hibernate: MySQL: Could not bind factory to JNDI
Возникает ошибка при выполнении на MySQL. Также появляется Could not unbind factory from JNDI при закрытии сессии. Как это исправить? Код: java 1. 2. 3. авторWARN: HHH000277: Could not bind factory to JNDI org.hibernate.engine.jndi.JndiException: Error parsing JNDI name [] at org.hibernate.engine.jndi.internal.JndiServiceImpl.parseName(JndiServiceImpl.java:141) at org.hibernate.engine.jndi.internal.JndiServiceImpl.bind(JndiServiceImpl.java:157) at org.hibernate.internal.SessionFactoryRegistry.addSessionFactory(SessionFactoryRegistry.java:103) at org.hibernate.internal.SessionFactoryImpl.<init>(SessionFactoryImpl.java:497) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1857) at org.hibernate.HibernateUtilities.<clinit>(HibernateUtilities.java:20) at org.hibernate.HibernateTest.main(HibernateTest.java:23) Caused by: javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:662) at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:307) at javax.naming.InitialContext.getURLOrDefaultInitCtx(InitialContext.java:344) at javax.naming.InitialContext.getNameParser(InitialContext.java:499) at org.hibernate.engine.jndi.internal.JndiServiceImpl.parseName(JndiServiceImpl.java:135) ... 6 more ... |
| 06.05.2014, 10:03:53 |
Ну, а в самом конфиге что? ... |
| 06.05.2014, 10:10:20 |
start [/forum/topic.php?desktop=1&fid=59&tid=2127221]: |
356ms |
50ms |
| others: | 289ms |
| total: | 752ms |
