scripting-invalid в web.xml
Неясно с автор# QUESTION 13: Given the web application deployment descriptor: 1 <jsp-config> 2 <jsp-property-group> 3 <url-pattern>*.jsp</url-pattern> 4 <scripting-invalid>false</scripting-invalid> 5 </jsp-property-group> 6 </jsp-config> andexample.jsp: 10 x 5 = ${10 * 5}<br> 2 * 3 = <%= 2 * 3 %><br> What is the result? A. An error occurs during page translation. B. Translation is successful, but nothing is included in the response. C. Both "10 x 5 = 50" and "2 * 3 = 6" are included in the JSP response. D. The text "10 x 5 = 50" is included in the JSP response, but "2 * 3 = 6" is NOT. E. The text "2 * 3 = 6" is included in the JSP response, but "10 x 5 = 50" is NOT. ответ авторC. Both "10 x 5 = 50" and "2 * 3 = 6" are included in the JSP response и сам попробовал и получил. Но ведь мы отключаем авторTag name: scripting-invalid Description : Can be used to easily disable scripting in a group of JSP pages. By default, scripting is enabled. ... |
| 07.12.2012, 19:27:43 |
ccoder, а в заголовке страницы что? Может там переопределен? ... |
| 07.12.2012, 19:30:32 |
scripting-invalid контролирует валидацию чтобы не использовался код вида. <%= 2 * 3 %> scripting-invalid=false значит валидация отключена. EL и scripting можно. scripting-invalid=true значит валидация включена. EL можно. scripting - нельзя. ... |
| 07.12.2012, 19:41:22 |
start [/forum/topic.php?desktop=1&fid=59&tid=2130405]: |
23ms |
48ms |
61ms |
| others: | 350ms |
| total: | 532ms |
