ejb fail authentiaction
Делал простое ejb приложение при запуске выдает: ERROR: JBREM000200: Remote connection failed: javax.security.sasl.SaslException: Authentication failed: all available authentication mechanisms failed javax.naming.NamingException: Failed to create remoting connection [Root exception is java.lang.RuntimeException: javax.security.sasl.SaslException: Authentication failed: all available authentication mechanisms failed] at org.jboss.naming.remote.client.ClientUtil.namingException(ClientUtil.java:36) at org.jboss.naming.remote.client.InitialContextFactory.getInitialContext(InitialContextFactory.java:121) at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:684) at javax.naming.InitialContext.getDefaultInitCtx(InitialContext.java:307) at javax.naming.InitialContext.init(InitialContext.java:242) at javax.naming.InitialContext.<init>(InitialContext.java:216) at com.simple.client.Client.getInitialContext(Client.java:22) at com.simple.client.Client.doLookup(Client.java:37) at com.simple.client.Client.main(Client.java:28) jboss-ejb-client.properties endpoint.name=client-endpoint remote.connectionprovider.create.options.org.xnio.Options.SSL_ENABLED=false remote.connections=default remote.connection.default.host=10.20.30.40 remote.connection.default.port = 4447 remote.connection.default.connect.options.org.xnio.Options.SASL_POLICY_NOANONYMOUS=false remote.connection.default.username=admin remote.connection.default.password=12345 jndi.properties java.naming.factory.initial=org.jboss.naming.remote.client.InitialContextFactory java.naming.factory.url.pkgs=org.jboss.ejb.client.naming java.naming.provider.url=remote://localhost:4447 java.naming.security.principal=admin java.naming.security.credentials=12345 сервер jboss 7.1 юзера создал. в консоль jboss зайти могу под (admin,12345) в чем может быть проблема? ... |
| 01.08.2014, 17:39:56 |
start [/forum/topic.php?desktop=1&fid=59&tid=2126802]: |
64ms |
49ms |
| others: | 356ms |
| total: | 549ms |
