Мой первый jsp+bean - почему не работает? где ошибка?
Выполняю простой, по идее, пример из учебника: создать бин, просто класс с методом выполняющим простую операцию: Код: plaintext 1. 2. 3. 4. 5. 6. Дальше создал jsp: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. ... |
| 19.10.2006, 10:19:42 |
какие ошибки-то выдает? ... |
| 19.10.2006, 10:57:40 |
Deadyкакие ошибки-то выдает? HTTP Status 500 - -------------------------------------------------------------------------------- type Exception report message description The server encountered an internal error () that prevented it from fulfilling this request. exception org.apache.jasper.JasperException: Unable to compile class for JSP An error occurred at line: 7 in the jsp file: /usesBean1.jsp Generated servlet error: C:\Documents and Settings\Martynenko\.netbeans\5.5beta2\apache-tomcat-5.5.17_base\work\Catalina\localhost\MyExamples\org\apache\jsp\usesBean1_jsp.java:46: cannot find symbol symbol : class CalculatorBean location: class org.apache.jsp.usesBean1_jsp CalculatorBean theBean = null; ^ An error occurred at line: 7 in the jsp file: /usesBean1.jsp Generated servlet error: C:\Documents and Settings\Martynenko\.netbeans\5.5beta2\apache-tomcat-5.5.17_base\work\Catalina\localhost\MyExamples\org\apache\jsp\usesBean1_jsp.java:48: cannot find symbol symbol : class CalculatorBean location: class org.apache.jsp.usesBean1_jsp theBean = (CalculatorBean) _jspx_page_context.getAttribute("theBean", PageContext.PAGE_SCOPE); ^ An error occurred at line: 7 in the jsp file: /usesBean1.jsp Generated servlet error: C:\Documents and Settings\Martynenko\.netbeans\5.5beta2\apache-tomcat-5.5.17_base\work\Catalina\localhost\MyExamples\org\apache\jsp\usesBean1_jsp.java:50: cannot find symbol symbol : class CalculatorBean location: class org.apache.jsp.usesBean1_jsp theBean = new CalculatorBean(); ^ 3 errors org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:510) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:375) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) org.netbeans.modules.web.monitor.server.MonitorFilter.doFilter(MonitorFilter.java:368) root cause org.apache.jasper.JasperException: Unable to compile class for JSP An error occurred at line: 7 in the jsp file: /usesBean1.jsp Generated servlet error: C:\Documents and Settings\Martynenko\.netbeans\5.5beta2\apache-tomcat-5.5.17_base\work\Catalina\localhost\MyExamples\org\apache\jsp\usesBean1_jsp.java:46: cannot find symbol symbol : class CalculatorBean location: class org.apache.jsp.usesBean1_jsp CalculatorBean theBean = null; ^ An error occurred at line: 7 in the jsp file: /usesBean1.jsp Generated servlet error: C:\Documents and Settings\Martynenko\.netbeans\5.5beta2\apache-tomcat-5.5.17_base\work\Catalina\localhost\MyExamples\org\apache\jsp\usesBean1_jsp.java:48: cannot find symbol symbol : class CalculatorBean location: class org.apache.jsp.usesBean1_jsp theBean = (CalculatorBean) _jspx_page_context.getAttribute("theBean", PageContext.PAGE_SCOPE); ^ An error occurred at line: 7 in the jsp file: /usesBean1.jsp Generated servlet error: C:\Documents and Settings\Martynenko\.netbeans\5.5beta2\apache-tomcat-5.5.17_base\work\Catalina\localhost\MyExamples\org\apache\jsp\usesBean1_jsp.java:50: cannot find symbol symbol : class CalculatorBean location: class org.apache.jsp.usesBean1_jsp theBean = new CalculatorBean(); ^ 3 errors org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:84) org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:328) org.apache.jasper.compiler.AntCompiler.generateClass(AntCompiler.java:249) org.apache.jasper.compiler.Compiler.compile(Compiler.java:297) org.apache.jasper.compiler.Compiler.compile(Compiler.java:276) org.apache.jasper.compiler.Compiler.compile(Compiler.java:264) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:563) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:303) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) org.netbeans.modules.web.monitor.server.MonitorFilter.doFilter(MonitorFilter.java:368) note The full stack trace of the root cause is available in the Apache Tomcat/5.5.17 logs. -------------------------------------------------------------------------------- Apache Tomcat/5.5.17 ... |
| 19.10.2006, 11:10:37 |
класс CalculatorBean следует поместить в пакет. ... |
| 19.10.2006, 11:18:33 |
Deadyкласс CalculatorBean следует поместить в пакет. Спасибо, помогло =) ... |
| 19.10.2006, 12:23:20 |
Deadyкласс CalculatorBean следует поместить в пакет. кстати почему? Почему в classes только сервлеты видятся, но не пользовательские классы без пакета - так задумано? ... |
| 23.10.2006, 01:38:47 |
трудно сказать. наверно стоит скачать сорцы томката и посмотреть. но 1. так как лень 2. так как классы всегда стоит класть в пакеты (хороший стиль) то впринципе забить. у меня таких проблем не возникает. ... |
| 23.10.2006, 11:55:50 |
start [/forum/topic.php?desktop=1&fid=59&tid=2147736]: |
304ms |
56ms |
| others: | 291ms |
| total: | 703ms |
