Проблема с JavaWebStart
Здраствуйте! У меня возникла следующая проблема. Запускаю программу import org.lwjgl.util.Timer; public class Test { public static void main(String[] args) { Timer t = new Timer(); System.exit(0); } } При запуске из командной строки - всё нормально. Если запускать через JavaWebStart выдаёт ошибку java.lang.reflect.InvocationTargetException at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.sun.javaws.Launcher.executeApplication(Unknown Source) at com.sun.javaws.Launcher.executeMainClass(Unknown Source) at com.sun.javaws.Launcher.continueLaunch(Unknown Source) at com.sun.javaws.Launcher.handleApplicationDesc(Unknown Source) at com.sun.javaws.Launcher.handleLaunchFile(Unknown Source) at com.sun.javaws.Launcher.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: java.lang.ExceptionInInitializerError at org.lwjgl.Sys.createImplementation(Sys.java:112) at org.lwjgl.Sys.<clinit>(Sys.java:100) at org.lwjgl.util.Timer.<clinit>(Timer.java:50) at Test.main(Test.java:7) ... 11 more Caused by: java.security.AccessControlException: access denied (java.util.PropertyPermission org.lwjgl.util.Debug read) at java.security.AccessControlContext.checkPermission(Unknown Source) at java.security.AccessController.checkPermission(Unknown Source) at java.lang.SecurityManager.checkPermission(Unknown Source) at java.lang.SecurityManager.checkPropertyAccess(Unknown Source) at java.lang.System.getProperty(Unknown Source) at java.lang.Boolean.getBoolean(Unknown Source) at org.lwjgl.LWJGLUtil$3.run(LWJGLUtil.java:440) at java.security.AccessController.doPrivileged(Native Method) at org.lwjgl.LWJGLUtil.getPrivilegedBoolean(LWJGLUtil.java:438) at org.lwjgl.LWJGLUtil.<clinit>(LWJGLUtil.java:268) ... 15 more Вот этот org.lwjgl.util.Timer хранится в jar-е из которого с половиной классов такая же проблема, а половина работает нормально!? Кто-нибудь знает в чём может быть проблема? Зарание спасибо. ... |
| 13.11.2006, 14:13:51 |
Возник вопрос- насколько хорошо вы разбираетесь в Java Web Start? Видимо Таймер создается в отдельном потоке, что не разрешено по умолчанию, также как и доступ к файлпам, сети принтерам и тд.Есть два способа.прочитайте на www.java.sun.com про технологию ВебСтарт в частности про Basic Services или просто подпишите свое приложение ... |
| 15.11.2006, 10:58:25 |
start [/forum/topic.php?desktop=1&fid=59&tid=2147506]: |
40ms |
47ms |
| others: | 310ms |
| total: | 471ms |
