Не работает Mondrian с Firebird
Подключаемся к Firebird из Mondrian через JDBC, при работе с другими базами всё нормально, но с Firebird при попытке подключится через JRubik возникают ошибки: Soap Fault code=SOAP-ENV:Server.00HSBE02 fault string=XMLA Discover unparse results error fault actor=Mondrian detail: com.tonbeller.jpivot.olap.model.OlapException: Soap Fault code=SOAP-ENV:Server.00HSBE02 fault string=XMLA Discover unparse results error fault actor=Mondrian detail: com.tonbeller.jpivot.xmla.XMLA_SOAP.errorCheck(XMLA_SOAP.java:1460) com.tonbeller.jpivot.xmla.XMLA_SOAP.discover(XMLA_SOAP.java:1409) com.tonbeller.jpivot.xmla.XMLA_SOAP.discoverDim(XMLA_SOAP.java:339) es.aeat.eett.rubik.discoverer.DynamicTreeNodeXmla.loadDimensions(DynamicTreeNodeXmla.java:121) es.aeat.eett.rubik.discoverer.DynamicTreeNodeXmla.loadChildren(DynamicTreeNodeXmla.java:77) es.aeat.eett.rubik.discoverer.DynamicTreeNodeXmla.getChildCount(DynamicTreeNodeXmla.java:57) javax.swing.tree.DefaultTreeModel.getChildCount(DefaultTreeModel.java:168) javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.expand(VariableHeightLayoutCache.java:1461) javax.swing.tree.VariableHeightLayoutCache$TreeStateNode.expand(VariableHeightLayoutCache.java:1270) javax.swing.tree.VariableHeightLayoutCache.ensurePathIsExpanded(VariableHeightLayoutCache.java:966) javax.swing.tree.VariableHeightLayoutCache.setExpandedState(VariableHeightLayoutCache.java:164) javax.swing.plaf.basic.BasicTreeUI.updateExpandedDescendants(BasicTreeUI.java:1542) javax.swing.plaf.basic.BasicTreeUI$Handler.treeExpanded(BasicTreeUI.java:3578) javax.swing.JTree.fireTreeExpanded(JTree.java:2235) javax.swing.JTree.setExpandedState(JTree.java:3006) javax.swing.JTree.expandPath(JTree.java:1742) javax.swing.plaf.basic.BasicTreeUI.toggleExpandState(BasicTreeUI.java:2149) javax.swing.plaf.basic.BasicTreeUI.handleExpandControlClick(BasicTreeUI.java:2136) javax.swing.plaf.basic.BasicTreeUI.checkForClickInExpandControl(BasicTreeUI.java:2090) javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(BasicTreeUI.java:3423) javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(BasicTreeUI.java:3393) java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:222) java.awt.AWTEventMulticaster.mousePressed(AWTEventMulticaster.java:221) java.awt.Component.processMouseEvent(Component.java:5485) javax.swing.JComponent.processMouseEvent(JComponent.java:3093) java.awt.Component.processEvent(Component.java:5253) java.awt.Container.processEvent(Container.java:1966) java.awt.Component.dispatchEventImpl(Component.java:3955) java.awt.Container.dispatchEventImpl(Container.java:2024) java.awt.Component.dispatchEvent(Component.java:3803) java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4212) java.awt.LightweightDispatcher.processMouseEvent(Container.java:3889) java.awt.LightweightDispatcher.dispatchEvent(Container.java:3822) java.awt.Container.dispatchEventImpl(Container.java:2010) java.awt.Window.dispatchEventImpl(Window.java:1766) java.awt.Component.dispatchEvent(Component.java:3803) java.awt.EventQueue.dispatchEvent(EventQueue.java:463) java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:234) java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:163) java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:157) java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:149) java.awt.EventDispatchThread.run(EventDispatchThread.java:110) База данных FoodMart стандартная, которая используется Mondrian для теста. Насколько я понял JRubik не может найти потомков в иерархии у кубов Sales, Warehouse and Sales и Sales Ragged. И в мондриане некоторые MDX запросы не выполняются Вопрос: что мне сделать, стобы исправить эти ошибки. Заранее спасибо! ... |
| 20.04.2007, 15:16:04 |
start [/forum/topic.php?desktop=1&fid=59&tid=2145974]: |
39ms |
29ms |
| others: | 319ms |
| total: | 440ms |
