Restlet vs Jarsey
Подскажите плиз в чем принципиальная разница Restlet vs Jarsey? ... |
| 22.09.2012, 20:04:23 |
Restlet vs Jarsey
oson, http://stackoverflow.com/questions/3459795/how-to-choose-between-jersey-apache-wink-and-jboss-resteasy JAX-RS Implementations Jersey Reference Implementation Usually the most cutting edge Supports true asynchronous (ie web sockets etc...) connections through either Atmosphere or 2.0 version. Has support for Spring and standard injection containers (ie @Inject). Glassfish bundles it. Does not require a servlet container. Its much more modular than the other JAX-RS projects. It has a kick ass URI Builder Does not necessarily require servlet container. Grizzly support Netty support (very early). ... Restlet Very powerful but very complicated Provides some low-level REST support Does not require a servlet container ... ... |
| 27.09.2012, 20:36:10 |
start [/forum/topic.php?desktop=1&fid=59&tid=2130848]: |
65ms |
67ms |
| others: | 338ms |
| total: | 548ms |
