.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jax-qname.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jaxr-api.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jaxr-impl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jaxrpc-api.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jaxrpc-impl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jdic_0_9.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jmxremote.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jmxremote_optional.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jsf-api.jar;C:/Sun/Creator2_1/SunAppServer8/lib\jsf-impl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\mail.jar;C:/Sun/Creator2_1/SunAppServer8/lib\PEtray.jar;C:/Sun/Creator2_1/SunAppServer8/lib\relaxngDatatype.jar;C:/Sun/Creator2_1/SunAppServer8/lib\rmissl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\saaj-api.jar;C:/Sun/Creator2_1/SunAppServer8/lib\saaj-impl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smbase.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smdb2.jar;C:/Sun/Creator2_1/SunAppServer8/lib\sminformix.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smoracle.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smresource.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smspy.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smsqlserver.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smsybase.jar;C:/Sun/Creator2_1/SunAppServer8/lib\smutil.jar;C:/Sun/Creator2_1/SunAppServer8/lib\xalan.jar;C:/Sun/Creator2_1/SunAppServer8/lib\xercesImpl.jar;C:/Sun/Creator2_1/SunAppServer8/lib\xsdlib.jar;C:/Sun/Creator2_1/SunAppServer8/lib/install/applications/jmsra/imqjmsra.jar;C:/Sun/Creator2_1/SunAppServer8/imq/lib/jaxm-api.jar;C:/Sun/Creator2_1/SunAppServer8/imq/lib/fscontext.jar;C:/Sun/Creator2_1/SunAppServer8/lib/ant/lib/ant.jar com.sun.rave.tray.RavePEMain start display native|#] *** EXITING ERROR: Can't create Java VM *** ОС Win Xp SP2. Похоже на то что ему не нравятся пробелы в путях, но у меня их нет. Заранее благодарен. P.S. Можноли както креатор переподвязать на tomcat? ... |
| 04.05.2006, 10:11:03 |
Странно, у меня в свое время с этим проблем не было. Все нормально запускалось без всяких приключений ... |
| 04.05.2006, 10:30:16 |
Посмотрите что у вас в PATH, JAVA_HOME,... ... |
| 04.05.2006, 10:54:05 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. ... |
| 04.05.2006, 11:03:05 |
пишет же что его смущают пробелы в пути к jdk и сам путь показывает, плохо это конечно, но видимо лечится аж двумя способами, 1й поставить жаву в не програм файлс (например ещё одну :)), 2й покопаться в запускающих скриптах где есть ссылки на джаву и возможно поставить кавычки или закодировать пробел у меня правда под рукой нет криатора, 2й способ проверить не могу. ... |
| 04.05.2006, 14:27:12 |
У меня в Program files не явы. Насколькоя понял то это он приводит как пример. ... |
| 04.05.2006, 15:35:29 |
Gold Fish .... ОС Win Xp SP2. Похоже на то что ему не нравятся пробелы в путях, но у меня их нет. ну почему же нет, вот же они Gold Fish PATH = C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\Perl\bin\;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;c:\JDK1.5.0_04\bin;C:\ Program Files \Microsoft SQL Server\80\Tools\BINN;c:\Archivators;C:\PROGRA~1\UACenter;C:\Python24;C:\ Documents and Settings \yr\Desktop\pljava-i686-pc-mingw32-pg8.0-1.1.0;C:\Program Files\ Common Files \GTK\2.0\bin ... |
| 04.05.2006, 18:22:39 |
если судить по http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6370909 то возможно это глюки когда в PATH в принципе есть пробелы :( ... |
| 04.05.2006, 18:42:30 |
Похоже на то и ему не катят кавычки. ... |
| 04.05.2006, 19:07:39 |
Убрал все пробелы и всеравно не стартует выдает в лог тоже самое только без ворнинга. Что самое интересное что Creator 2004Q2 работает отлично. ... |
| 12.05.2006, 14:12:01 |
start [/forum/topic.php?desktop=1&fid=59&tid=2149298]: |
36ms |
62ms |
| others: | 328ms |
| total: | 482ms |
