Что же все таки такое Struts?
Здравствуйте! Подскажите, Struts - это 1) библиотека пользовательских тэгов? 2) среда разработки в архитектуре: модель-вид-контроллер 3) Ваш вариант :) ... |
| 26.09.2006, 17:03:23 |
контроллер ;) ... |
| 26.09.2006, 17:05:04 |
Почитаем первоисточник http://struts.apache.org/index.html Apache Struts is a free open-source framework for creating Java web applications. Web applications differ from conventional websites in that web applications can create a dynamic response. Many websites deliver only static pages. A web application can interact with databases and business logic engines to customize a response. Web applications based on JavaServer Pages sometimes commingle database code, page design code, and control flow code. In practice, we find that unless these concerns are separated, larger applications become difficult to maintain. One way to separate concerns in a software application is to use a Model-View-Controller (MVC) architecture. The Model represents the business or database code, the View represents the page design code, and the Controller represents the navigational code. The Struts framework is designed to help developers create web applications that utilize a MVC architecture. The framework provides three key components: * A "request" handler provided by the application developer that is mapped to a standard URI. * A "response" handler that transfers control to another resource which completes the response. * A tag library that helps developers create interactive form-based applications with server pages. The framework's architecture and tags are buzzword compliant. Struts works well with conventional REST applications and with nouveau technologies like SOAP and AJAX. ... |
| 26.09.2006, 17:11:26 |
zna9контроллер ;) в смысле, это сервлет который управляет потоком информации? когда я говорил о среде разработке, я имел ввиду, визуальную среду разработки, которая предоставляет какие-то средства для разработки приложений в выше указанной архитектуре. т.е. это совсем не так, и такое утверждение ошибочно???? ... |
| 26.09.2006, 17:25:28 |
читать я умею, по русски :), и не ленюсь покапаться в книгах, руководствах, перед тем как задать вопрос, англоязычную доку я так же просматривал, но я так и не понял точно что же все таки Struts? в том англоязычном отрывке, что мне был представлен, написано: Struts - framework! В моем представлении, framework - (визуальная) среда разработки, которая предоставляет (содержит) определенные компоненты (API) для упрощения программирования. Я не прав или прав??? в том же англоязычном тексте упоминались тэги, так что, это библиотека тэгов????? ничего не понятно! может кто-нибудь дать четкий вразумительный ответ что такое Struts??????? ... |
| 26.09.2006, 17:46:08 |
vladik_k В моем представлении, framework - (визуальная) среда разработки, которая предоставляет (содержит) определенные компоненты (API) для упрощения программирования. Я не прав или прав??? Вы не правы. Найдите и прочитайте определение фреймворка. В английском варианте. ... |
| 26.09.2006, 17:49:10 |
start [/forum/topic.php?desktop=1&fid=59&tid=2148008]: |
297ms |
70ms |
| others: | 307ms |
| total: | 748ms |
