ошибка в цикле
Подскажите пож-та новичку где в цикле ошибка Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. Выводит следущее: INSERT INTO Rep3_2 (val, S1, S2, S3, S4, S5, S6, S7, S8, S9, S10, S11, S12, S13, S14, S15, S16, S17, S18, S19, S20) VALUES (1, (SELECT R3F1(d1,d2,1,1,1)), (SELECT R3F1(d1,d2,1,2,1)), (SELECT R3F1(d1,d2,1,3,1)), (SELECT R3F1(d1,d2,1,4,1)), (SELECT R3F1(d1,d2,1,5,1)), (SELECT R3F1(d1,d2,1,6,1)), (SELECT R3F1(d1,d2,1,7,1)), (SELECT R3F1(d1,d2,1,8,1)), (SELECT R3F1(d1,d2,1,9,1)), (SELECT R3F1(d1,d2,1,10,1)), (SELECT R3F1(d1,d2,1,11,1)), (SELECT R3F1(d1,d2,1,12,1)), (SELECT R3F1(d1,d2,1,13,1)), (SELECT R3F1(d1,d2,1,14,1)), (SELECT R3F1(d1,d2,1,15,1)), (SELECT R3F1(d1,d2,1,16,1)), (SELECT R3F1(d1,d2,1,17,1)), (SELECT R3F1(d1,d2,1,18,1)), (SELECT R3F1(d1,d2,1,19,1)), (SELECT R3F1(d1,d2,1,20,1))); INSERT INTO Rep3_2 (val, S1, S2, S3, S4, S5, S6, S7, S8, S9, S10, S11, S12, S13, S14, S15, S16, S17, S18, S19, S20) VALUES (1, (SELECT R3F1(d1,d2,1,1,1)), (SELECT R3F1(d1,d2,1,2,1)), (SELECT R3F1(d1,d2,1,3,1)), (SELECT R3F1(d1,d2,1,4,1)), (SELECT R3F1(d1,d2,1,5,1)), (SELECT R3F1(d1,d2,1,6,1)), (SELECT R3F1(d1,d2,1,7,1)), (SELECT R3F1(d1,d2,1,8,1)), (SELECT R3F1(d1,d2,1,9,1)), (SELECT R3F1(d1,d2,1,10,1)), (SELECT R3F1(d1,d2,1,11,1)), (SELECT R3F1(d1,d2,1,12,1)), (SELECT R3F1(d1,d2,1,13,1)), (SELECT R3F1(d1,d2,1,14,1)), (SELECT R3F1(d1,d2,1,15,1)), (SELECT R3F1(d1,d2,1,16,1)), (SELECT R3F1(d1,d2,1,17,1)), (SELECT R3F1(d1,d2,1,18,1)), (SELECT R3F1(d1,d2,1,19,1)), (SELECT R3F1(d1,d2,1,20,1))); (2, (SELECT R3F1(d1,d2,2,1,1)), (SELECT R3F1(d1,d2,2,2,1)), (SELECT R3F1(d1,d2,2,3,1)), (SELECT R3F1(d1,d2,2,4,1)), (SELECT R3F1(d1,d2,2,5,1)), (SELECT R3F1(d1,d2,2,6,1)), (SELECT R3F1(d1,d2,2,7,1)), (SELECT R3F1(d1,d2,2,8,1)), (SELECT R3F1(d1,d2,2,9,1)), (SELECT R3F1(d1,d2,2,10,1)), (SELECT R3F1(d1,d2,2,11,1)), (SELECT R3F1(d1,d2,2,12,1)), (SELECT R3F1(d1,d2,2,13,1)), (SELECT R3F1(d1,d2,2,14,1)), (SELECT R3F1(d1,d2,2,15,1)), (SELECT R3F1(d1,d2,2,16,1)), (SELECT R3F1(d1,d2,2,17,1)), (SELECT R3F1(d1,d2,2,18,1)), (SELECT R3F1(d1,d2,2,19,1)), (SELECT R3F1(d1,d2,2,20,1))); INSERT INTO Rep3_2 (val, S1, S2, S3, S4, S5, S6, S7, S8, S9, S10, S11, S12, S13, S14, S15, S16, S17, S18, S19, S20) VALUES (1, (SELECT R3F1(d1,d2,1,1,1)), (SELECT R3F1(d1,d2,1,2,1)), (SELECT R3F1(d1,d2,1,3,1)), (SELECT R3F1(d1,d2,1,4,1)), (SELECT R3F1(d1,d2,1,5,1)), (SELECT R3F1(d1,d2,1,6,1)), (SELECT R3F1(d1,d2,1,7,1)), (SELECT R3F1(d1,d2,1,8,1)), (SELECT R3F1(d1,d2,1,9,1)), (SELECT R3F1(d1,d2,1,10,1)), (SELECT R3F1(d1,d2,1,11,1)), (SELECT R3F1(d1,d2,1,12,1)), (SELECT R3F1(d1,d2,1,13,1)), (SELECT R3F1(d1,d2,1,14,1)), (SELECT R3F1(d1,d2,1,15,1)), (SELECT R3F1(d1,d2,1,16,1)), (SELECT R3F1(d1,d2,1,17,1)), (SELECT R3F1(d1,d2,1,18,1)), (SELECT R3F1(d1,d2,1,19,1)), (SELECT R3F1(d1,d2,1,20,1))); (2, (SELECT R3F1(d1,d2,2,1,1)), (SELECT R3F1(d1,d2,2,2,1)), (SELECT R3F1(d1,d2,2,3,1)), (SELECT R3F1(d1,d2,2,4,1)), (SELECT R3F1(d1,d2,2,5,1)), (SELECT R3F1(d1,d2,2,6,1)), (SELECT R3F1(d1,d2,2,7,1)), (SELECT R3F1(d1,d2,2,8,1)), (SELECT R3F1(d1,d2,2,9,1)), (SELECT R3F1(d1,d2,2,10,1)), (SELECT R3F1(d1,d2,2,11,1)), (SELECT R3F1(d1,d2,2,12,1)), (SELECT R3F1(d1,d2,2,13,1)), (SELECT R3F1(d1,d2,2,14,1)), (SELECT R3F1(d1,d2,2,15,1)), (SELECT R3F1(d1,d2,2,16,1)), (SELECT R3F1(d1,d2,2,17,1)), (SELECT R3F1(d1,d2,2,18,1)), (SELECT R3F1(d1,d2,2,19,1)), (SELECT R3F1(d1,d2,2,20,1))); (3, (SELECT R3F1(d1,d2,3,1,1)), (SELECT R3F1(d1,d2,3,2,1)), (SELECT R3F1(d1,d2,3,3,1)), (SELECT R3F1(d1,d2,3,4,1)), (SELECT R3F1(d1,d2,3,5,1)), (SELECT R3F1(d1,d2,3,6,1)), (SELECT R3F1(d1,d2,3,7,1)), (SELECT R3F1(d1,d2,3,8,1)), (SELECT R3F1(d1,d2,3,9,1)), (SELECT R3F1(d1,d2,3,10,1)), (SELECT R3F1(d1,d2,3,11,1)), (SELECT R3F1(d1,d2,3,12,1)), (SELECT R3F1(d1,d2,3,13,1)), (SELECT R3F1(d1,d2,3,14,1)), (SELECT R3F1(d1,d2,3,15,1)), (SELECT R3F1(d1,d2,3,16,1)), (SELECT R3F1(d1,d2,3,17,1)), (SELECT R3F1(d1,d2,3,18,1)), (SELECT R3F1(d1,d2,3,19,1)), (SELECT R3F1(d1,d2,3,20,1))); ..... ... |
| 26.11.2013, 10:29:31 |
ошибка в цикле
_smbd_, Да нет ошибки, все правильно выводит. ... |
| 26.11.2013, 10:42:29 |
ошибка в цикле
0FD, ах да, моя ошибка. ошибка выходит после того как вставляю значения d1, d2: for (int j=1; j<=cols; j++) { v += ", (SELECT R3F1(to_date("+"'"+request.getParameter("d1")+"'"+","+"'"+"yyyy-mm-dd"+"'"+"),"+ "to_date("+"'"+request.getParameter("d2")+"'"+","+"'"+"yyyy-mm-dd"+"'"+")," +i+ "," +j+ ",1))"; } ошибка: SEVERE: Servlet.service() for servlet [jsp] in context with path [/MedStatPro] threw exception [An exception occurred processing JSP page /RepExcel3.jsp at line 77 76: stI = con.createStatement(); 77: rsI = stI.executeUpdate(ins); ... |
| 26.11.2013, 10:55:08 |
ошибка в цикле
ошибка здесь конечно в синтаксисе, но на Базе работает. Проверял так SELECT R3F1(to_date('2013-11-01','yyyy-mm-dd'),to_date('2013-11-15','yyyy-mm-dd'),1,1,1) ... |
| 26.11.2013, 10:58:29 |
ошибка в цикле
_smbd_0FD, ах да, моя ошибка. ошибка выходит после того как вставляю значения d1, d2: for (int j=1; j<=cols; j++) { v += ", (SELECT R3F1(to_date("+"'"+request.getParameter("d1")+"'"+","+"'"+"yyyy-mm-dd"+"'"+"),"+ "to_date("+"'"+request.getParameter("d2")+"'"+","+"'"+"yyyy-mm-dd"+"'"+")," +i+ "," +j+ ",1))"; } Ах вот как, я то думал что Вы обратите внимание на то, что блоки разной длины, и то что sql выглядит так insert into t (...) values (1,select ..,...,select ...);, (2,select ..,...,select ...);, (3,select ..,...,select ...) ... |
| 26.11.2013, 11:20:17 |
ошибка в цикле
0FD, Да это и есть первоначальная проблема. Не могу понять почему INSERT INTO Rep3_2 (val, S1, S2, S3, S4, S5, S6, S7, S8, S9, S10, S11, S12, S13, S14, S15, S16, S17, S18, S19, S20) VALUES ставится только один раз ... |
| 26.11.2013, 12:26:43 |
ошибка в цикле
_smbd_, Код: java 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. ... |
| 26.11.2013, 12:36:23 |
ошибка в цикле
а что значит авторно на Базе работает. ? в какой IDE работаешь? что говорит пошаговая отладка? что будет если в цикле запустить только INSERT , по очереди 1,2 или третий? for (int j=2; j<=2; j++) к примеру а ты уверен, что в одном executeUpdate(ins); мщжно запускать несколько INSERT ? ... |
| 26.11.2013, 12:40:21 |
ошибка в цикле
0FD, Спасибо. загнал в цикл: String ins = "INSERT INTO Rep3_2 (" + u + ") VALUES "; Теперь другая проблема, но таже ошибка: org.apache.jasper.JasperException: An exception occurred processing JSP page /RepExcel3.jsp at line 78 77: stI = con.createStatement(); 78: rsI = stI.executeUpdate(ins); вадя прав, нельзя запускать несколько Insert в одном executeUpdate(ins) ... |
| 26.11.2013, 12:53:18 |
ошибка в цикле
вадя, Eclipse IDE. Да Вы правы нельзя запускать несколько Insert в одном executeUpdate Не подскажете как делается пошаговая отладка на Eclipse? ... |
| 26.11.2013, 12:56:51 |
ошибка в цикле
Как быть с executeUpdate(ins)? ... |
| 26.11.2013, 12:58:01 |
ошибка в цикле
вадя, SELECT R3F1(to_date('2013-11-01','yyyy-mm-dd'),to_date('2013-11-15','yyyy-mm-dd'),1,1,1) запрос на Postgresql базе работает. ... |
| 26.11.2013, 13:05:04 |
ошибка в цикле
_smbd_, Ошибку напиши. Скорее всего из-за ; в конце sql : ins = ins + v + "); "; ... |
| 26.11.2013, 13:07:39 |
ошибка в цикле
0FD, ноя 26, 2013 2:18:33 PM org.apache.catalina.core.StandardWrapperValve invoke SEVERE: Servlet.service() for servlet [jsp] in context with path [/MedStatPro] threw exception [An exception occurred processing JSP page /RepExcel3.jsp at line 78 75: // ins = ins.length()-1 + ");"; 76: //out.println(ins); 77: stI = con.createStatement(); 78: rsI = stI.executeUpdate(ins); 79: 80: Statement st = null; 81: ResultSet rs = null; Stacktrace:] with root cause org.postgresql.util.PSQLException: ERROR: syntax error at or near ";" Позиция: 154 at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2157) at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1886) at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:255) at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:555) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:403) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(AbstractJdbc2Statement.java:331) at org.apache.jsp.RepExcel3_jsp._jspService(RepExcel3_jsp.java:145) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.nodir.toshmi.EncodingFilter.doFilter(EncodingFilter.java:34) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) ... |
| 26.11.2013, 13:19:07 |
ошибка в цикле
_smbd_, ins = ins + v + ")"; ... |
| 26.11.2013, 13:22:38 |
ошибка в цикле
0FD, Сделал, но все еще ругается org.apache.jasper.JasperException: An exception occurred processing JSP page /RepExcel3.jsp at line 78 77: stI = con.createStatement(); 78: rsI = stI.executeUpdate(ins); Может все таки executeUpdate(ins) как-то присвоить на переменную для каждого инсерта? ... |
| 26.11.2013, 13:28:05 |
ошибка в цикле
_smbd_, Ну ошибку напиши, не получается уже у меня по номеру строки определить причину ... |
| 26.11.2013, 13:32:59 |
ошибка в цикле
0FD, так вот же 78-строка: 78: rsI = stI.executeUpdate(ins); полностью ошибка вот: ноя 26, 2013 2:36:33 PM org.apache.catalina.core.StandardWrapperValve invoke SEVERE: Servlet.service() for servlet [jsp] in context with path [/MedStatPro] threw exception [An exception occurred processing JSP page /RepExcel3.jsp at line 78 75: // ins = ins.length()-1 + ");"; 76: //out.println(ins); 77: stI = con.createStatement(); 78: rsI = stI.executeUpdate(ins); 79: 80: Statement st = null; 81: ResultSet rs = null; Stacktrace:] with root cause org.postgresql.util.PSQLException: ERROR: syntax error at or near ";" Позиция: 154 at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2157) at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1886) at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:255) at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:555) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:403) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(AbstractJdbc2Statement.java:331) at org.apache.jsp.RepExcel3_jsp._jspService(RepExcel3_jsp.java:145) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:432) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:390) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:334) at javax.servlet.http.HttpServlet.service(HttpServlet.java:728) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.nodir.toshmi.EncodingFilter.doFilter(EncodingFilter.java:34) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) ... |
| 26.11.2013, 13:36:53 |
ошибка в цикле
_smbd_, Если такая же, напишу еще раз. Убери точку с запятой!!!!!!! ins = ins +v+ "); "; out.println(ins); %><br><br><% <<<<<<< Тут } ins = ins.length()-1 + ");"; <<<<<<<<< Или тут, я не знаю какой у тебя код ... |
| 26.11.2013, 13:41:50 |
ошибка в цикле
0FD, давно убрал ins = ins +v+ ")"; Ругается именно на 78: rsI = stI.executeUpdate(ins); Вобще можно все инсерты одним executeUpdate(ins) выполнять? ... |
| 26.11.2013, 13:50:04 |
ошибка в цикле
_smbd_, Весь код, пжлст. А то ошибка говорит о том что осталась ';' ... |
| 26.11.2013, 13:54:46 |
ошибка в цикле
выведи запрос в консоль,скопируй, вставь в базу а то, что у тебя "работает в базе" отличается от того что в первом посте ... |
| 26.11.2013, 14:11:22 |
ошибка в цикле
0FD, Вот пож-та JDBC_Con obj=new JDBC_Con(); Connection con; con=obj.connect(); Statement stD = null; String del = "Delete from Rep3_2;"; stD = con.createStatement(); int rsD = stD.executeUpdate(del); Statement stI = null; int rsI=0; int cols=20; int rows=16; String v =""; String ins = ""; String u = "val"; for (int i=1; i<=cols; i++) { u += ", S" + i; } for (int i=1; i<=rows; i++) { ins = "INSERT INTO Rep3_2 ("+u+") VALUES "; v = "("+i; for (int j=1; j<=cols; j++) { v += ", (SELECT R3F1(to_date("+"'"+request.getParameter("d1")+"'"+","+"'"+"yyyy-mm-dd"+"'"+"),"+ "to_date("+"'"+request.getParameter("d2")+"'"+","+"'"+"yyyy-mm-dd"+"'"+")," +i+ "," +j+ ",1))"; } ins = ins +v+ ")"; } stI = con.createStatement(); rsI = stI.executeUpdate(ins); ... |
| 26.11.2013, 14:17:07 |
ошибка в цикле
А это весь jsp <%@ page language="java" contentType="text/html; charset=UTF-8" pageEncoding="UTF-8"%> <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" " http://www.w3.org/TR/html4/loose.dtd"> <%@ page import="java.sql.*, java.util.*"%> <%@ page import="org.nodir.toshmi.JDBC_Con" %> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8"> <title>SMTH</title> </head> <body LINK="blue"> <% String exportToExcel = request.getParameter("exportToExcel"); if (exportToExcel != null && exportToExcel.toString().equalsIgnoreCase("YES")) { response.setContentType("application/vnd.ms-excel"); response.setHeader("Content-Disposition", "inline; filename=" + "Region_Otdel.xls"); } %> <table width=1100 align="center"> <th colspan="21">Худудлар ва бўлимлар бўйича шифохонадан чиқарилганлар. Бюджет.<br>В разрезе областей и отделов. Бюджет.</th> </table><br> <table width=1100 align="center" border="1"> <thead> <tr> <td align="center"></td> <td align="center"><b>Ревматология</b></td> <td align="center"><b>Эндокринология</b></td> <td align="center"><b>терепия</b></td> <td align="center"><b>Кардиология</b></td> <td align="center"><b>Кардиореанимация</b></td> <td align="center"><b>SMTH</b></td> <td align="center"><b>Взрос.инфекция</b></td> <td align="center"><b>Детская.инфекция</b></td> <td align="center"><b>SMTH</b></td> <td align="center"><b>Взрослая ЛОР</b></td> <td align="center"><b>Детская ЛОР</b></td> <td align="center"><b>Взр.хир.стом.</b></td> <td align="center"><b>Дет.хир.стом.</b></td> <td align="center"><b>Гинекология</b></td> <td align="center"><b>Хир.реанимация</b></td> <td align="center"><b>К-ка реабилитация</b></td> <td align="center"><b>Гинекология реанимация</b></td> <td align="center"><b>Нефрология</b></td> <td align="center"><b>Неврология</b></td> <td align="center"><b>Дет.хир.стом.(SMTH)</b></td> </tr> </thead> <tbody> <% JDBC_Con obj=new JDBC_Con(); Connection con; con=obj.connect(); Statement stD = null; String del = "Delete from Rep3_2;"; stD = con.createStatement(); int rsD = stD.executeUpdate(del); Statement stI = null; int rsI=0; int cols=20; int rows=16; String v =""; String ins = ""; String u = "val"; for (int i=1; i<=cols; i++) { u += ", S" + i; } for (int i=1; i<=rows; i++) { ins = "INSERT INTO Rep3_2 ("+u+") VALUES "; v = "("+i; for (int j=1; j<=cols; j++) { v += ", (SELECT R3F1(to_date("+"'"+request.getParameter("d1")+"'"+","+"'"+"yyyy-mm-dd"+"'"+"),"+ "to_date("+"'"+request.getParameter("d2")+"'"+","+"'"+"yyyy-mm-dd"+"'"+")," +i+ "," +j+ ",1))"; } ins = ins +v+ ")"; } stI = con.createStatement(); rsI = stI.executeUpdate(ins); Statement st = null; ResultSet rs = null; String sel = "SELECT r1.uz_, r1.ru_, r1.val, r2.S1, r2.S2, r2.S3, r2.S4, r2.S5, r2.S6, r2.S7, r2.S8, r2.S9, r2.S10, "+ " r2.S11, r2.S12, r2.S13, r2.S14, r2.S15, r2.S16, r2.S17, r2.S18, r2.S19, r2.S20" + " FROM Rep3_1 r1 "+ "FULL OUTER JOIN Rep3_2 r2 "+ " ON r1.val=r2.val "+ "ORDER BY r1.val;"; st = con.createStatement(); rs = st.executeQuery(sel); while (rs.next()) { %> <tr><td><b><%=rs.getString(1)%></b></td> <td><%=rs.getInt(4)%></td><td><%=rs.getInt(5)%></td><td><%=rs.getInt(6)%></td><td><%=rs.getInt(7)%></td><td><%=rs.getInt(8)%></td> <td><%=rs.getInt(9)%></td><td><%=rs.getInt(10)%></td><td><%=rs.getInt(11)%></td><td><%=rs.getInt(12)%></td><td><%=rs.getInt(13)%></td> <td><%=rs.getInt(14)%></td><td><%=rs.getInt(15)%></td><td><%=rs.getInt(16)%></td><td><%=rs.getInt(17)%></td><td><%=rs.getInt(18)%></td> <td><%=rs.getInt(19)%></td><td><%=rs.getInt(20)%></td><td><%=rs.getInt(21)%></td><td><%=rs.getInt(22)%></td><td><%=rs.getInt(23)%></td></tr> <% } %> </tbody> </table> <br> <% if (exportToExcel == null) { %> <a href="DepRegionsRep.jsp?exportToExcel=YES"><Font size="5" color="blue">Export to Excel</Font></a> <% } %> </body> </html> <% try { //con.commit(); con.close(); } catch (SQLException e) { e.printStackTrace(); } %> ... |
| 26.11.2013, 14:21:48 |
ошибка в цикле
_smbd_, Да в том месте нет ; Может из-за этих ; String del = "Delete from Rep3_2;<-------"; или String sel = "SELECT r1.uz_, r1.ru_, r1.val, r2.S1, r2.S2, r2.S3, r2.S4, r2.S5, r2.S6, r2.S7, r2.S8, r2.S9, r2.S10, "+ " r2.S11, r2.S12, r2.S13, r2.S14, r2.S15, r2.S16, r2.S17, r2.S18, r2.S19, r2.S20" + " FROM Rep3_1 r1 "+ "FULL OUTER JOIN Rep3_2 r2 "+ " ON r1.val=r2.val "+ "ORDER BY r1.val;<----------"; ... |
| 26.11.2013, 14:36:32 |
start [/forum/topic.php?desktop=1&fid=59&tid=2128121]: |
319ms |
66ms |
| others: | 291ms |
| total: | 736ms |
