помогите пожалуийста..error: не может найти символ method add
/* * To change this template, choose Tools | Templates * and open the template in the editor. */ /* * mainForm.java * * Created on 31.01.2014, 23:13:52 */ package druce; import java.util.HashMap; import java.util.ArrayList; import java.util.Iterator; import javax.swing.JOptionPane; /** * * @author Arlindo */ public class squad extends javax.swing.JFrame { HashMap al= new HashMap(); private Object p; /** Creates new form mainForm */ public squad() { initComponents(); } /** This method is called from within the constructor to * initialize the form. * WARNING: Do NOT modify this code. The content of this method is * always regenerated by the Form Editor. */ @SuppressWarnings("unchecked") // <editor-fold defaultstate="collapsed" desc="Generated Code"> private void initComponents() { jButton1 = new javax.swing.JButton(); jButton2 = new javax.swing.JButton(); jLabel1 = new javax.swing.JLabel(); jLabel2 = new javax.swing.JLabel(); jLabel3 = new javax.swing.JLabel(); jLabel4 = new javax.swing.JLabel(); name = new javax.swing.JTextField(); nationality = new javax.swing.JTextField(); course = new javax.swing.JTextField(); age = new javax.swing.JTextField(); jScrollPane1 = new javax.swing.JScrollPane(); jTextArea1 = new javax.swing.JTextArea(); setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE); jButton1.setText("Добавить "); jButton1.addActionListener(new java.awt.event.ActionListener() { public void actionPerformed(java.awt.event.ActionEvent evt) { jButton1ActionPerformed(evt); } }); jButton2.setText("Выход"); jButton2.addActionListener(new java.awt.event.ActionListener() { public void actionPerformed(java.awt.event.ActionEvent evt) { jButton2ActionPerformed(evt); } }); jLabel1.setText("ФИО :"); jLabel2.setText("nationality:"); jLabel3.setText("course:"); jLabel4.setText("age:"); jTextArea1.setColumns(20); jTextArea1.setRows(5); jScrollPane1.setViewportView(jTextArea1); javax.swing.GroupLayout layout = new javax.swing.GroupLayout(getContentPane()); getContentPane().setLayout(layout); layout.setHorizontalGroup( layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING) .addGroup(layout.createSequentialGroup() .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING) .addComponent(jScrollPane1, javax.swing.GroupLayout.DEFAULT_SIZE, 390, Short.MAX_VALUE) .addGroup(layout.createSequentialGroup() .addContainerGap() .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING) .addGroup(layout.createSequentialGroup() .addComponent(jButton1) .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, 230, Short.MAX_VALUE) .addComponent(jButton2)) .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, layout.createSequentialGroup() .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING) .addComponent(jLabel1) .addComponent(jLabel2) .addComponent(jLabel3) .addComponent(jLabel4)) .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED, 41, Short.MAX_VALUE) .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING, false) .addComponent(age) .addComponent(course) .addComponent(nationality) .addComponent(name, javax.swing.GroupLayout.DEFAULT_SIZE, 285, Short.MAX_VALUE)))))) .addContainerGap()) ); layout.setVerticalGroup( layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING) .addGroup(javax.swing.GroupLayout.Alignment.TRAILING, layout.createSequentialGroup() .addComponent(jScrollPane1, javax.swing.GroupLayout.DEFAULT_SIZE, 136, Short.MAX_VALUE) .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED) .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE) .addComponent(jLabel1) .addComponent(name, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)) .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED) .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE) .addComponent(jLabel2) .addComponent(nationality, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)) .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED) .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE) .addComponent(jLabel3) .addComponent(course, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)) .addPreferredGap(javax.swing.LayoutStyle.ComponentPlacement.RELATED) .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE) .addComponent(jLabel4) .addComponent(age, javax.swing.GroupLayout.PREFERRED_SIZE, javax.swing.GroupLayout.DEFAULT_SIZE, javax.swing.GroupLayout.PREFERRED_SIZE)) .addGap(26, 26, 26) .addGroup(layout.createParallelGroup(javax.swing.GroupLayout.Alignment.BASELINE) .addComponent(jButton1) .addComponent(jButton2)) .addContainerGap()) ); pack(); }// </editor-fold> private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) { // TODO add your handling code here: jTextArea1.setText( name.getText() + nationality.getText() + course.getText() + age.getText()); if(name.getText().equals("")||nationality.getText().equals("") ||course.getText().equals("")||age.getText().equals("")) JOptionPane.showMessageDialog(this,"Необходмые поля не были заполнены!","Ошибка", JOptionPane.ERROR_MESSAGE); else try{ Integer.parseInt(course.getText()); al.Add(p) ; p=null; Iterator it = al.entrySet().iterator(); while (it.hasNext()) { doc ap=(doc)it.next(); jTextArea1.append("ФИО:"+ap.getname()+"nationality:"+ap.getnationality()+" course:"+ Integer.toString(ap.getcourse())+"age:"+ap.getbirthyear()+'\n'); ap=null; } } catch (NumberFormatException e){ JOptionPane.showMessageDialog(this,"Введены неверные данные!","Ошибка", JOptionPane.ERROR_MESSAGE ); } } private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) { // TODO add your handling code here: System.exit(0); } /** * @param args the command line arguments */ public static void main(String args[]) { java.awt.EventQueue.invokeLater(new Runnable() { @Override public void run() { new squad().setVisible(true); } }); } // Variables declaration - do not modify public static javax.swing.JTextField age; public static javax.swing.JTextField course; private javax.swing.JButton jButton1; private javax.swing.JButton jButton2; private javax.swing.JLabel jLabel1; private javax.swing.JLabel jLabel2; private javax.swing.JLabel jLabel3; private javax.swing.JLabel jLabel4; private javax.swing.JScrollPane jScrollPane1; private javax.swing.JTextArea jTextArea1; public static javax.swing.JTextField name; public static javax.swing.JTextField nationality; // End of variables declaration } [SRC java][/SRC] ... |
| 05.02.2014, 02:54:30 |
start [/forum/topic.php?desktop=1&fid=59&tid=2127701]: |
27ms |
103ms |
27ms |
68ms |
| others: | 296ms |
| total: | 563ms |
