Проблем с Postgres
ето работает try { Class.forName("org.postgresql.Driver"); } catch (ClassNotFoundException e1) { // TODO Auto-generated catch block e1.printStackTrace(); } ResultSet rs = null; Statement statement = null; Connection conn; try { conn = DriverManager.getConnection("jdbc:postgresql:POS", "dimo", "dimo"); statement = conn.createStatement(); String strQuery; // strQuery = "SELECT tb_inv_header.pos_id, tb_inv_detail.invd_amount as fld_INVD_AMOUNT, tb_article.art_name as fld_ART_NAME, tb_articlegroup.grpname as fld_GRPNAME, tb_pricemodificator.prm_name as fld_PRM_NAME, tb_article.art_id as fld_ART_ID, tb_inv_detail.invd_price_per as fld_INVD_PRICE_PER, "; //strQuery = strQuery + "tb_inv_detail.invd_price_complete as fld_INVD_PRICE_COMPLETE FROM tb_inv_header Inner Join tb_inv_detail ON tb_inv_header.invh_id = tb_inv_detail.invh_id Inner Join tb_article ON tb_inv_detail.id = tb_article.id Inner Join tb_articlegroup ON tb_article.grpid = tb_articlegroup.grpid left Join tb_pricemodificator ON tb_inv_detail.prm_id = tb_pricemodificator.prm_id"; strQuery = "SELECT art_name as fld_ART_NAME from tb_article"; System.out.println(strQuery); rs = statement.executeQuery(strQuery); String lang =""; while(rs.next()){ lang = rs.getString("fld_ART_NAME"); System.out.println( " " + lang + " " ); } } catch (SQLException e1) { // TODO Auto-generated catch block e1.printStackTrace(); } а так нет: strQuery = "SELECT tb_inv_header.pos_id, tb_inv_detail.invd_amount as fld_INVD_AMOUNT, tb_article.art_name as fld_ART_NAME, tb_articlegroup.grpname as fld_GRPNAME, tb_pricemodificator.prm_name as fld_PRM_NAME, tb_article.art_id as fld_ART_ID, tb_inv_detail.invd_price_per as fld_INVD_PRICE_PER, "; strQuery = strQuery + "tb_inv_detail.invd_price_complete as fld_INVD_PRICE_COMPLETE FROM tb_inv_header Inner Join tb_inv_detail ON tb_inv_header.invh_id = tb_inv_detail.invh_id Inner Join tb_article ON tb_inv_detail.id = tb_article.id Inner Join tb_articlegroup ON tb_article.grpid = tb_articlegroup.grpid left Join tb_pricemodificator ON tb_inv_detail.prm_id = tb_pricemodificator.prm_id"; хотя в pgAdmine запрос дает результат! REATE TABLE tb_article ( id int4 NOT NULL, art_id varchar(25) NOT NULL, art_name varchar(150) NOT NULL, art_comment varchar(200), art_min_storage int4, art_parent_id int4, grpid int4, art_colour varchar(150), art_size int4, art_check_amount bool, art_base_article bool, art_crea_date date, art_user_mod int4, art_mod_date date, art_user_crea int4, CONSTRAINT tb_article_pkey PRIMARY KEY (id), CONSTRAINT fked71bc05191b4dc FOREIGN KEY (grpid) REFERENCES tb_articlegroup (grpid) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT tb_article_art_id_key UNIQUE (art_id) ) WITHOUT OIDS; ALTER TABLE tb_article OWNER TO ...; CREATE TABLE tb_inv_header ( invh_id int8 NOT NULL, invh_number varchar(25), invh_crea_date timestamp, pos_id int4 NOT NULL, usrid int4 NOT NULL, cus_id int4, invh_state float8, invh_pay_type int4, CONSTRAINT tb_inv_header_pkey PRIMARY KEY (invh_id), CONSTRAINT fk5b51152c211c062a FOREIGN KEY (cus_id) REFERENCES tb_customer (cus_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_invh_pos FOREIGN KEY (pos_id) REFERENCES tb_pos (pos_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_invh_usr FOREIGN KEY (usrid) REFERENCES tb_user (usrid) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT tb_inv_header_invh_number_key UNIQUE (invh_number) ) WITHOUT OIDS; ALTER TABLE tb_inv_header OWNER TO ...; REATE TABLE tb_package_detail ( pad_id int4 NOT NULL, pah_id int4 NOT NULL, art_id int4 NOT NULL, pad_price_portion_type float8, pad_price_portion_amount float8, CONSTRAINT tb_package_detail_pkey PRIMARY KEY (pad_id), CONSTRAINT fk_pad_art_artid FOREIGN KEY (art_id) REFERENCES tb_article (id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_pad_pah_id FOREIGN KEY (pah_id) REFERENCES tb_package_header (pah_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION ) WITHOUT OIDS; ALTER TABLE tb_package_detail OWNER TO ...; ... |
| 08.11.2006, 00:12:33 |
start [/forum/topic.php?desktop=1&fid=59&tid=2147553]: |
23ms |
62ms |
57ms |
| others: | 282ms |
| total: | 481ms |
