Struts tags и скриплеты
Скажите пожалуйста как использовать в поле value тэга logic скриплет? Как динамически изменять value (там изначально ожидается не bean name)? У меня возникает ошибка в следующем коде: Код: plaintext 1. 2. 3. 4. Exception report Exception reportorg.apache.jasper.JasperException: Unable to compile class for JSP An error occurred at line: 172 in the jsp file: /browsepublication.jsp Generated servlet error: C:\Documents and Settings\SAP\.IntelliJIdea\system\tomcat_TomcatLocal_c4250d2c\work\Catalina\localhost\university\org\apache\jsp\browsepublication_jsp.java:386: cannot find symbol symbol : method setValue(int) location: class org.apache.struts.taglib.logic.LessThanTag _jspx_th_logic_lessThan_0.setValue(((ActionFormSearch)session.getAttribute("browseForm")).getTotalPages()); ^ An error occurred at line: 172 in the jsp file: /browsepublication.jsp Generated servlet error: Note: C:\Documents and Settings\SAP\.IntelliJIdea\system\tomcat_TomcatLocal_c4250d2c\work\Catalina\localhost\university\org\apache\jsp\browsepublication_jsp.java uses unchecked or unsafe operations. An error occurred at line: 172 in the jsp file: /browsepublication.jsp Generated servlet error: Note: Recompile with -Xlint:unchecked for details. 1 error org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:84) org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:332) org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:412) org.apache.jasper.compiler.Compiler.compile(Compiler.java:472) org.apache.jasper.compiler.Compiler.compile(Compiler.java:451) org.apache.jasper.compiler.Compiler.compile(Compiler.java:439) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:511) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:295) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:292) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:236) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1063) org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:386) org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:229) org.apache.struts.action.ActionServlet.process(ActionServlet.java:1194) org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414) javax.servlet.http.HttpServlet.service(HttpServlet.java:689) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) БОЛЬШОЕ СПАСИБО! ... |
| 28.01.2006, 01:38:55 |
ясно же написано: Код: plaintext 1. 2. 3. 4. 5. Атрибуты тегов - ВСЕГДА строки. Поэтому пишите так: Код: plaintext ... |
| 29.01.2006, 12:03:44 |
М.Голованов , Спасибо!! ... |
| 29.01.2006, 12:42:19 |
urgencyСкажите пожалуйста как использовать в поле value тэга logic скриплет? Как динамически изменять value (там изначально ожидается не bean name)? У меня возникает ошибка в следующем коде: Код: plaintext 1. 2. 3. 4. Exception report Exception reportorg.apache.jasper.JasperException: Unable to compile class for JSP An error occurred at line: 172 in the jsp file: /browsepublication.jsp Generated servlet error: C:\Documents and Settings\SAP\.IntelliJIdea\system\tomcat_TomcatLocal_c4250d2c\work\Catalina\localhost\university\org\apache\jsp\browsepublication_jsp.java:386: cannot find symbol symbol : method setValue(int) location: class org.apache.struts.taglib.logic.LessThanTag _jspx_th_logic_lessThan_0.setValue(((ActionFormSearch)session.getAttribute("browseForm")).getTotalPages()); ^ An error occurred at line: 172 in the jsp file: /browsepublication.jsp Generated servlet error: Note: C:\Documents and Settings\SAP\.IntelliJIdea\system\tomcat_TomcatLocal_c4250d2c\work\Catalina\localhost\university\org\apache\jsp\browsepublication_jsp.java uses unchecked or unsafe operations. An error occurred at line: 172 in the jsp file: /browsepublication.jsp Generated servlet error: Note: Recompile with -Xlint:unchecked for details. 1 error org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:84) org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:332) org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:412) org.apache.jasper.compiler.Compiler.compile(Compiler.java:472) org.apache.jasper.compiler.Compiler.compile(Compiler.java:451) org.apache.jasper.compiler.Compiler.compile(Compiler.java:439) org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:511) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:295) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:292) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:236) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1063) org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:386) org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:229) org.apache.struts.action.ActionServlet.process(ActionServlet.java:1194) org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:414) javax.servlet.http.HttpServlet.service(HttpServlet.java:689) javax.servlet.http.HttpServlet.service(HttpServlet.java:802) БОЛЬШОЕ СПАСИБО! ... |
| 25.10.2007, 19:21:10 |
start [/forum/topic.php?desktop=1&fid=59&tid=2144230]: |
27ms |
50ms |
26ms |
90ms |
| others: | 381ms |
| total: | 617ms |
