spring + hibernate
Добрый день. Никак не могу разобраться в чем проблема: вроде все просто и правильно, но не работает. Имеем: 1. /com/test/model/City.hbm.xml <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 2.0/EN" "http://hibernate.sourcefourge.net/hibernate-mapping-2.0.dtd"> <hibernate-mapping> <class name="com.test.model.City" table="cities"> <id name="cityId" column="city_id" type="long"> <generator class="increment" /> </id> <property name="cityName" column="city_name" type="string" length="50" not-null="true" /> </class> </hibernate-mapping> 2. applicatioContext.xml <?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE beans PUBLIC "-//SPRING//DTD BEAN//EN" "http://www.springframework.org/dtd/spring-beans.dtd"> <beans> <bean id="dataSource" class="org.springframework.jdbc.datasource. DriverManagerDataSource"> <property name="driverClassName"> <value>com.mysql.jdbc.Driver</value> </property> <property name="url"> <value>jdbc:mysql://localhost/testdb</value> </property> <property name="username"> <value>root</value> </property> <property name="password"> <value>12345</value> </property> </bean> <bean id="sessionFactory" class="org.springframework.orm.hibernate. LocalSessionFactoryBean"> <property name="dataSource"> <ref local="dataSource"/> </property> <property name="mappingResources"> <list> <value>com/test/model/City.hbm.xml</value> </list> </property> <property name="hibernateProperties"> <props> <prop key="hibernate.dialect"> org.hibernate.dialect.MySQLDialect </prop> </props> </property> </bean> </beans> При запуске под Tomcat выдает: INFO: Loaded JDBC driver: com.mysql.jdbc.Driver 04.08.2006 18:25:57 net.sf.hibernate.cfg.Environment <clinit> INFO: Hibernate 2.1.4 04.08.2006 18:25:57 net.sf.hibernate.cfg.Environment <clinit> INFO: hibernate.properties not found 04.08.2006 18:25:57 net.sf.hibernate.cfg.Environment <clinit> INFO: using CGLIB reflection optimizer 04.08.2006 18:25:57 net.sf.hibernate.cfg.Configuration addInputStream SEVERE: Could not configure datastore from input stream org.dom4j.DocumentException: hibernate.sourcefourge.net Nested exception: hibern ate.sourcefourge.net at org.dom4j.io.SAXReader.read(SAXReader.java:358) at net.sf.hibernate.cfg.Configuration.addInputStream(Configuration.java: 283) at org.springframework.orm.hibernate.LocalSessionFactoryBean.afterProper tiesSet(LocalSessionFactoryBean.java:446) at org.springframework.beans.factory.support.AbstractAutowireCapableBean Factory. invokeInitMethods(AbstractAutowireCapableBeanFacto ry.java:1059) at org.springframework.beans.factory.support.AbstractAutowireCapableBean Factory.createBean(AbstractAutowireCapableBeanFactory.java:363) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean (AbstractBeanFactory.java:226) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean (AbstractBeanFactory.java:147) at org.springframework.beans.factory.support.DefaultListableBeanFactory. preInstantiateSingletons(DefaultListableBeanFactor y.java:269) at org.springframework.context.support.AbstractApplicationContext.refres h(AbstractApplicationContext.java:320) at org.springframework.web.context.support.AbstractRefreshableWebApplica tionContext.refresh(AbstractRefreshableWebApplicationContext.java:134) at org.springframework.web.context.ContextLoader.createWebApplicationCon text(ContextLoader.java:246) at org.springframework.web.context.ContextLoader.initWebApplicationConte xt(ContextLoader.java:184) at org.springframework.web.context.ContextLoaderListener.contextInitiali zed(ContextLoaderListener.java:49) at org.apache.catalina.core.StandardContext.listenerStart(StandardContex t.java:3269) at org.apache.catalina.core.StandardContext.start(StandardContext.java:3 598) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase .java:821) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:80 7) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:579) at org.apache.catalina.core.StandardHostDeployer.install(StandardHostDep loyer.java:307) at org.apache.catalina.core.StandardHost.install(StandardHost.java:772) at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:492 ) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:400 ) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:718) at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java :358) at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl eSupport.java:166) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1196) at org.apache.catalina.core.StandardHost.start(StandardHost.java:738) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1188) at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:347 ) at org.apache.catalina.core.StandardService.start(StandardService.java:4 97) at org.apache.catalina.core.StandardServer.start(StandardServer.java:219 0) at org.apache.catalina.startup.Catalina.start(Catalina.java:512) at org.apache.catalina.startup.Catalina.execute(Catalina.java:400) at org.apache.catalina.startup.Catalina.process(Catalina.java:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:203) В чем может быть проблема (spring-1.2.6, hibernate 2.0, tomcat4.1)? ... |
| 04.08.2006, 19:21:45 |
start [/forum/topic.php?desktop=1&fid=59&tid=2148486]: |
326ms |
57ms |
| others: | 324ms |
| total: | 792ms |
