tomcat 7 не стартует из под eclipse
Установил Tomcat 7. Через startou запускается нормально. А из eclipse ни в какую не хочет. Попробовал поставить Tomcat 6 он из под eclipse стартует нормально. Вот лог: окт 15, 2013 9:39:53 AM org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;C:\Program Files\Pervasive Software\PSQL\bin\;C:\Oracle\product\11.2.0\client_1\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Novell\ZENworks\bin;Z:.;Y:.;C:\eclipse;;. окт 15, 2013 9:39:54 AM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-bio-8080"] окт 15, 2013 9:39:54 AM org.apache.coyote.AbstractProtocol init SEVERE: Failed to initialize end point associated with ProtocolHandler ["http-bio-8080"] java.net.BindException: Address already in use: JVM_Bind <null>:8080 at org.apache.tomcat.util.net.JIoEndpoint.bind(JIoEndpoint.java:406) at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:610) at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:429) at org.apache.coyote.http11.AbstractHttp11JsseProtocol.init(AbstractHttp11JsseProtocol.java:119) at org.apache.catalina.connector.Connector.initInternal(Connector.java:981) at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102) at org.apache.catalina.core.StandardService.initInternal(StandardService.java:559) at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102) at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:814) at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102) at org.apache.catalina.startup.Catalina.load(Catalina.java:640) at org.apache.catalina.startup.Catalina.load(Catalina.java:665) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:281) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:455) Caused by: java.net.BindException: Address already in use: JVM_Bind at java.net.DualStackPlainSocketImpl.bind0(Native Method) at java.net.DualStackPlainSocketImpl.socketBind(Unknown Source) at java.net.AbstractPlainSocketImpl.bind(Unknown Source) at java.net.PlainSocketImpl.bind(Unknown Source) at java.net.ServerSocket.bind(Unknown Source) at java.net.ServerSocket.<init>(Unknown Source) at java.net.ServerSocket.<init>(Unknown Source) at org.apache.tomcat.util.net.DefaultServerSocketFactory.createSocket(DefaultServerSocketFactory.java:49) at org.apache.tomcat.util.net.JIoEndpoint.bind(JIoEndpoint.java:393) ... 17 more окт 15, 2013 9:39:54 AM org.apache.catalina.core.StandardService initInternal SEVERE: Failed to initialize connector [Connector[HTTP/1.1-8080]] org.apache.catalina.LifecycleException: Failed to initialize component [Connector[HTTP/1.1-8080]] at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:106) at org.apache.catalina.core.StandardService.initInternal(StandardService.java:559) at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102) at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:814) at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102) at org.apache.catalina.startup.Catalina.load(Catalina.java:640) at org.apache.catalina.startup.Catalina.load(Catalina.java:665) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:281) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:455) Caused by: org.apache.catalina.LifecycleException: Protocol handler initialization failed at org.apache.catalina.connector.Connector.initInternal(Connector.java:983) at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:102) ... 12 more Caused by: java.net.BindException: Address already in use: JVM_Bind <null>:8080 at org.apache.tomcat.util.net.JIoEndpoint.bind(JIoEndpoint.java:406) at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:610) at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:429) at org.apache.coyote.http11.AbstractHttp11JsseProtocol.init(AbstractHttp11JsseProtocol.java:119) at org.apache.catalina.connector.Connector.initInternal(Connector.java:981) ... 13 more Caused by: java.net.BindException: Address already in use: JVM_Bind at java.net.DualStackPlainSocketImpl.bind0(Native Method) at java.net.DualStackPlainSocketImpl.socketBind(Unknown Source) at java.net.AbstractPlainSocketImpl.bind(Unknown Source) at java.net.PlainSocketImpl.bind(Unknown Source) at java.net.ServerSocket.bind(Unknown Source) at java.net.ServerSocket.<init>(Unknown Source) at java.net.ServerSocket.<init>(Unknown Source) at org.apache.tomcat.util.net.DefaultServerSocketFactory.createSocket(DefaultServerSocketFactory.java:49) at org.apache.tomcat.util.net.JIoEndpoint.bind(JIoEndpoint.java:393) ... 17 more окт 15, 2013 9:39:54 AM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["ajp-bio-8009"] окт 15, 2013 9:39:54 AM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 923 ms окт 15, 2013 9:39:54 AM org.apache.catalina.core.StandardService startInternal INFO: Starting service Catalina окт 15, 2013 9:39:54 AM org.apache.catalina.core.StandardEngine startInternal INFO: Starting Servlet Engine: Apache Tomcat/7.0.42 окт 15, 2013 9:39:55 AM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["ajp-bio-8009"] окт 15, 2013 9:39:55 AM org.apache.catalina.startup.Catalina start INFO: Server startup in 593 ms ... |
| 15.10.2013, 09:40:47 |
У вас уже кто-то на 8080 висит, вот томкат и не стартует. Address already in use: JVM_Bind <null>:8080 ... |
| 15.10.2013, 10:30:46 |
Почему тогда T6 запускается без проблем? ... |
| 15.10.2013, 11:47:04 |
iv_roman_vlПочему тогда T6 запускается без проблем? Откуда мне знать, где какие конфиги. Может T6 на 80м порту пускается? Запустите 7й, когда ошибка повторится - посомтрите через netstat какой процесс занял порт. http://javarevisited.blogspot.com/2011/12/address-already-use-jvm-bind-exception.html ... |
| 15.10.2013, 11:53:37 |
Blazkowicz, А вот лог от Т6, но причём он запускается.... окт 15, 2013 12:46:36 PM org.apache.catalina.core.AprLifecycleListener init INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre7\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;C:\Program Files\Pervasive Software\PSQL\bin\;C:\Oracle\product\11.2.0\client_1\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft\Web Platform Installer\;C:\Program Files\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Novell\ZENworks\bin;Z:.;Y:.;C:\eclipse;;. окт 15, 2013 12:46:36 PM org.apache.coyote.http11.Http11Protocol init SEVERE: Error initializing endpoint java.net.BindException: Address already in use: JVM_Bind <null>:8080 at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:549) at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:180) at org.apache.catalina.connector.Connector.initialize(Connector.java:1123) at org.apache.catalina.core.StandardService.initialize(StandardService.java:703) at org.apache.catalina.core.StandardServer.initialize(StandardServer.java:838) at org.apache.catalina.startup.Catalina.load(Catalina.java:538) at org.apache.catalina.startup.Catalina.load(Catalina.java:562) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:261) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413) Caused by: java.net.BindException: Address already in use: JVM_Bind at java.net.DualStackPlainSocketImpl.bind0(Native Method) at java.net.DualStackPlainSocketImpl.socketBind(Unknown Source) at java.net.AbstractPlainSocketImpl.bind(Unknown Source) at java.net.PlainSocketImpl.bind(Unknown Source) at java.net.ServerSocket.bind(Unknown Source) at java.net.ServerSocket.<init>(Unknown Source) at java.net.ServerSocket.<init>(Unknown Source) at org.apache.tomcat.util.net.DefaultServerSocketFactory.createSocket(DefaultServerSocketFactory.java:50) at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:538) ... 12 more окт 15, 2013 12:46:36 PM org.apache.catalina.core.StandardService initialize SEVERE: Failed to initialize connector [Connector[HTTP/1.1-8080]] LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind <null>:8080 at org.apache.catalina.connector.Connector.initialize(Connector.java:1125) at org.apache.catalina.core.StandardService.initialize(StandardService.java:703) at org.apache.catalina.core.StandardServer.initialize(StandardServer.java:838) at org.apache.catalina.startup.Catalina.load(Catalina.java:538) at org.apache.catalina.startup.Catalina.load(Catalina.java:562) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:261) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413) окт 15, 2013 12:46:36 PM org.apache.catalina.startup.Catalina load INFO: Initialization processed in 363 ms окт 15, 2013 12:46:36 PM org.apache.catalina.core.StandardService start INFO: Starting service Catalina окт 15, 2013 12:46:36 PM org.apache.catalina.core.StandardEngine start INFO: Starting Servlet Engine: Apache Tomcat/6.0.37 окт 15, 2013 12:46:37 PM org.apache.coyote.http11.Http11Protocol start INFO: Starting Coyote HTTP/1.1 on http-8080 окт 15, 2013 12:46:37 PM org.apache.jk.common.ChannelSocket init INFO: JK: ajp13 listening on /0.0.0.0:8009 окт 15, 2013 12:46:37 PM org.apache.jk.server.JkMain start INFO: Jk running ID=0 time=0/20 config=null окт 15, 2013 12:46:37 PM org.apache.catalina.startup.Catalina start INFO: Server startup in 329 ms ... |
| 15.10.2013, 12:49:07 |
iv_roman_vl, судя по логу томкат 6 тоже не запукается у вас. как вы узнаете что у вас 6й томкат запускается ? если у вас в браузере что то открывается то может это не 6й томкат, а что то еще запущено. посмотрите в процессах скорее всего один из томкатов не завершил работу. ... |
| 16.10.2013, 12:39:50 |
есть два варианта один как указал блазковиц узнать что конкретно работает на 8080 порту. Можно открыть процесс эксплорер и посмотреть Java или javaw процессы. Если он у вас только один то следовательно только эклипса работает (при условаии что она запущена). Если больше то какой то томкат все еще рабоает. Убейте лишние процессы java и все. Надеюсь это не продакшн машина. ... |
| 16.10.2013, 12:43:30 |
start [/forum/topic.php?desktop=1&fid=59&tid=2128403]: |
26ms |
46ms |
62ms |
| others: | 326ms |
| total: | 512ms |
