Hibernate 3.4.0 Interbase 7.5.1 jaybird 2.2.4 java 1.7
Помогите разобраться. Имеется datasource в xml: <bean id="dataSourceInterBase" class="org.springframework.jdbc.datasource.DriverManagerDataSource" p:driverClassName="${interbase.jdbc.driverClassName}" p:url="${interbase.jdbc.databaseurl}" p:username="${interbase.jdbc.username}" p:password="${interbase.jdbc.password}"/> соответственно jdbc.properties: interbase.jdbc.driverClassName=org.firebirdsql.jdbc.FBDriver interbase.jdbc.databaseurl=jdbc:firebirdsql:granit/3050:C:/Base/PANELS.gdb interbase.jdbc.username=* interbase.jdbc.password=* При запуске получаю ошибку: WARN : org.hibernate.util.JDBCExceptionReporter - SQL Error: 335544583, SQLState: HY000 ERROR: org.hibernate.util.JDBCExceptionReporter - GDS Exception. 335544583. SQLDA missing or incorrect version, or incorrect number/type of variables WARN : org.hibernate.cfg.SettingsFactory - Could not obtain connection metadata org.firebirdsql.jdbc.FBSQLException: GDS Exception. 335544583. SQLDA missing or incorrect version, or incorrect number/type of variables at org.firebirdsql.jdbc.FBDataSource.getConnection(FBDataSource.java:123) at org.firebirdsql.jdbc.AbstractDriver.connect(AbstractDriver.java:126) at java.sql.DriverManager.getConnection(DriverManager.java:571) at java.sql.DriverManager.getConnection(DriverManager.java:187) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:173) at org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:164) at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:153) at org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119) at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:83) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:111) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2101) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1325) at org.hibernate.cfg.AnnotationConfiguration.buildSessionFactory(AnnotationConfiguration.java:867) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:863) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:782) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:188) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1541) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1479) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1387) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1128) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:626) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479) at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:389) at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:294) at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4887) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5381) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633) at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:657) at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1637) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at java.lang.Thread.run(Thread.java:724) ... |
| 13.01.2014, 14:04:53 |
Драйвер не той версии? https://www.google.com/search?q="SQLDA missing or incorrect version, or incorrect number/type of variables" ... |
| 13.01.2014, 14:07:19 |
Сервер не той версии. Не надо ходить к InterBase 7.5.1 через JayBird, который реализует протокол доступа к Firebird и думать, что всё будет шоколадно. Если у InterBase есть собственный jdbc-драйвер - используйте его. Нет - обломайтесь. ... |
| 13.01.2014, 16:18:41 |
start [/forum/topic.php?desktop=1&fid=59&tid=2127830]: |
25ms |
73ms |
61ms |
| others: | 300ms |
| total: | 503ms |
