Помогите написать программу!
You should implement a simple directory viewer, which should be made by requerements: 1) Directory viewer have a simple UI, which allows user to specify any directory path and should have a button “Build a directory tree”; 2) After pressing of “Build a directory tree” button you application should build a tree of objects in memory. Each element in file system will be a separate node in the tree of objects. Your application also should print your objects tree into xml file; 3) XML file should have the next structure: <directory name=”Some.root.name”> <directory name=”name1”> <file name=”notes1” extention=”txt” /> <file name=”notes2” extention=”txt” /> <file name=”notes3” extention=”txt” /> </directory> <file name=”photo” extention=”jpg” /> </directory> ... |
| 31.01.2013, 13:30:53 |
10% от следующей годовой зарплаты. ... |
| 31.01.2013, 13:38:13 |
Leonidv, ну хоть наведи пример. ... |
| 31.01.2013, 13:41:17 |
start [/forum/topic.php?desktop=1&fid=59&tid=2130078]: |
35ms |
33ms |
| others: | 312ms |
| total: | 426ms |
