nuzhna pomos4 po spring+hiber
v logah oshibka: ERROR: org.springframework.web.context.ContextLoader - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'contactDAOImpl': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.hibernate.SessionFactory org.home.contactmanager.dao.ContactDAOImpl.sessionFactory; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at.. pereproveril konfigi DB i tak.. telnet na port database_server, vsyo normal6no.. gde posmotret6 es4o i 4to? =) ... |
| 04.10.2012, 11:27:36 |
.. Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1455) .. i t.d. ... |
| 04.10.2012, 11:29:43 |
Вы откусили и выкинули самое важное из текста ошибки. Если не можете найти суть, скопируйте сюда полностью. ... |
| 04.10.2012, 11:34:30 |
[INFO] Scanning for projects... [WARNING] [WARNING] Some problems were encountered while building the effective model for org.home:contactmanager1:war:1.0.0-BUILD-SNAPSHOT [WARNING] 'build.plugins.plugin.version' for org.mortbay.jetty:jetty-maven-plugin is missing. @ line 174, column 18 [WARNING] [WARNING] It is highly recommended to fix these problems because they threaten the stability of your build. [WARNING] [WARNING] For this reason, future Maven versions might no longer support building such malformed projects. [WARNING] [INFO] [INFO] ------------------------------------------------------------------------ [INFO] Building ContactManager 1.0.0-BUILD-SNAPSHOT [INFO] ------------------------------------------------------------------------ [INFO] [INFO] >>> jetty-maven-plugin:8.1.7.v20120910:run (default-cli) @ contactmanager1 >>> [INFO] [INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ contactmanager1 --- [debug] execute contextualize [WARNING] Using platform encoding (Cp1252 actually) to copy filtered resources, i.e. build is platform dependent! [INFO] Copying 4 resources [INFO] [INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ contactmanager1 --- [INFO] Nothing to compile - all classes are up to date [INFO] [INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ contactmanager1 --- [debug] execute contextualize [WARNING] Using platform encoding (Cp1252 actually) to copy filtered resources, i.e. build is platform dependent! [INFO] Copying 1 resource [INFO] [INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ contactmanager1 --- [INFO] Nothing to compile - all classes are up to date [INFO] [INFO] <<< jetty-maven-plugin:8.1.7.v20120910:run (default-cli) @ contactmanager1 <<< [INFO] [INFO] --- jetty-maven-plugin:8.1.7.v20120910:run (default-cli) @ contactmanager1 --- [INFO] Configuring Jetty for project: ContactManager [INFO] webAppSourceDirectory C:\jtty\wrk\ContactManager\src\main\webapp does not exist. Defaulting to C:\jtty\wrk\ContactManager\src\main\webapp [INFO] Reload Mechanic: automatic [INFO] Classes = C:\jtty\wrk\ContactManager\target\classes [INFO] Context path = / [INFO] Tmp directory = C:\jtty\wrk\ContactManager\target\tmp [INFO] Web defaults = org/eclipse/jetty/webapp/webdefault.xml [INFO] Web overrides = none [INFO] web.xml file = file:/C:/jtty/wrk/ContactManager/src/main/webapp/WEB-INF/web.xml [INFO] Webapp directory = C:\jtty\wrk\ContactManager\src\main\webapp 2012-10-04 00:12:08.296:INFO:oejs.Server:jetty-8.1.7.v20120910 2012-10-04 00:12:09.843:INFO:oejpw.PlusConfiguration:No Transaction manager found - if your webapp requires one, please configure one. 2012-10-04 00:12:14.828:INFO:/:No Spring WebApplicationInitializer types detected on classpath 2012-10-04 00:12:15.453:INFO:oejsh.ContextHandler:started o.m.j.p.JettyWebAppContext{/,file:/C:/jtty/wrk/ContactManager/src/main/webapp/},file:/C:/jtty/wrk/ContactManager/src/main/webapp/ 2012-10-04 00:12:15.453:INFO:oejsh.ContextHandler:started o.m.j.p.JettyWebAppContext{/,file:/C:/jtty/wrk/ContactManager/src/main/webapp/},file:/C:/jtty/wrk/ContactManager/src/main/webapp/ 2012-10-04 00:12:15.453:INFO:oejsh.ContextHandler:started o.m.j.p.JettyWebAppContext{/,file:/C:/jtty/wrk/ContactManager/src/main/webapp/},file:/C:/jtty/wrk/ContactManager/src/main/webapp/ 2012-10-04 00:12:15.546:INFO:/:Initializing Spring root WebApplicationContext INFO : org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started INFO : org.springframework.web.context.support.XmlWebApplicationContext - Refreshing Root WebApplicationContext: startup date [Thu Oct 04 00:12:15 PDT 2012]; root of context hierarchy INFO : org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/spring/root-context.xml] INFO : org.springframework.context.annotation.ClassPathBeanDefinitionScanner - JSR-250 'javax.annotation.ManagedBean' found and supported for component scanning INFO : org.springframework.context.annotation.ClassPathBeanDefinitionScanner - JSR-330 'javax.inject.Named' annotation found and supported for component scanning INFO : org.springframework.context.annotation.ClassPathBeanDefinitionScanner - JSR-250 'javax.annotation.ManagedBean' found and supported for component scanning INFO : org.springframework.context.annotation.ClassPathBeanDefinitionScanner - JSR-330 'javax.inject.Named' annotation found and supported for component scanning INFO : org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/spring/data.xml] INFO : org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/spring/security.xml] INFO : org.springframework.beans.factory.config.PropertyPlaceholderConfigurer - Loading properties file from ServletContext resource [/WEB-INF/jdbc.properties] INFO : org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor - JSR-330 'javax.inject.Inject' annotation found and supported for autowiring INFO : org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@350967a6: defining beans [org.springframework.context.annotation.internalConfigurationAnnotationProcessor,org.springframework.context.annotation.internalAutowiredAnnotationProcessor,org.springframework.context.annotation.internalRequiredAnnotationProcessor,org.springframework.context.annotation.internalCommonAnnotationProcessor,org.springframework.context.annotation.internalPersistenceAnnotationProcessor,contactDAOImpl,contactServiceImpl,org.springframework.aop.config.internalAutoProxyCreator,org.springframework.transaction.annotation.AnnotationTransactionAttributeSource#0,org.springframework.transaction.interceptor.TransactionInterceptor#0,org.springframework.transaction.config.internalTransactionAdvisor,transactionManager,messageSource,propertyConfigurer,dataSource,sessionFactory,org.springframework.context.annotation.ConfigurationClassPostProcessor$ImportAwareBeanPostProcessor#0]; root of factory hierarchy WARN : org.hibernate.internal.util.xml.DTDEntityResolver - HHH000223: Recognized obsolete hibernate namespace http://hibernate.sourceforge.net/. Use namespace http://www.hibernate.org/dtd/ instead. Refer to Hibernate 3.6 Migration Guide! INFO : org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@350967a6: defining beans [org.springframework.context.annotation.internalConfigurationAnnotationProcessor,org.springframework.context.annotation.internalAutowiredAnnotationProcessor,org.springframework.context.annotation.internalRequiredAnnotationProcessor,org.springframework.context.annotation.internalCommonAnnotationProcessor,org.springframework.context.annotation.internalPersistenceAnnotationProcessor,contactDAOImpl,contactServiceImpl,org.springframework.aop.config.internalAutoProxyCreator,org.springframework.transaction.annotation.AnnotationTransactionAttributeSource#0,org.springframework.transaction.interceptor.TransactionInterceptor#0,org.springframework.transaction.config.internalTransactionAdvisor,transactionManager,messageSource,propertyConfigurer,dataSource,sessionFactory,org.springframework.context.annotation.ConfigurationClassPostProcessor$ImportAwareBeanPostProcessor#0]; root of factory hierarchy ERROR: org.springframework.web.context.ContextLoader - Context initialization failed org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'contactDAOImpl': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.hibernate.SessionFactory org.home.contactmanager.dao.ContactDAOImpl.sessionFactory; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:287) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.hibernate.SessionFactory org.home.contactmanager.dao.ContactDAOImpl.sessionFactory; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:506) at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284) ... 55 more Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1455) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848) at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790) at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478) ... 57 more Caused by: org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:186) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:150) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.buildJdbcConnectionAccess(JdbcServicesImpl.java:223) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:89) at org.hibernate.service.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:75) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:159) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:73) at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2283) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2279) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1748) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1788) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:860) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:779) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1514) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1452) ... 67 more Caused by: org.hibernate.HibernateException: Could not instantiate connection provider [org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider] at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.instantiateExplicitConnectionProvider(ConnectionProviderInitiator.java:192) at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.initiateService(ConnectionProviderInitiator.java:114) at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.initiateService(ConnectionProviderInitiator.java:54) at org.hibernate.service.internal.StandardServiceRegistryImpl.initiateService(StandardServiceRegistryImpl.java:69) at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:176) ... 84 more Caused by: java.lang.ClassCastException: org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider cannot be cast to org.hibernate.service.jdbc.connections.spi.ConnectionProvider at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.instantiateExplicitConnectionProvider(ConnectionProviderInitiator.java:189) ... 88 more 2012-10-04 00:12:17.375:WARN:oejw.WebAppContext:Failed startup of context o.m.j.p.JettyWebAppContext{/,file:/C:/jtty/wrk/ContactManager/src/main/webapp/},file:/C:/jtty/wrk/ContactManager/src/main/webapp/ org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'contactDAOImpl': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.hibernate.SessionFactory org.home.contactmanager.dao.ContactDAOImpl.sessionFactory; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:287) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.hibernate.SessionFactory org.home.contactmanager.dao.ContactDAOImpl.sessionFactory; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:506) at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in ServletContext resource [/WEB-INF/spring/data.xml]: Invocation of init method failed; nested exception is org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1455) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848) at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790) at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478) at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.hibernate.service.spi.ServiceException: Unable to create requested service [org.hibernate.service.jdbc.connections.spi.ConnectionProvider] at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:186) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:150) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.buildJdbcConnectionAccess(JdbcServicesImpl.java:223) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:89) at org.hibernate.service.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:75) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:159) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:73) at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2283) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2279) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1748) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1788) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:860) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:779) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1514) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1452) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848) at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790) at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478) at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: org.hibernate.HibernateException: Could not instantiate connection provider [org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider] at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.instantiateExplicitConnectionProvider(ConnectionProviderInitiator.java:192) at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.initiateService(ConnectionProviderInitiator.java:114) at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.initiateService(ConnectionProviderInitiator.java:54) at org.hibernate.service.internal.StandardServiceRegistryImpl.initiateService(StandardServiceRegistryImpl.java:69) at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:176) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:150) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.buildJdbcConnectionAccess(JdbcServicesImpl.java:223) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:89) at org.hibernate.service.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:75) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:159) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:73) at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2283) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2279) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1748) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1788) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:860) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:779) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1514) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1452) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848) at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790) at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478) at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) Caused by: java.lang.ClassCastException: org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider cannot be cast to org.hibernate.service.jdbc.connections.spi.ConnectionProvider at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.instantiateExplicitConnectionProvider(ConnectionProviderInitiator.java:189) at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.initiateService(ConnectionProviderInitiator.java:114) at org.hibernate.service.jdbc.connections.internal.ConnectionProviderInitiator.initiateService(ConnectionProviderInitiator.java:54) at org.hibernate.service.internal.StandardServiceRegistryImpl.initiateService(StandardServiceRegistryImpl.java:69) at org.hibernate.service.internal.AbstractServiceRegistryImpl.createService(AbstractServiceRegistryImpl.java:176) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:150) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.buildJdbcConnectionAccess(JdbcServicesImpl.java:223) at org.hibernate.engine.jdbc.internal.JdbcServicesImpl.configure(JdbcServicesImpl.java:89) at org.hibernate.service.internal.StandardServiceRegistryImpl.configureService(StandardServiceRegistryImpl.java:75) at org.hibernate.service.internal.AbstractServiceRegistryImpl.initializeService(AbstractServiceRegistryImpl.java:159) at org.hibernate.service.internal.AbstractServiceRegistryImpl.getService(AbstractServiceRegistryImpl.java:131) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:73) at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2283) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2279) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1748) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1788) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:860) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:779) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1514) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1452) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848) at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790) at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478) at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87) at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:384) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:283) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111) at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771) at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:411) at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763) at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:247) at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1238) at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706) at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:480) at org.mortbay.jetty.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:293) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:95) at org.eclipse.jetty.server.Server.doStart(Server.java:277) at org.mortbay.jetty.plugin.JettyServer.doStart(JettyServer.java:65) at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64) at org.mortbay.jetty.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:511) at org.mortbay.jetty.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:364) at org.mortbay.jetty.plugin.JettyRunMojo.execute(JettyRunMojo.java:516) at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153) at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84) at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59) at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183) at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161) at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320) at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156) at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537) at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196) at org.apache.maven.cli.MavenCli.main(MavenCli.java:141) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290) at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230) at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409) at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352) 2012-10-04 00:12:17.437:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:8080 [INFO] Started Jetty Server ... |
| 04.10.2012, 11:49:01 |
nuzhna pomos4 po spring+hiber
web.xml <web-app xmlns=" http://java.sun.com/xml/ns/javaee" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" version="2.5" xsi:schemaLocation=" http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd"> <context-param> <param-name>contextConfigLocation</param-name> <param-value>/WEB-INF/spring/root-context.xml</param-value> </context-param> <listener> <listener-class> org.springframework.web.context.ContextLoaderListener </listener-class> </listener> <servlet> <servlet-name>appServlet</servlet-name> <servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class> <init-param> <param-name>contextConfigLocation</param-name> <param-value>/WEB-INF/spring/appServlet/servlet-context.xml</param-value> </init-param> <load-on-startup>1</load-on-startup> </servlet> <servlet-mapping> <servlet-name>appServlet</servlet-name> <url-pattern>/</url-pattern> </servlet-mapping> <filter> <filter-name>charsetFilter</filter-name> <filter-class> org.springframework.web.filter.CharacterEncodingFilter </filter-class> <init-param> <param-name>encoding</param-name> <param-value>UTF-8</param-value> </init-param> <init-param> <param-name>forceEncoding</param-name> <param-value>true</param-value> </init-param> </filter> <filter-mapping> <filter-name>charsetFilter</filter-name> <url-pattern>/*</url-pattern> </filter-mapping> </web-app> root-context.xml <beans xmlns=" http://www.springframework.org/schema/beans" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:aop=" http://www.springframework.org/schema/aop" xmlns:context=" http://www.springframework.org/schema/context" xmlns:jee=" http://www.springframework.org/schema/jee" xmlns:lang=" http://www.springframework.org/schema/lang" xmlns:p=" http://www.springframework.org/schema/p" xmlns:tx=" http://www.springframework.org/schema/tx" xmlns:util=" http://www.springframework.org/schema/util" xsi:schemaLocation=" http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd http://www.springframework.org/schema/aop http://www.springframework.org/schema/aop/spring-aop.xsd http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context.xsd http://www.springframework.org/schema/jee http://www.springframework.org/schema/jee/spring-jee.xsd http://www.springframework.org/schema/lang http://www.springframework.org/schema/lang/spring-lang.xsd http://www.springframework.org/schema/tx http://www.springframework.org/schema/tx/spring-tx.xsd http://www.springframework.org/schema/util http://www.springframework.org/schema/util/spring-util.xsd"> <context:annotation-config/> <context:component-scan base-package="org.home.contactmanager.dao"/> <context:component-scan base-package="org.home.contactmanager.service"/> <import resource="data.xml"/> <import resource="security.xml"/> </beans> data.xml <beans xmlns=" http://www.springframework.org/schema/beans" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:aop=" http://www.springframework.org/schema/aop" xmlns:context=" http://www.springframework.org/schema/context" xmlns:jee=" http://www.springframework.org/schema/jee" xmlns:lang=" http://www.springframework.org/schema/lang" xmlns:p=" http://www.springframework.org/schema/p" xmlns:tx=" http://www.springframework.org/schema/tx" xmlns:util=" http://www.springframework.org/schema/util" xsi:schemaLocation=" http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd http://www.springframework.org/schema/aop http://www.springframework.org/schema/aop/spring-aop.xsd http://www.springframework.org/schema/jee http://www.springframework.org/schema/jee/spring-jee.xsd http://www.springframework.org/schema/lang http://www.springframework.org/schema/lang/spring-lang.xsd http://www.springframework.org/schema/tx http://www.springframework.org/schema/tx/spring-tx.xsd http://www.springframework.org/schema/util http://www.springframework.org/schema/util/spring-util.xsd"> <tx:annotation-driven transaction-manager="transactionManager"/> <bean id="transactionManager" class="org.springframework.orm.hibernate3.HibernateTransactionManager"> <property name="sessionFactory" ref="sessionFactory"/> </bean> <bean id="messageSource" class="org.springframework.context.support.ReloadableResourceBundleMessageSource"> <property name="basename" value="classpath:messages"/> <property name="defaultEncoding" value="UTF-8"/> </bean> <bean id="propertyConfigurer" class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer" p:location="/WEB-INF/jdbc.properties"/> <bean id="dataSource" class="org.springframework.jdbc.datasource.DriverManagerDataSource" p:driverClassName="${jdbc.driverClassName}" p:url="${jdbc.databaseurl}" p:username="${jdbc.username}" p:password="${jdbc.password}"/> <bean id="sessionFactory" class="org.springframework.orm.hibernate3.LocalSessionFactoryBean"> <property name="dataSource" ref="dataSource"/> <property name="configLocation"> <value>classpath:hibernate.cfg.xml</value> </property> <property name="configurationClass"> <value>org.hibernate.cfg.AnnotationConfiguration</value> </property> <property name="hibernateProperties"> <props> <prop key="hibernate.show_sql">true</prop> <prop key="hibernate.dialect">${jdbc.dialect}</prop> <prop key="hibernate.connection.charSet">UTF-8</prop> </props> </property> </bean> </beans> servlet-context.xml <?xml version="1.0" encoding="UTF-8" ?> <beans:beans xmlns=" http://www.springframework.org/schema/mvc" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:beans=" http://www.springframework.org/schema/beans" xsi:schemaLocation=" http://www.springframework.org/schema/mvc http://www.springframework.org/schema/mvc/spring-mvc-3.0.xsd http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-3.0.xsd"> <annotation-driven /> <resources mapping="/resources/**" location="/resources/" /> <beans:bean class="org.springframework.web.servlet.view.InternalResourceViewResolver"> <beans:property name="prefix" value="/WEB-INF/views/" /> <beans:property name="suffix" value=".jsp" /> </beans:bean> <beans:import resource="controllers.xml" /> </beans:beans> hibernate.cfg.xml <?xml version='1.0' encoding='utf-8'?> <!DOCTYPE hibernate-configuration PUBLIC "-//Hibernate/Hibernate Configuration DTD//EN" " http://hibernate.sourceforge.net/hibernate-configuration-3.0.dtd"> <hibernate-configuration> <session-factory> <mapping class="org.home.contactmanager.domain.Contact" /> </session-factory> </hibernate-configuration> ... |
| 04.10.2012, 11:53:39 |
<?xml version="1.0" encoding="UTF-8"?> <project xmlns=" http://maven.apache.org/POM/4.0.0" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd"> <modelVersion>4.0.0</modelVersion> <groupId>org.taranov</groupId> <artifactId>contactmanager1</artifactId> <name>ContactManager</name> <packaging>war</packaging> <version>1.0.0-BUILD-SNAPSHOT</version> <properties> <java-version>1.6</java-version> <org.springframework-version>3.1.0.RELEASE</org.springframework-version> <org.aspectj-version>1.6.9</org.aspectj-version> <org.slf4j-version>1.5.10</org.slf4j-version> </properties> <dependencies> <!-- Spring --> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-context</artifactId> <version>${org.springframework-version}</version> <exclusions> <!-- Exclude Commons Logging in favor of SLF4j --> <exclusion> <groupId>commons-logging</groupId> <artifactId>commons-logging</artifactId> </exclusion> </exclusions> </dependency> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-webmvc</artifactId> <version>${org.springframework-version}</version> </dependency> <!-- AspectJ --> <dependency> <groupId>org.aspectj</groupId> <artifactId>aspectjrt</artifactId> <version>${org.aspectj-version}</version> </dependency> <!-- Logging --> <dependency> <groupId>org.slf4j</groupId> <artifactId>slf4j-api</artifactId> <version>${org.slf4j-version}</version> </dependency> <dependency> <groupId>org.slf4j</groupId> <artifactId>jcl-over-slf4j</artifactId> <version>${org.slf4j-version}</version> <scope>runtime</scope> </dependency> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-tx</artifactId> <version>${org.springframework-version}</version> </dependency> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-orm</artifactId> <version>${org.springframework-version}</version> </dependency> <dependency> <groupId>org.slf4j</groupId> <artifactId>slf4j-log4j12</artifactId> <version>${org.slf4j-version}</version> <scope>runtime</scope> </dependency> <dependency> <groupId>log4j</groupId> <artifactId>log4j</artifactId> <version>1.2.15</version> <exclusions> <exclusion> <groupId>javax.mail</groupId> <artifactId>mail</artifactId> </exclusion> <exclusion> <groupId>javax.jms</groupId> <artifactId>jms</artifactId> </exclusion> <exclusion> <groupId>com.sun.jdmk</groupId> <artifactId>jmxtools</artifactId> </exclusion> <exclusion> <groupId>com.sun.jmx</groupId> <artifactId>jmxri</artifactId> </exclusion> </exclusions> <scope>runtime</scope> </dependency> <!-- @Inject --> <dependency> <groupId>javax.inject</groupId> <artifactId>javax.inject</artifactId> <version>1</version> </dependency> <!-- Servlet --> <dependency> <groupId>javax.servlet</groupId> <artifactId>servlet-api</artifactId> <version>2.5</version> <scope>provided</scope> </dependency> <dependency> <groupId>javax.servlet.jsp</groupId> <artifactId>jsp-api</artifactId> <version>2.1</version> <scope>provided</scope> </dependency> <dependency> <groupId>javax.servlet</groupId> <artifactId>jstl</artifactId> <version>1.2</version> </dependency> <!-- Test --> <dependency> <groupId>junit</groupId> <artifactId>junit</artifactId> <version>4.7</version> <scope>test</scope> </dependency> <dependency> <groupId>javax.persistence</groupId> <artifactId>persistence-api</artifactId> <version>1.0.2</version> </dependency> <dependency> <groupId>org.hibernate</groupId> <artifactId>hibernate-core</artifactId> <version>4.1.7.Final</version> </dependency> <dependency> <groupId>org.hibernate</groupId> <artifactId>hibernate-annotations</artifactId> <version>3.5.6-Final</version> </dependency> <dependency> <groupId>org.hibernate</groupId> <artifactId>hibernate-commons-annotations</artifactId> <version>3.3.0.ga</version> </dependency> <dependency> <groupId>mysql</groupId> <artifactId>mysql-connector-java</artifactId> <version>5.1.21</version> </dependency> <dependency> <groupId>org.springframework</groupId> <artifactId>spring-jpa</artifactId> <version>2.0.8</version> </dependency> <dependency> <groupId>javax.transaction</groupId> <artifactId>transaction-api</artifactId> <version>1.1-rev-1</version> </dependency> </dependencies> <build> <finalName>contactmanager</finalName> <plugins> <plugin> <artifactId>maven-war-plugin</artifactId> <version>2.1.1</version> <configuration> <packagingExcludes>WEB-INF/web.xml</packagingExcludes> </configuration> </plugin> <plugin> <groupId>org.mortbay.jetty</groupId> <artifactId>jetty-maven-plugin</artifactId> </plugin> <plugin> <artifactId>maven-eclipse-plugin</artifactId> <version>2.9</version> <configuration> <additionalProjectnatures> <projectnature>org.springframework.ide.eclipse.core.springnature</projectnature> </additionalProjectnatures> <additionalBuildcommands> <buildcommand>org.springframework.ide.eclipse.core.springbuilder</buildcommand> </additionalBuildcommands> <downloadSources>true</downloadSources> <downloadJavadocs>true</downloadJavadocs> </configuration> </plugin> <plugin> <groupId>org.apache.maven.plugins</groupId> <artifactId>maven-compiler-plugin</artifactId> <version>2.3.2</version> <configuration> <source>1.6</source> <target>1.6</target> <compilerArgument>-Xlint:all</compilerArgument> <showWarnings>true</showWarnings> <showDeprecation>true</showDeprecation> </configuration> </plugin> </plugins> </build> </project> ... |
| 04.10.2012, 11:54:47 |
Caused by: org.hibernate.HibernateException: Could not instantiate connection provider [org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider] ... |
| 04.10.2012, 11:59:18 |
Caused by: java.lang.ClassCastException: org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider cannot be cast to org.hibernate.service.jdbc.connections.spi.ConnectionProvider ne mozhet tip6l privesti... 4itayu dal6she) ... |
| 04.10.2012, 12:00:18 |
versiya hibera? ne 4-ya dolzhna b6lt6, da? ... |
| 04.10.2012, 12:06:28 |
super/// Caused by: java.lang.IncompatibleClassChangeError kuda posmotret6? ... |
| 04.10.2012, 12:16:40 |
Хибер 4й версии, а Spring интеграция для 3й. ... |
| 04.10.2012, 12:49:14 |
kT_________super/// Caused by: java.lang.IncompatibleClassChangeError kuda posmotret6? Это откуда7 ... |
| 04.10.2012, 12:49:23 |
Blazkowicz, eto esli v pom.xml ukazat6 versiyu hibernate 3.x.x vmesto ukazannoy ranee 4.x.x ya pravil6no ponyal 4to hiber 4 i spring 3 sovmestim6l? ... |
| 04.10.2012, 12:57:02 |
kT_________eto esli v pom.xml ukazat6 versiyu hibernate 3.x.x vmesto ukazannoy ranee 4.x.x Вы снова обрезали исключение до неинформативного состояния. kT_________ya pravil6no ponyal 4to hiber 4 i spring 3 sovmestim6l? http://blog.springsource.org/2012/04/06/migrating-to-spring-3-1-and-hibernate-4-1/ ... |
| 04.10.2012, 13:00:04 |
za s6lLku spasibo/ oznakomilsya. sklonen s4itat6 4to farsh b6lL v pom.xml, konkretno s versiyami. dopilil pom.xml WARN : org.hibernate.util.JDBCExceptionReporter - SQL Error: 1045, SQLState: 28000 ERROR: org.hibernate.util.JDBCExceptionReporter - Access denied for user 'contactmanager'@'192.168.80.1' (using password: YES) WARN : org.hibernate.cfg.SettingsFactory - Could not obtain connection to query metadata ja ))) dal6she ya sam. spasibo bol6shoe za pomos46 ... |
| 04.10.2012, 13:39:01 |
start [/forum/topic.php?desktop=1&fid=59&tid=2130844]: |
23ms |
56ms |
74ms |
| others: | 290ms |
| total: | 490ms |
