Не получается настроить mysql в netbeans
Выводит ошибку, когда пытаюсь установить соединение с базой 131016 20:35:57 [Warning] Can't create test file C:\Program Files\xampp\xampp\mysql\data\comp.lower-test 131016 20:35:57 [Warning] Can't create test file C:\Program Files\xampp\xampp\mysql\data\comp.lower-test 131016 20:35:57 [Note] Plugin 'FEDERATED' is disabled. 131016 20:35:57 InnoDB: The InnoDB memory heap is disabled 131016 20:35:57 InnoDB: Mutexes and rw_locks use Windows interlocked functions 131016 20:35:57 InnoDB: Compressed tables use zlib 1.2.3 131016 20:35:57 InnoDB: Initializing buffer pool, size = 128.0M 131016 20:35:57 InnoDB: Completed initialization of buffer pool 131016 20:35:57 InnoDB: Operating system error number 5 in a file operation. InnoDB: The error means mysqld does not have the access rights to InnoDB: the directory. It may also be you have created a subdirectory InnoDB: of the same name as a data file. InnoDB: File name .\ibdata1 InnoDB: File operation call: 'create'. InnoDB: Cannot continue operation. Мои настройки: В чем может быть дело? ... |
| 16.10.2013, 21:42:41 |
start [/forum/topic.php?desktop=1&fid=59&tid=2128404]: |
28ms |
49ms |
83ms |
| others: | 286ms |
| total: | 508ms |
