В чем ошибка и как бороться с ней?
Запускаю приложение в TomCat, а он видает ошибку HTTP Status 500 - -------------------------------------------------------------------------------- type Exception report message description The server encountered an internal error () that prevented it from fulfilling this request. exception javax.servlet.ServletException: Error allocating a servlet instance org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:164) org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:211) org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:805) org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:696) org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:605) org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:677) java.lang.Thread.run(Unknown Source) root cause java.lang.UnsupportedClassVersionError: ListBook (Unsupported major.minor version 49.0) java.lang.ClassLoader.defineClass0(Native Method) java.lang.ClassLoader.defineClass(Unknown Source) java.security.SecureClassLoader.defineClass(Unknown Source) org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:1653) org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:883) org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1333) org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1213) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:164) org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:211) org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:805) org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:696) org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:605) org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:677) java.lang.Thread.run(Unknown Source) note The full stack trace of the root cause is available in the Tomcat logs. -------------------------------------------------------------------------------- Apache Tomcat/5.0.16 Подскажите как исправить? ... |
| 14.12.2006, 12:44:56 |
Собственно ошибка: java.lang.UnsupportedClassVersionError: ListBook (Unsupported major.minor version 49.0) Сервер использует более старую версию JVM (1.4?) чем была использована для компиляции сервлета (1.5). Надо либо перекомпилировать сервлет соответствующей версией компилятора, либо использовать при компиляции ключ (не помню какой). ... |
| 14.12.2006, 13:16:46 |
Для компиляции использую Oracle JDeveloper 10g Release 3 (10.1.3) Версия Tomcat: 5.0.16 Server Какую версию компилятора тогда нужно? ... |
| 14.12.2006, 13:30:05 |
Для компиляции ты используеш JDK а версию посмотри в настройках девелопера ... |
| 14.12.2006, 13:36:46 |
-target 1.4 можно поставить а что говорит javac -version ? ... |
| 14.12.2006, 13:36:52 |
Заменил jvm на 1.6. Теперь выдает новую ошибку=((( Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. ... |
| 14.12.2006, 15:49:18 |
Подключение к БД как настраивали? FAQ по Tomcat читали? ... |
| 14.12.2006, 15:58:31 |
Подключаюсь так: Код: plaintext 1. 2. 3. 4. 5. 6. 7. ... |
| 14.12.2006, 16:30:10 |
ojdbc14.jar(или какой там у вас jdbc driver) в WEB-INF/lib своего приложения закиньте и будет вам счастье ... |
| 14.12.2006, 16:34:14 |
-=Pino=-Подключаюсь так: Код: plaintext 1. 2. 3. 4. 5. 6. 7. Зря ты так подключаешься. Думаю тебе в обход всех решений с DriverManager нужно использовать пул соеденений ... |
| 14.12.2006, 16:39:02 |
start [/forum/topic.php?desktop=1&fid=59&tid=2147200]: |
39ms |
53ms |
| others: | 311ms |
| total: | 463ms |
