помогите с ExtensionsFilter
Помогите новичку, пробовал пример из http://example.irian.at/example-simple-20070505/tree2NiceWrap.jsf Немогу разобраться с фильтрами!!! (у меня такая иерархия WEB-INF/jsp/tree.jsp). web.xml выглятит так <?xml version="1.0" encoding="UTF-8"?> <web-app xmlns="http://java.sun.com/xml/ns/j2ee" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd" version="2.4"> <description>Sample web.xml for MyFaces 1.1.5, taken from MyFaces site, but with .jsf extension changed back to standard .faces. http://www.coreservlets.com/JSF-Tutorial/ </description> <context-param> <description>Comma separated list of URIs of (additional) faces config files. (e.g. /WEB-INF/my-config.xml) See JSF 1.0 PRD2, 10.3.2 Attention: You do not need to put /WEB-INF/faces-config.xml in here. </description> <param-name>javax.faces.CONFIG_FILES</param-name> <param-value>/WEB-INF/examples-config.xml</param-value> </context-param> <context-param> <description>State saving method: "client" or "server" (= default) See JSF Specification 2.5.3</description> <param-name>javax.faces.STATE_SAVING_METHOD</param-name> <param-value>client</param-value> </context-param> <context-param> <description>Only applicable if state saving method is "server" (= default). Defines the amount (default = 20) of the latest views are stored in session.</description> <param-name>org.apache.myfaces.NUMBER_OF_VIEWS_IN_SESSION</param-name> <param-value>20</param-value> </context-param> <context-param> <description>Only applicable if state saving method is "server" (= default). If true (default) the state will be serialized to a byte stream before it is written to the session. If false the state will not be serialized to a byte stream.</description> <param-name>org.apache.myfaces.SERIALIZE_STATE_IN_SESSION</param-name> <param-value>true</param-value> </context-param> <context-param> <description>Only applicable if state saving method is "server" (= default) and if org.apache.myfaces.SERIALIZE_STATE_IN_SESSION is true (= default) If true (default) the serialized state will be compressed before it is written to the session. If false the state will not be compressed.</description> <param-name>org.apache.myfaces.COMPRESS_STATE_IN_SESSION</param-name> <param-value>true</param-value> </context-param> <context-param> <description>This parameter tells MyFaces if javascript code should be allowed in the rendered HTML output. If javascript is allowed, command_link anchors will have javascript code that submits the corresponding form. If javascript is not allowed, the state saving info and nested parameters will be added as url parameters. Default: "true"</description> <param-name>org.apache.myfaces.ALLOW_JAVASCRIPT</param-name> <param-value>true</param-value> </context-param> <context-param> <param-name>org.apache.myfaces.DETECT_JAVASCRIPT</param-name> <param-value>false</param-value> </context-param> <context-param> <description>If true, rendered HTML code will be formatted, so that it is "human readable". i.e. additional line separators and whitespace will be written, that do not influence the HTML code. Default: "true"</description> <param-name>org.apache.myfaces.PRETTY_HTML</param-name> <param-value>true</param-value> </context-param> <context-param> <description>If true, a javascript function will be rendered that is able to restore the former vertical scroll on every request. Convenient feature if you have pages with long lists and you do not want the browser page to always jump to the top if you trigger a link or button action that stays on the same page. Default: "false"</description> <param-name>org.apache.myfaces.AUTO_SCROLL</param-name> <param-value>true</param-value> </context-param> <context-param> <description> Used for encrypting view state. Only relevant for client side state saving. See MyFaces wiki/web site documentation for instructions on how to configure an application for diffenent encryption strengths. </description> <param-name>org.apache.myfaces.SECRET</param-name> <param-value>NzY1NDMyMTA=</param-value> </context-param> <context-param> <description> Validate managed beans, navigation rules and ensure that forms are not nested. </description> <param-name>org.apache.myfaces.VALIDATE</param-name> <param-value>true</param-value> </context-param> <context-param> <description>A class implementing the org.apache.myfaces.shared.renderkit.html.util.AddResource interface. It is responsible to place scripts and css on the right position in your HTML document. Default: "org.apache.myfaces.shared.renderkit.html.util.DefaultAddResource" Follow the description on the MyFaces-Wiki-Performance page to enable StreamingAddResource instead of DefaultAddResource if you want to gain performance. </description> <param-name>org.apache.myfaces.ADD_RESOURCE_CLASS</param-name> <param-value>org.apache.myfaces.renderkit.html.util.DefaultAddResource</param-value> <!--param-value>org.apache.myfaces.component.html.util.StreamingAddResource</param-value--> </context-param> <context-param> <description> A very common problem in configuring MyFaces-web-applications is that the Extensions-Filter is not configured at all or improperly configured. This parameter will check for a properly configured Extensions-Filter if it is needed by the web-app. In most cases this check will work just fine, there might be cases where an internal forward will bypass the Extensions-Filter and the check will not work. If this is the case, you can disable the check by setting this parameter to false. </description> <param-name>org.apache.myfaces.CHECK_EXTENSIONS_FILTER</param-name> <param-value>true</param-value> </context-param> <filter> <filter-name>extensionsFilter</filter-name> <filter-class>org.apache.myfaces.webapp.filter.ExtensionsFilter</filter-class> <init-param> <description>Set the size limit for uploaded files. Format: 10 - 10 bytes 10k - 10 KB 10m - 10 MB 1g - 1 GB</description> <param-name>uploadMaxFileSize</param-name> <param-value>100m</param-value> </init-param> <init-param> <description>Set the threshold size - files below this limit are stored in memory, files above this limit are stored on disk. Format: 10 - 10 bytes 10k - 10 KB 10m - 10 MB 1g - 1 GB</description> <param-name>uploadThresholdSize</param-name> <param-value>100k</param-value> </init-param> </filter> <filter-mapping> <filter-name>extensionsFilter</filter-name> <url-pattern>*.faces</url-pattern> </filter-mapping> <servlet> <servlet-name>Faces Servlet</servlet-name> <servlet-class>javax.faces.webapp.FacesServlet</servlet-class> <load-on-startup>1</load-on-startup> </servlet> <servlet-mapping> <servlet-name>Faces Servlet</servlet-name> <url-pattern>*.faces</url-pattern> </servlet-mapping> </web-app> при деплое на сервер выдает org.apache.jasper.JasperException: ExtensionsFilter not correctly configured. JSF mapping missing. JSF pages not covered. Please see: http://myfaces.apache.org/tomahawk/extensionsFilter.html Помогите разобраться плз ... |
| 07.05.2007, 11:09:35 |
вот пример для использования tomahawk Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. ... |
| 11.05.2007, 18:02:22 |
start [/forum/topic.php?desktop=1&fid=59&tid=2145781]: |
49ms |
48ms |
| others: | 295ms |
| total: | 444ms |
