Jar - проблема с запуском
C:\Documents and Settings\v.plotnikov\Рабочий стол\JavaReports_ITC\lib>java -cp Ranges.jar;poi-3.0.1-FINAL-20070705.jar;ojdbc14dms.jar;dms.jar design.Main_class Exception in thread "main" java.lang.UnsupportedClassVersionError: design/Main_c lass (Unsupported major.minor version 49.0) at java.lang.ClassLoader.defineClass0(Native Method) at java.lang.ClassLoader.defineClass(Unknown Source) at java.security.SecureClassLoader.defineClass(Unknown Source) at java.net.URLClassLoader.defineClass(Unknown Source) at java.net.URLClassLoader.access$100(Unknown Source) at java.net.URLClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClassInternal(Unknown Source) Когда прописываю JAVA_HOME = .../jdk и в path путь к .../jdk/bin запускается нормально, но хотелось бы обойтись без копирования JDK ... |
| 25.10.2007, 18:54:14 |
start [/forum/topic.php?desktop=1&fid=59&tid=2144229]: |
44ms |
39ms |
| others: | 337ms |
| total: | 477ms |
