Форумы / Java [игнор отключен] [закрыт для гостей] / Netty. Few questions about Echo Object Server.
6 сообщений из 6, страница 1 из 1
    #38382482
eldarkaa
Продолжаю пытаться сделать сетевую mini - игру по TCP/IP протоколу.
Code (nothing special, but it's working!)
ObjectEchoClient
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
 * Copyright 2012 The Netty Project
 * The Netty Project licenses this file to you under the Apache License,
 * version 2.0 (the "License"); you may not use this file except in compliance
 * with the License. You may obtain a copy of the License at:
 *   http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
 * License for the specific language governing permissions and limitations
 * under the License.
package Shooter2Dv30082013;
import io.netty.bootstrap.Bootstrap;
import io.netty.channel.ChannelInitializer;
import io.netty.channel.EventLoopGroup;
import io.netty.channel.nio.NioEventLoopGroup;
import io.netty.channel.socket.SocketChannel;
import io.netty.channel.socket.nio.NioSocketChannel;
import io.netty.example.echo.EchoClient;
import io.netty.handler.codec.serialization.ClassResolvers;
import io.netty.handler.codec.serialization.ObjectDecoder;
import io.netty.handler.codec.serialization.ObjectEncoder;
 * Modification of {@link EchoClient} which utilizes Java object serialization.
public class ObjectEchoClient {
    private final String host;
    private final int port;
    private final int playerX;
    private final int playerY;
    public ObjectEchoClient(String host, int port, int playerX, int playerY) {
        this.host = host;
        this.port = port;
        this.playerX = playerX;
        this.playerY = playerY;
    public void run() throws Exception {
        EventLoopGroup group = new NioEventLoopGroup();
        try {
            Bootstrap b = new Bootstrap();
            b.group(group)
             .channel(NioSocketChannel.class)
             .handler(new ChannelInitializer<SocketChannel>() {
                @Override
                public void initChannel(SocketChannel ch) throws Exception {
                    ch.pipeline().addLast(
                            new ObjectEncoder(),
                            new ObjectDecoder(ClassResolvers.cacheDisabled(null)),
                            new ObjectEchoClientHandler(playerX, playerY));
            // Start the connection attempt.
            b.connect(host, port).sync().channel().closeFuture().sync();
        } finally {
            group.shutdownGracefully();
    public static void main(String[] args) throws Exception {
        // Print usage if no argument is specified.
        String[] news= new String[4];
        news[0]="127.0.0.1";
        news[1]="8080";
        news[2]="50";
        news[3]="100";
        // Parse options.
        final String host = news[0];
        final int port = Integer.parseInt(news[1]);
        final int player_X = Integer.parseInt(news[2]);
        final int player_Y = Integer.parseInt(news[3]);
        new ObjectEchoClient(host, port, player_X, player_Y).run();
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
import io.netty.channel.ChannelHandlerContext;
import io.netty.channel.ChannelInboundHandlerAdapter;
import java.util.logging.Level;
import java.util.logging.Logger;
 * Handler implementation for the object echo client.  It initiates the
 * ping-pong traffic between the object echo client and server by sending the
 * first message to the server.
public class ObjectEchoClientHandler extends ChannelInboundHandlerAdapter {
    private static final Logger logger = Logger.getLogger(
            ObjectEchoClientHandler.class.getName());
     * Creates a client-side handler.
    public ObjectEchoClientHandler(int Player_X, int Player_Y) {
        if (Player_X < 0) {
            throw new IllegalArgumentException(
                    "Wrong coordinates X: " + Player_X);
        this.playerX = Player_X;
        this.playerY = Player_Y;
    @Override
    public void channelActive(ChannelHandlerContext ctx) throws Exception {
        // Send the first message if this handler is a client-side handler.
        ctx.write(playerX);
        ctx.writeAndFlush(playerY);
    @Override
    public void channelRead(ChannelHandlerContext ctx, Object msg) throws Exception {
        // Echo back the received object to the server.
        ctx.write(msg);
    @Override
    public void channelReadComplete(ChannelHandlerContext ctx) throws Exception {
        ctx.flush();
    @Override
    public void exceptionCaught(
            ChannelHandlerContext ctx, Throwable cause) throws Exception {
        logger.log(
                Level.WARNING,
                "Unexpected exception from downstream.", cause);
        ctx.close();
ObjectEchoServer
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
import io.netty.bootstrap.ServerBootstrap;
import io.netty.channel.socket.nio.NioServerSocketChannel;
import io.netty.example.echo.EchoServer;
 * Modification of {@link EchoServer} which utilizes Java object serialization.
public class ObjectEchoServer {
    public ObjectEchoServer(int port) {
        this.port = port;
        EventLoopGroup bossGroup = new NioEventLoopGroup();
        EventLoopGroup workerGroup = new NioEventLoopGroup();
        try {
            ServerBootstrap b = new ServerBootstrap();
            b.group(bossGroup, workerGroup)
             .channel(NioServerSocketChannel.class)
             .childHandler(new ChannelInitializer<SocketChannel>() {
                @Override
                            new ObjectEchoServerHandler());
            // Bind and start to accept incoming connections.
            b.bind(port).sync().channel().closeFuture().sync();
        } finally {
            bossGroup.shutdownGracefully();
            workerGroup.shutdownGracefully();
        int port;
        if (args.length > 0) {
            port = Integer.parseInt(args[0]);
        } else {
            port = 8080;
        new ObjectEchoServer(port).run();
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
 * Handles both client-side and server-side handler depending on which
 * constructor was called.
public class ObjectEchoServerHandler extends ChannelInboundHandlerAdapter {
            ObjectEchoServerHandler.class.getName());
    @Override
        ctx.write(msg);
        System.out.println(msg);
    @Override
        ctx.flush();
    @Override
        logger.log(
                Level.WARNING,
        ctx.close();
Result, 50-coordx1, 56-coordx2,100-coordy1,106-coordy2
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
50
100
56
106
50
100
56
106
50
100
56
106
50
56
100
106
Я собрался передавать данные с помощью сетевой библиотеки Netty. Есть парочка вопросов.
1. Как же получить несколько объектов из pipeline'a ? (сериализация понятно, как это тут реализуется в Netty, видел классы ObjectDecode, ObjectEncode, но как их использовать душе не ясно)
2. Это нормально постоянно в канал отсылать координаты игрока?
3. Я видел реализации серверов с пакетами. В пакетах(специальный класс Packet) обычно отсылают "код управления", что-то типа остановить сервер, разорвать соединение с клиетном и тд? Для этого они нужны?
4. Почему происходит такое :
50
56
100
106
    #38382970
eldarkaa
i really need your help
    #38383286
eldarkaa
Давайте посоветуем автору решение?) (а то придется к буржуазам идти и считать, что никто тут не может подсказать с нетти(..);
    #38390927
eldarkaa
снова появилось время взяться за Netty, так что если появились спецы подскажите ответы на вопросы (а то придется до всего (очень) долго доходить)
    #38390964
eldarkaa
    #38391305
eldarkaa
ObjectEchoClient
Код: java
1.
2.
3.
Connected.
20 20
Message is sended
ObjectEchoServer
Код: java
1.
2.
3.
4.
5.
6.
7.
Server is started
[Shooter2Dv30082013.Player@14115e3]
io.netty.channel.DefaultChannelHandlerContext@2fb4b69d
DefaultChannelPromise@7036b673(failure(io.netty.handler.codec.EncoderException: java.io.NotSerializableException: io.netty.channel.DefaultChannelHandlerContext)
В самом ObjectEchoServerHandler:
ObjectEchoServerHandler.java
Код: java
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
    @Override
        Player player = (Player) msg;
        entityMap.put(ctx,player);
        System.out.println(entityMap.values());
        System.out.println(player);
        System.out.println(ctx);
        ctx.write(entityMap);
        System.out.println(ctx.write(entityMap));
Player унаследован от сущности Entity, в которой хранятся координаты(переменные) (1 - х, 2 - у).
В EntitiyMap - специальный класс (в первую очередь для Сериализации), в котором хранятся сущности Entity (player,enemy).
Проблема такая. Не хочет получать с сервера объект класса EntityMap.
