java.io.BufferedReader@40545646
package javaapplication18; import java.io.BufferedReader; import java.io.FileInputStream; import java.io.FileNotFoundException; import java.io.IOException; import java.io.InputStreamReader; public class Tath { public void f() throws IOException { try { FileInputStream fis = new FileInputStream("D://0.txt"); BufferedReader br = new BufferedReader(new InputStreamReader(fis)); br.readLine(); System.out.println("" + br); } catch (FileNotFoundException ex) { System.out.println("File 0.txt doesn't exist"); } } } package javaapplication18; import java.io.IOException; public class Main { public static void main(String[] args) throws IOException { Tath object = new Tath(); object.f(); } } Результат java.io.BufferedReader@40545646, как сделать так чтобы выходили буквы? ... |
| 27.12.2013, 16:13:31 |
Arkadi, нужно br.readLine() записать в стринг перед выводом ... |
| 27.12.2013, 16:17:43 |
start [/forum/topic.php?desktop=1&fid=59&tid=2127897]: |
57ms |
36ms |
| others: | 298ms |
| total: | 452ms |
