JSTL 1.0 + JSP 1.2
скажу сразу, что до этого случая юзал JSTL 1.1 + JSP 2.0 + Tomcat 5.0.28 и проблем не возникало, сейчас изза требований заказчика юзаю JSTL 1.0 + JSP 1.2 + Tomcat 4.1.29. проблема следуюшая, пытаюсь вывести с помощью JSTL некое значение на скрин, например: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. Код: plaintext Код: plaintext ... |
| 16.11.2006, 18:20:36 |
JSTL 1.0 + JSP 1.2
http://java.sun.com/developer/technicalArticles/javaserverpages/faster/Note: The specification for the expression language is really the responsibility of the JSR-152 expert group (JavaServer Pages 1.3). The JSR-52 (JSTL) and the JSR-152 expert groups have worked together on specifying the expression language. However, since JSTL 1.0 was finalized prior to JavaServer Pages 2.0, the goal was to ensure that the current expression-language specification would be compatible with the one in JavaServer Pages 2.0. The good news is that once JavaServer Pages 2.0 is released, you'll be ready to use its expression language, since it's the same as what you see here. ... |
| 16.11.2006, 20:13:32 |
start [/forum/topic.php?desktop=1&fid=59&tid=2147480]: |
38ms |
59ms |
| others: | 281ms |
| total: | 437ms |
