Eclipse. Не могу я его поянть
Проект, который запускался без проблем выдает следующее при запуске теперь: log!ENTRY org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Bundle initial@reference:file:plugins/com.swtdesigner_4.2.1/ [15] was not resolved. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing required bundle org.eclipse.core.resources_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing required bundle org.eclipse.jdt.core_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing required bundle org.eclipse.jdt.ui_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing required bundle org.eclipse.jdt.launching_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing required bundle org.eclipse.jdt.debug.ui_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing required bundle org.eclipse.debug.ui_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.pde.core_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.pde.ui_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.search_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.ui.editors_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.ui.ide_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.ui.forms_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.ui.console_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.team.ui_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.text_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.jface.text_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.update.configurator_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.ltk.core.refactoring_0.0.0. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.99 !MESSAGE Missing optionally required bundle org.eclipse.ltk.ui.refactoring_0.0.0. !ENTRY org.eclipse.osgi 2006-11-29 08:30:03.115 !MESSAGE Bundle initial@reference:file:../EclipseWorkspace/ru.nameapp/ [17] was not resolved. !SUBENTRY 1 org.eclipse.osgi 2006-11-29 08:30:03.115 !MESSAGE Missing required bundle com.swtdesigner_0.0.0. !ENTRY org.eclipse.osgi 2006-11-29 08:30:03.115 !MESSAGE Application error !STACK 1 java.lang.RuntimeException: Application "ru.nameapp.application" could not be found in the registry. The applications available are: <NONE>. at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:216) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:585) at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334) at org.eclipse.core.launcher.Main.basicRun(Main.java:278) at org.eclipse.core.launcher.Main.run(Main.java:973) at org.eclipse.core.launcher.Main.main(Main.java:948) Подскажите, что я мог сделать не так? ... |
| 29.11.2006, 08:37:53 |
Я думаю, неправильно задали вопрос. Напишите, что вы хотите сделать и что сделали, после чего все полетело. ... |
| 29.11.2006, 11:54:24 |
Что хотел сделать - запустить проект. Что делал до этого - поправил код в паре классов. Что смутило - для меня эта ошибка абсолютно не понятна. Результат - исправил путем очистки списка плагинов в конфигурации запуска, и заново прописал необходимые. В общем методом научного тыка. ... |
| 29.11.2006, 13:09:53 |
start [/forum/topic.php?desktop=1&fid=59&tid=2147355]: |
46ms |
60ms |
| others: | 294ms |
| total: | 464ms |
