Печать и кодировка
Добрый день имеется термальный принтер TM200 пытаюсь распечатать на нем русский текст, но выходят кракозябры... Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. пробовал во многих кодировках бестолку "ASCII", "ISO8859_1","ISO8859_2","ISO8859_3","ISO8859_4","ISO8859_5", "ISO8859_6","ISO8859_7","ISO8859_8","ISO8859_9", "Big5", "Cp037", "Cp1006" ,"Cp1025","Cp1026","Cp1046","Cp1097","Cp1098", "Cp1112" ,"Cp1122","Cp1123","Cp1124", "Cp1250" ,"Cp1251","Cp1252","Cp1253","Cp1254","Cp1255", "Cp1256" ,"Cp1257","Cp1258","Cp1381","Cp1383", "Cp273" ,"Cp277" ,"Cp278" ,"Cp280" ,"Cp284" ,"Cp285","Cp297", "Cp33722","Cp420" ,"Cp424" ,"Cp437" ,"Cp500" ,"Cp737","Cp775", "Cp838" ,"Cp850" ,"Cp852" ,"Cp855" ,"Cp857" , "Cp860" ,"Cp861" ,"Cp862" ,"Cp863" ,"Cp864" ,"Cp865", "Cp866" ,"Cp868" ,"Cp869" ,"Cp870" ,"Cp871" ,"Cp874","Cp875", "Cp918" ,"Cp921" ,"Cp922" ,"Cp930" ,"Cp933" ,"Cp935","Cp937","Cp939", "Cp942" ,"Cp948" ,"Cp949" ,"Cp950" ,"Cp964" ,"Cp970", "EUC_CN","EUC_JP","EUC_KR","EUC_TW", "GBK", "ISO2022CN_CNS","ISO2022JP","ISO2022KR", "JIS0201","JIS0208","JIS0212", "KOI8_R", "MS874", "MacArabic","MacCentralEurope","MacCroatian","MacCyrillic", "MacDingbat","MacGreek","MacHebrew","MacIceland","MacRoman", "MacRomania","MacSymbol","MacThai","MacTurkish","MacUkraine", "SJIS", "UTF8","UTF-16","UnicodeBig","UnicodeLittle" java класс в кодировке UTF-8 прошу вашей помощи, заранее спасибо. ... |
| 21.06.2012, 00:18:50 |
Печать и кодировка
supported doc flavors Код: html 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. ... |
| 21.06.2012, 00:20:29 |
Печать и кодировка
у него в спецификации Character set: 95 Alphanumeric; 32 International; 128x7 graphics может, в него загрузить чо надо? ... |
| 21.06.2012, 10:44:32 |
Печать и кодировка
grasoff.netу него в спецификации Character set: 95 Alphanumeric; 32 International; 128x7 graphics может, в него загрузить чо надо? извиняюсь за глупый вопрос, а что в него загрузить если мне надо русский текст? ... |
| 21.06.2012, 16:06:48 |
Печать и кодировка
J2SE, Если аппаратные ресурсы позволяют, сделайте растр и печатайте картинками. ... |
| 21.06.2012, 19:00:31 |
Печать и кодировка
Лагман, очень не хотелось таким способом, но видать придется им Благодарю. ... |
| 21.06.2012, 23:25:49 |
Печать и кодировка
J2SEизвиняюсь за глупый вопрос, а что в него загрузить если мне надо русский текст? Например, во времена MS-DOS были матричные принтеры, которые не умели печатать по-русски, надо было в них предварительно загружать руссские шрифты. Естесственно, при выключении принтер всё забывал и надо было повторять эту процедуру при каждом его включении. Может у вас похожий случай? ... |
| 22.06.2012, 08:33:01 |
Печать и кодировка
J2SEа что в него загрузить если мне надо русский текст?наверное, можно как-то управлять тем - что именно за 32 international символа там. может, их можно загружать в этот принтер. ... |
| 22.06.2012, 10:46:42 |
Печать и кодировка
этот принтер должен поддерживать Cp866. почитайте документацию , как сменить. или обратитесь в сервисный центр. ... |
| 22.06.2012, 11:38:47 |
start [/forum/topic.php?desktop=1&fid=59&tid=2131507]: |
26ms |
63ms |
86ms |
| others: | 349ms |
| total: | 584ms |
