Glassfish и TransactionRolledbackLocalException
Сделал вот таким - 12076295 - образом. При нажатии на кнопку "save" в консоли вываливается следующая ошибка: авторCaused by: javax.ejb.EJBTransactionRolledbackException at com.sun.ejb.containers.BaseContainer.mapLocal3xException(BaseContainer.java:2305) at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:2088) at com.sun.ejb.containers.BaseContainer.postInvoke(BaseContainer.java:1990) at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:222) at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88) at $Proxy279.findAll(Unknown Source) at ru.vac.pagecode.cl.InsCompany.getInsList(InsCompany.java:31) at sun.reflect.GeneratedMethodAccessor286.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at javax.el.BeanELResolver.getValue(BeanELResolver.java:302) at com.sun.faces.el.DemuxCompositeELResolver._getValue(DemuxCompositeELResolver.java:176) at com.sun.faces.el.DemuxCompositeELResolver.getValue(DemuxCompositeELResolver.java:203) at com.sun.el.parser.AstValue.getValue(AstValue.java:116) at com.sun.el.parser.AstValue.getValue(AstValue.java:163) at com.sun.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:219) at com.sun.faces.facelets.el.TagValueExpression.getValue(TagValueExpression.java:109) ... 51 more Caused by: javax.ejb.TransactionRolledbackLocalException: Client's transaction aborted at com.sun.ejb.containers.BaseContainer.useClientTx(BaseContainer.java:4699) at com.sun.ejb.containers.BaseContainer.preInvokeTx(BaseContainer.java:4577) at com.sun.ejb.containers.BaseContainer.preInvoke(BaseContainer.java:1910) at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:212) ... 64 more findAll - это метод в ejb: Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Причем, во всех остальных случаях он работает идеально, а именно в этом отваливается с вышеобозначенной ошибкой. ... |
| 12.02.2012, 10:19:30 |
amigaboy_ , приведите полный stacktrace. В том, что вы привели, лишь последствия - EJBTransactionRolledbackException, но нет информации о причине возникновения исключения... ... |
| 12.02.2012, 16:50:10 |
Ruslan.Isbarov amigaboy_ , приведите полный stacktrace. В том, что вы привели, лишь последствия - EJBTransactionRolledbackException, но нет информации о причине возникновения исключения...Да все дело в том, что скорее всего роллбак случился раньше, но неправильная обработка исключений не позволила его заметить. То есть где-то в другом месте кода вылетевший Runtime-экспешн пересек границу прокси, вызвал роллбак, но был где-то "съеден" - например, его вывели в логгер, но не прокинули дальше. И все - транзакция откачена, но про это никто не знает. ... |
| 12.02.2012, 17:40:44 |
start [/forum/topic.php?desktop=1&fid=59&tid=2132586]: |
25ms |
301ms |
69ms |
| others: | 334ms |
| total: | 779ms |
