Не получается соединить ireport с mssql2000
я новичек, нуждаюсь в помощи!=) версия ireport 2.0.1 версия jdbc driver for mssql2000 sp3 при попытке подключения выдает ошибку: SQL problems: [Microsoft][SQLServer 2000 Driver for JDBC]End of stream was detected on a read. jdbc:microsoft:sqlserver://projdb:1433;DatabaseName=projectserver листинг: Exception Message: java.sql.SQLException: [Microsoft][SQLServer 2000 Driver for JDBC]End of stream was detected on a read. Level: SEVERE Stack Trace: com.microsoft.jdbc.base.BaseExceptions.createException(Unknown Source) com.microsoft.jdbc.base.BaseExceptions.getException(Unknown Source) com.microsoft.jdbc.sqlserver.tds.TDSRequest.processReply(Unknown Source) com.microsoft.jdbc.sqlserver.SQLServerImplConnection.open(Unknown Source) com.microsoft.jdbc.base.BaseConnection.getNewImplConnection(Unknown Source) com.microsoft.jdbc.base.BaseConnection.open(Unknown Source) com.microsoft.jdbc.base.BaseDriver.connect(Unknown Source) it.businesslogic.ireport.connection.JDBCConnection.getConnection(JDBCConnection.java:105) it.businesslogic.ireport.connection.JDBCConnection.test(JDBCConnection.java:404) it.businesslogic.ireport.connection.gui.ConnectionDialog.jButtonTestActionPerformed(ConnectionDialog.java:322) it.businesslogic.ireport.connection.gui.ConnectionDialog.access$300(ConnectionDialog.java:24) it.businesslogic.ireport.connection.gui.ConnectionDialog$4.actionPerformed(ConnectionDialog.java:274) javax.swing.AbstractButton.fireActionPerformed(Unknown Source) javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) javax.swing.DefaultButtonModel.setPressed(Unknown Source) javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source) java.awt.Component.processMouseEvent(Unknown Source) javax.swing.JComponent.processMouseEvent(Unknown Source) java.awt.Component.processEvent(Unknown Source) java.awt.Container.processEvent(Unknown Source) java.awt.Component.dispatchEventImpl(Unknown Source) java.awt.Container.dispatchEventImpl(Unknown Source) java.awt.Component.dispatchEvent(Unknown Source) java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) java.awt.Container.dispatchEventImpl(Unknown Source) java.awt.Window.dispatchEventImpl(Unknown Source) java.awt.Component.dispatchEvent(Unknown Source) java.awt.EventQueue.dispatchEvent(Unknown Source) java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) java.awt.Dialog$1.run(Unknown Source) java.awt.Dialog$3.run(Unknown Source) java.security.AccessController.doPrivileged(Native Method) java.awt.Dialog.show(Unknown Source) java.awt.Component.show(Unknown Source) java.awt.Component.setVisible(Unknown Source) java.awt.Window.setVisible(Unknown Source) java.awt.Dialog.setVisible(Unknown Source) it.businesslogic.ireport.gui.ConnectionsDialog.jButtonModifyParameterActionPerformed(ConnectionsDialog.java:514) it.businesslogic.ireport.gui.ConnectionsDialog.jTableParametersMouseClicked(ConnectionsDialog.java:447) it.businesslogic.ireport.gui.ConnectionsDialog.access$100(ConnectionsDialog.java:53) it.businesslogic.ireport.gui.ConnectionsDialog$5.mouseClicked(ConnectionsDialog.java:196) java.awt.AWTEventMulticaster.mouseClicked(Unknown Source) java.awt.Component.processMouseEvent(Unknown Source) javax.swing.JComponent.processMouseEvent(Unknown Source) java.awt.Component.processEvent(Unknown Source) java.awt.Container.processEvent(Unknown Source) java.awt.Component.dispatchEventImpl(Unknown Source) java.awt.Container.dispatchEventImpl(Unknown Source) java.awt.Component.dispatchEvent(Unknown Source) java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) java.awt.Container.dispatchEventImpl(Unknown Source) java.awt.Window.dispatchEventImpl(Unknown Source) java.awt.Component.dispatchEvent(Unknown Source) java.awt.EventQueue.dispatchEvent(Unknown Source) java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) java.awt.Dialog$1.run(Unknown Source) java.awt.Dialog$3.run(Unknown Source) java.security.AccessController.doPrivileged(Native Method) java.awt.Dialog.show(Unknown Source) java.awt.Component.show(Unknown Source) java.awt.Component.setVisible(Unknown Source) java.awt.Window.setVisible(Unknown Source) java.awt.Dialog.setVisible(Unknown Source) it.businesslogic.ireport.gui.ConnectionsDialog.setVisible(ConnectionsDialog.java:623) it.businesslogic.ireport.gui.MainFrame.jMenuItemConnectionsActionPerformed(MainFrame.java:6466) it.businesslogic.ireport.gui.MainFrame.access$13800(MainFrame.java:101) it.businesslogic.ireport.gui.MainFrame$175.actionPerformed(MainFrame.java:3757) javax.swing.AbstractButton.fireActionPerformed(Unknown Source) javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) javax.swing.DefaultButtonModel.setPressed(Unknown Source) javax.swing.AbstractButton.doClick(Unknown Source) javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source) javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source) java.awt.Component.processMouseEvent(Unknown Source) javax.swing.JComponent.processMouseEvent(Unknown Source) java.awt.Component.processEvent(Unknown Source) java.awt.Container.processEvent(Unknown Source) java.awt.Component.dispatchEventImpl(Unknown Source) java.awt.Container.dispatchEventImpl(Unknown Source) java.awt.Component.dispatchEvent(Unknown Source) java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) java.awt.Container.dispatchEventImpl(Unknown Source) java.awt.Window.dispatchEventImpl(Unknown Source) java.awt.Component.dispatchEvent(Unknown Source) java.awt.EventQueue.dispatchEvent(Unknown Source) java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) java.awt.EventDispatchThread.pumpEvents(Unknown Source) java.awt.EventDispatchThread.pumpEvents(Unknown Source) java.awt.EventDispatchThread.run(Unknown Source) ... |
| 18.10.2007, 10:50:01 |
start [/forum/topic.php?desktop=1&fid=59&tid=2144306]: |
56ms |
34ms |
| others: | 373ms |
| total: | 534ms |
