HS @AnalyzerDiscriminator
Возможно ли как-то совместить использование @AnalyzerDiscriminator и @Analyzer(impl = Analyzer.class), т.е. не использовать @AnalyzerDef ? docThe prerequisite for using @AnalyzerDiscriminator is that all analyzers which are going to be used dynamically are predefined via @AnalyzerDef definitions. If this is the case, one can place the @AnalyzerDiscriminator annotation either on the class or on a specific property of the entity for which to dynamically select an analyzer. ... |
| 04.07.2013, 14:53:35 |
start [/forum/topic.php?desktop=1&fid=59&tid=2129053]: |
54ms |
54ms |
| others: | 286ms |
| total: | 452ms |
