Ошибка запуска Apache Tomcat7
Ошибка следущая: Server Tomcat v7.0 Server at localhost was unable to start within 45 seconds. If the server requires more time, try increasing the timeout in the server editor. Пробовал увеличить время (Timeout), переустановил и перезапустил, как апач так и eclipse. Не помогает что делать? ... |
| 30.09.2013, 13:39:56 |
Логи читать. ... |
| 30.09.2013, 13:45:10 |
Вот логи: сен 30, 2013 2:46:01 PM org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jdk1.7.0_25\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;c:\Program Files\Java\bin;c:\java\JasperReports\jasperreports-5.2.0\dist\jasperreports-5.2.0.jar;c:\java\JasperReports\jasperreports-5.2.0\lib;;C:\java\eclipse;;. сен 30, 2013 2:46:01 PM org.apache.tomcat.util.digester.SetPropertiesRule begin WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:MedStatPro' did not find a matching property. сен 30, 2013 2:46:01 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-8080"] сен 30, 2013 2:46:01 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["ajp-bio-8009"] сен 30, 2013 2:46:01 PM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 929 ms сен 30, 2013 2:46:01 PM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina сен 30, 2013 2:46:01 PM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.42 сен 30, 2013 2:46:02 PM org.apache.catalina.core.StandardContext filterStart SEVERE: Exception starting filter EncodingFilter java.lang.NoClassDefFoundError: Filter at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClass(ClassLoader.java:792) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142) at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2895) at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1173) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1681) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1559) at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:527) at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:509) at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:137) at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:260) at org.apache.catalina.core.ApplicationFilterConfig.<init>(ApplicationFilterConfig.java:107) at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:4775) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5452) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1559) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1549) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:724) Caused by: java.lang.ClassNotFoundException: Filter at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1714) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1559) ... 22 more сен 30, 2013 2:46:02 PM org.apache.catalina.core.StandardContext startInternal SEVERE: Error filterStart сен 30, 2013 2:46:02 PM org.apache.catalina.core.StandardContext startInternal SEVERE: Context [/MedStatPro] startup failed due to previous errors сен 30, 2013 2:46:02 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-bio-8080"] сен 30, 2013 2:46:02 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["ajp-bio-8009"] сен 30, 2013 2:46:02 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 651 ms ... |
| 30.09.2013, 13:50:47 |
Ну, вот. Сервер обрыгался стартануть приложение из-за ошибки SEVERE: Exception starting filter EncodingFilter java.lang.NoClassDefFoundError: Filter Эклипс ждал когда подымется контекст. Контекст так и не поднялся. Вот эклипс и решил грохнуть сервер. ... |
| 30.09.2013, 13:55:59 |
в web.xml имя класса прописано без пакетов? ... |
| 30.09.2013, 13:56:19 |
с пакетом ... <filter> <filter-name>EncodingFilter</filter-name> <filter-class>org.ххх.ххх.EncodingFilter</filter-class> <init-param> <param-name>encoding</param-name> <param-value>UTF-8</param-value> </init-param> </filter> <filter-mapping> <filter-name>EncodingFilter</filter-name> <url-pattern>/*</url-pattern> </filter-mapping> ... ... |
| 30.09.2013, 13:59:34 |
Внутри EncodingFilter искпользуется некий класс Filter, который и не найден? ... |
| 30.09.2013, 14:07:49 |
да, почемуто стал ругатся на import javax.servlet.Filter;... Хотя Filter есть и состоит из методов - doFilter(...) и init(FilterConfig) ... |
| 30.09.2013, 14:15:05 |
Кто-то servlet.jar или servlet-api.jar поместил в Томкат куда не следовало. Убедитесь что этот jar не попадает в WEB-INF/lib. Хотя в этом случае томкат его умеет игнорировать. ... |
| 30.09.2013, 14:18:18 |
Вроде исправил, теперь другая ошибка: org.postgresql cannot be resolved to a type тут на jsp ругается: <%@ page import="java.sql.*, java.util.*"%> <% DriverManager.registerDriver(new org.postgresql.Driver()); Connection conn = DriverManager.getConnection("jdbc:postgresql://localhost:5432/db","login","pwd"); %> а настройки такие: CLASSPATH = c:\Program Files\Java\jdk1.7.0_25\lib JAVA_HOME = c:\Program Files\Java\jdk1.7.0_25 PATH = ...;c:\Program Files\Java\jdk1.7.0_25\bin ... |
| 30.09.2013, 15:06:14 |
CLASSPATH указывает туда где postgresql-9.2-1003.jdbc4.jar ... |
| 30.09.2013, 15:07:57 |
_smb_Вроде исправил, теперь другая ошибка: org.postgresql cannot be resolved to a type Ну, драйвера не видит. _smb_тут на jsp ругается: <%@ page import="java.sql.*, java.util.*"%> <% DriverManager.registerDriver(new org.postgresql.Driver()); Connection conn = DriverManager.getConnection("jdbc:postgresql://localhost:5432/db","login","pwd"); %> OMFG, т.е. на каждый запрос каждого пользователя производится попытка зарегать драйевер и создать физическое соединение с БД. _smb_CLASSPATH = c:\Program Files\Java\jdk1.7.0_25\lib Эта переменная среды используется по своему назначению крайне редко. А в серверных приложениях почти никогда. ... |
| 30.09.2013, 15:31:11 |
_smb_CLASSPATH указывает туда где postgresql-9.2-1003.jdbc4.jar Драйвер лежит в c:\Program Files\Java\jdk1.7.0_25\lib ? ... |
| 30.09.2013, 15:31:39 |
Blazkowicz, да, драйвер во всех папках lib лежит)) ... |
| 30.09.2013, 15:45:37 |
У вас куча ошибок. В jre/jdk никогда ничего не добавляйте. Разве что в исключительных случаях, либо в тех, которые строго описаны в документации и тогда когда вы точно знаете что делаете. JDBC драйвера там точно не нужны. Драйверна нужно складывать в WEB-INF/lib или Tomcat7/lib. В нормальном (не учебном) приложении с JDBC нужно работать через пул соединений. С кодом, который у вас вы очень быстро упретесь в лимит соединений со стороны БД. В том виде как реализовано у вас, вы не можете закрыть connection в блоке finally, что неизбежно ведёт к утечкам в случае не штатных ситуаций. ... |
| 30.09.2013, 15:50:41 |
Blazkowicz, Спасибо большое за помошь. Как вы заметили я чайник. Напишу класс только оттуда будет соединение к БД. А всё началось с установкой JasperReports и обновлением Java. Вроде всё вернул в прежнее состояние но проблемы остались. Уберу дрова везде кроме Tomcat7/lib, посмотрю что получится ... |
| 30.09.2013, 16:03:37 |
start [/forum/topic.php?desktop=1&fid=59&tid=2128511]: |
54ms |
66ms |
| others: | 302ms |
| total: | 498ms |
