Падает сервер
После какого-то времени работы, получаю вот это, причем это уже не первый раз. Если я перезапущу сервер, оно заведется. авторService Temporarily Unavailable The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later. Apache/2.2.15 (Red Hat) Server at service-infosearch.rhcloud.com Port 80 Вот все что показывает в логах: автор==> app-root/logs/haproxy.log <== [ALERT] 230/145135 (49658) : proxy 'express' has no server available! [WARNING] 230/145246 (49658) : Server express/local-gear is UP (leaving maintenance). [WARNING] 230/150417 (49658) : Server express/local-gear is DOWN for maintenance. [ALERT] 230/150417 (49658) : proxy 'express' has no server available! [WARNING] 230/150536 (49658) : Server express/local-gear is UP (leaving maintenance). [WARNING] 234/162639 (49658) : Server express/local-gear is DOWN, reason: Layer7 timeout, check duration: 10002ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue. [ALERT] 234/162639 (49658) : proxy 'express' has no server available! [WARNING] 234/162800 (49658) : Server express/local-gear is UP, reason: Layer7 check passed, code: 200, info: "OK", check duration: 4ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue. [WARNING] 236/044431 (49658) : Server express/local-gear is DOWN for maintenance. [ALERT] 236/044431 (49658) : proxy 'express' has no server available! ==> app-root/logs/jbossas.log <== 2014/08/25 04:44:47,307 INFO [com.jolbox.bonecp.BoneCP] (MSC service thread 1-1) Shutting down connection pool... 2014/08/25 04:44:47,846 INFO [com.jolbox.bonecp.BoneCP] (MSC service thread 1-1) Connection pool has been shutdown. 2014/08/25 04:44:48,067 INFO [stdout] (MSC service thread 1-1) Context destroyed! 2014/08/25 04:44:48,185 INFO [org.hornetq.ra.HornetQResourceAdapter] (MSC service thread 1-3) HornetQ resource adapter stopped 2014/08/25 04:44:49,432 INFO [org.jboss.weld.deployer] (MSC service thread 1-2) JBAS016009: Stopping weld service for deployment ROOT.war 2014/08/25 04:44:50,331 INFO [com.arjuna.ats.jbossatx] (MSC service thread 1-2) ARJUNA032018: Destroying TransactionManagerService 2014/08/25 04:44:50,414 INFO [com.arjuna.ats.jbossatx] (MSC service thread 1-3) ARJUNA032014: Stopping transaction recovery manager 2014/08/25 04:44:51,812 INFO [org.hornetq.core.server.impl.HornetQServerImpl] (MSC service thread 1-4) HornetQ Server version 2.2.13.Final (HQ_2_2_13_FINAL_AS7, 122) [ae69a4b4-f302-11e3-b99a-22000a9d2078] stopped 2014/08/25 04:44:52,840 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015877: Stopped deployment ROOT.war in 16053ms 2014/08/25 04:44:52,989 INFO [org.jboss.as] (MSC service thread 1-1) JBAS015950: JBoss AS 7.1.1.Final "Brontes" stopped in 16185ms Есть какие-нибудь соображения? ... |
| 25.08.2014, 15:06:01 |
Падает сервер
Причем он похоже не падает, а просто корректно останавливается... ... |
| 25.08.2014, 15:09:25 |
Падает сервер
rema174, я не понял или у тебя деплой варника идёт 16 сек? ... |
| 25.08.2014, 15:17:46 |
Падает сервер
Это не у меня, это сервер деплоит автомататически, видимо в связи с чем то (восстанавливает работу?). Хотя, если я с локалки деплою, то это занимает даже больше времени. ... |
| 25.08.2014, 15:21:34 |
Падает сервер
rema174, Гугл советует увеличить deployment-timeout в standalone.xml. Посмотри лог деплоймента. Может там какие-то предупреждения есть. ... |
| 25.08.2014, 15:24:06 |
Падает сервер
rema174, я бы не давал ему "самому по себе") Может это и тормозит. ... |
| 25.08.2014, 15:25:14 |
Падает сервер
Blazkowicz, Не нахожу такого файла. Как он может называться, deployment.log? Попробовал увелить таймаут в два раза, посмотрим как оно поведет. ... |
| 25.08.2014, 15:47:21 |
Падает сервер
rema174Не нахожу такого файла. Как он может называться, deployment.log? Ты вырезал кусок лога, в котором сервер останавливается. Надо читать лог того как сервер запускается. ... |
| 25.08.2014, 15:49:28 |
start [/forum/topic.php?desktop=1&fid=59&tid=2126535]: |
38ms |
62ms |
| others: | 331ms |
| total: | 493ms |
